New DJI Avata Firmware Released (12/28/2023)
12345
34461 184 2022-9-14
Johmic
Flight distance : 196955 ft
Greece
Sorry but here in Greece its been a hole day, that's why i was curious
2023-12-29
fansa697bdd1
Flight distance : 823271 ft
Could they be more vague with there "fixes".
2023-12-29
fansa697bdd1
Where is compatibility with the RC Motion2 and the DJI FPV Simulator??
U force me to buy and used itthe thing.
Now at least make it compatible with your own software.
2023-12-29
Johmic
Greece
Just for the information, i did the firmware update and everything is still ok.... For your consideration. .... Happy new Year to all of you.....
2023-12-29
fredbotton75
Flight distance : 1832001 ft
@ DJI Support : Is there a way to know more about the Avata "known issues" corrected by update dated 2023.12.28 ?
2023-12-30
Drone Junkie RC
Flight distance : 1015679 ft
I would like to know the known issues is that possible?
2023-12-30
matt2k
Austria
Hello after the new FW update v01.05.0000 the M mode no longer works on my avata via the RC2 only N and S. what can I do? Thanks
2023-12-30
matt2k
Austria
matt2k Posted at 12-30 11:19
problem solved
2023-12-30
SaurabhSrivastava
Flight distance : 2380479 ft
India
The firmware resets the M button to Sports.
You need to go into settings->controller and enable the M mode again.
2023-12-30
SaurabhSrivastava
India
Drone Junkie RC Posted at 12-30 11:04
We will never know.
2023-12-30
Drone Junkie RC
So we wait
2023-12-30
alex_markov
Flight distance : 39646480 ft
Bulgaria
My experience with DJI upgrades since 2016 (my first Mavic Pro ;) ) taught me that "Fixed some known issues." means DJI imposing some restrictions So I'll pass on this one ... for now
2023-12-30
DJI Tony
fredbotton75 Posted at 12-30 01:20
Hi there. When "fixed some bugs" or "fixed some known issues" is described in the firmware release notes, it is usually to update some regular software running logic or fix some problems that do not affect the use of the product. These have no impact on your use of the product. If it is an important firmware upgrade, engineers will list in the release notes what new features have been added or what user experience has been improved. At this time, it is recommended that you update the firmware in time to get a better experience. Have a nice day.
2023-12-31
DJI Tony
Hi, Drone Junkie RC. "Fixed some known issues" usually fixes problems encountered by a small number of customers or other invisible problems. If you have not encountered problems before, the update will have no actual impact, and the update is usually for the stability of use. Thank you for understanding.
2023-12-31
DJI Tony
alex_markov Posted at 12-30 23:19
Hi, Alex. Sorry about the inconvenience. It is recommended to update the firmware for a better experience. Important updates that affect the use of the product are normally posted. Have a nice day.
2023-12-31
KREMi
Poland
I will also wait with it - who works between x-mas and NewYear - so it might be prepared in advance patch for new changes in 2024 rules = more restrictions aka 120m AGL, etc..
I think if it would fix that Yaw issues, or oversensitivity after hiting some branches, where drone can go max throttle - they would write about it :/
wait till 1.1.24 and see what changed there first ;) then if green light from community, update
2023-12-31
Johmic
Greece
As i said in earlier post nothing has changed.... Eveything stil works as before....
2023-12-31
RGMGFitness
Flight distance : 233757 ft
frankymusik Posted at 2022-9-14 12:34
I can confirm that FCC Mode (with the 0 byte file) still works!
I just tested it!
Thank you for the heads up!  First question many will ask I'm sure.
2023-12-31
nightfly
Romania
RGMGFitness Posted at 2023-12-31 09:53
that post is old
that fcc mode doesnt work form a long time ago
1-2 20:19
SaurabhSrivastava
India
nightfly Posted at 1-2 20:19
that post is old
The Ham file hack still works on the latest firmware. It switches to FCC mode. What is your issue?
1-2 22:47
Mini-G
Flight distance : 673862 ft
So what’s new?
1-3 04:46
Xviews
Flight distance : 229255 ft
that post is old
it works, already tested with several avatas
1-3 11:11
SaurabhSrivastava
India
Mini-G Posted at 1-3 04:46
So what’s new?
So as per DJI, there are some invisible upgrades to an end user that include changes that do optimization of code, cleans some bugs, etc.
While this may not be apparent to an end user or bring in any new feature, it is still recommended by the company to upgrade to the latest firmware in order to ensure a smooth and safe flight as there may be small improvements in the code.
1-3 18:52
SaurabhSrivastava
India
As far as the Ham File hack is concerned, it still works and is no issue. You can switch to FCC mode using the ham file.
1-4 17:36
SalvoB.
Flight distance : 284272 ft
Please Put The New Manual Whit The declaration of the maximum take off weight. For the new EASA Rules from 1 January 2024, to Fly in A3 Category, and respect Art. 20 EASA Wont. Thanks.
1-5 09:07
12345
