Hello, I've got my new Avata kit today, and unfortunately, the weather is really bad outdoors, so I've decided to test it indoors first after seeing many videos of how people manage to do that. Is it normal that once I set everything up, the antenna signals show 0 and only 7Mbps. I tried flying it but shortly after takeoff, it starts flying on its own and doesn't respond to the motion controller anymore.
Am I missing something or do I need to change anything in settings first? I've seen many videos of how people are inside and fly the drone indoors + outdoors, behind walls, etc., without any interference, like this real estate video for example. How is this possible?
Hello there djiplay. I am sorry for the trouble this has caused and thank you for giving out these information. Just a friendly reminder that DJI do not recommend flying your DJI Avata indoors as the environment indoors may have interference and caused an incident and also during low light condition as the vision sensors may not work properly. DJI suggest to choose an outdoor open area where the GPS is good, no magnetic interference, to fly the DJI Avata and check if all the functions are normal. Thank you.
DJI Stephen Posted at 9-16 01:16
Thanks but this is really not answering any of my questions.
The aircraft is in "Low Power State" and that is normal until you start the motors. As for flying indoors, it needs quite a bit of light to work properly and be stable.
KLRSKIR Posted at 9-16 03:26
Thanks, it's the same thing with GPS after turning on the motors. It flies sort of on its own then and can't control it, that's why I posted as well. Light is sufficient as well.
Are indoors meant to be flown in manual mode? I have a motion controller only so can't swap to M for now but from what I've seen from the videos, it should work in Normal and Sports as well.
Stop The BS Dji Why i still spend over 15k on your drones .. smh what if you want to do real estate videos which is what this drone is made for , just stop it!!!
djiplay Posted at 9-16 03:47
If acting outside too, try re-bind your controller with aircraft via DJI app. Are you using RC 2 or Motion controller?
I did fly my Avata on my own house with RC 2, fully furnished, and not a glitch...no GPS and a huge refrigerator on at kitchen, no magnetic problems either.
What will get the Avata off normal is the kind of floor you have, like, if it is tile or marble very reflective that will be a recipe for a disaster
I had a number of flights inside a house yesterday, and the Avata lost control and went crazy multiple times. It is like it is confused because the GPS is all over the place or non-existent. Is there something I need to do to fly inside? After all, I thought that was one of the main purposes for the Avata, regardless of some comments from DJI and other. Totally confused.
mpoczynek Posted at 12-27 05:24
I'm not sure where you read/heard that the Avata is "made for" indoor flying ?
I really think it's not. If you try and fly it inside, it may work or it might not...
mpoczynek Posted at 2022-12-27 05:24
Mine does the same thing. May fly just fine or may start drifting and fly into the walls. I did a real estate video today and flew down the street into the front door through the main floor out the back over the golf course and back into the house. I then went up and over a loft and when flying through the upstairs bathroom it went out of control and hit the wall and crashed. I restarted it and flew it out but after that crash it was very unstable. Once back outside it flew perfect again. Wonder what the deal is?
TravisSRT Posted at 1-6 15:27
Magnetic interference or the type of surface of the floor, must have contrast and no reflex
When indoor without GPS The only way the drone can position itself without drifting is with the downward vision sistem sensor,but for this to work properly it needs to have reference points,if the floor is just One color(reflective even worse) or is poorly iluminated it Will have trouble to position itself. Having objects on the floor Will help with monochromatic floor and a led facing downwards will help with poorly ilumination (just don't block the vision system .Also there is a height limit for the vision system to work (5 meters if Im not mystaken)
why keep saying this thing is not for indoor flying?
Just watch the promo video on the website.... they fly inside (and not always with good lighting).
with the text: "Fly in places previously impossible".
only remark on the website is:
** When flying indoors, some features may be limited due to insufficient lighting, no GPS signal, or lack of space.
so if you go by the advertising of this thing, it IS for indoor flying.
i flew mine inside a couple of times (would love some good weather so i can go outside). in N mode, with the fpv Rc2. No problem whatsoever.
and i also flew on places with low light.
On site, DJI advise the props guard and sensors as a safety features to fly indoor.
"In addition to the built-in propeller guard, Avata features downward binocular vision and ToF infrared sensing for even greater safety. These sensors detect obstacles below and allow Avata to perform low-altitude or indoor flight."
HDPS Posted at 2022-10-27 21:39
Hi, just want to check. I fly avata using Normal mode but not stable.
Speed is very slow because i`m not confident enough.
If you dont mind, can your share any tips or tricks for indoor flight ?
saiful_suffian Posted at 2-13 22:47
Hello,
Your Avata should be stable, unless if it is on very high wind situation. I would calibrate everything and check it without any wind or magnetic interference, Avata should hold position steady.
If you are not enough confident yet, avoid confined small places or fly indoors for now. Generally flying indoors you will lose GPS signal, Avata still it will hold stable altitude, will not be bouncing up and down like regular quads. Avoid touching the walls or anything else because Avata Flight Control will go berserk trying to recover without GPS. Also, make sure that the floor is not reflective and has contrast so bottom sensor can properly work. A floor with gloss tile with one color only would not be good for example.
GPS is a driver, in RTH for example.
Inside the IMU should be primary stabilization, especially if the cameras see darkness / no good matches / many IR dots.
Just tried to take off indoors with Avata2, it was not stable, bounced to different sides and flied directly into the walls and finally crashed. What is this?
Info@oranjestate.nl Posted at 5-3 07:55
Post n.19 has your answer...
"** When flying indoors, some features may be limited due to insufficient lighting, no GPS signal, or lack of space."
Personally I think it is just bad marketing advertisment on DJI behalf.
You can fly any drone indoors, but there are some risks involved with it and some skills required...
