How to remove the landing legs?
1505 2 2022-10-17
fansdb68f33a
Flight distance : 1001352 ft
Hi all,
I have an m600 and I will travel with it in an airplane, I have the GPC pro case... this case complies with the size regulations for must of the airlines, which is why I select it... but in order for the drone to fit, I have to remove the landing legs, which seems to be easy... but my drone does not have a screw pressing the landing gear leg, which is very strange, it made me think maybe the landing legs are glued? please see the image attached:
landing gear leg
landing gear leg
My question is, how can I remove the landing gear leg?
Thanks!!
2022-10-17
patiam
Flight distance : 1118740 ft
https://dl.djicdn.com/downloads/ ... _Manual_v1.0_EN.pdf
I think you need to release the spring tension to get to the screws you need to loosen? Or if they are simply not there perhaps the spring just holds the legs in?
2022-10-17
DJI Natalia
Hi, there.
Sorry for the late reply.
May we know if your problem is resolved? If not, please check the following details:
There is a spring on the landing gear that hooks the fuselage and the landing gear. First remove the hook of the spring from the landing gear, and then the landing gear can be pulled out.
Thank you.
2022-10-24
