DJI Paladin
Hi there. Thank you for reaching out. If you To change the system language of DJI RC Pro/DJI RC, please drag the target language to the top of the page then it will be changed to the target language successfully. The operations are as follows:
Settings-System-Language & input—Languages—Press and hold the drag bar at the right end of the target language and drag it up to the top to modify the language
Note: If you drag it to the top, but the system language is not changed, please wait a while, or use your finger to swipe the screen from top to bottom to speed up the screen refresh, then it will take effect.
Hope this helps. Thank you for your valued support.
Here's some tutorial:
https://www.veed.io/view/836186b ... bbd4a0c24f/showcase
