DJI Natalia
Hi, there. Could you please check the following details and keep us updated?
1. The highlight screen version corresponding to aircraft 01.02.0450 is V2.6.6.0, and the latest firmware version of the highlight screen is V3.0.2.0. We recommend that you go to the settings page - system update to check the highlight screen version.
2. For the second problem you mentioned, it may be the problem that the user can not set the custom buttons of the remote control correctly, because the device is a PSDK device, it is recommended that you confirm with their technical support.
3. For the third question, may we know if you mean to change the color of the arms' ESC light? If yes, please note that it is not supported.
4. May we know if you want to zoom? Would you mind telling us more details about this problem so that we can better check?
5. Are you using the DJI Pilot app? If you cannot visually view the downloaded area on the map, you can use the map cache function. When you are connected to the Internet, you can find the area where you need to fly, and then zoom in and out of the map to cache the layer of the location.
6. If you want to connect the Cendence controller to the computer assistant software to upgrade, please note that the Cendence controller does not support connecting to the computer assistant software. But the Cendence S controller is possible(Cendence S is the remote control of the M200 V2).
Thank you for your support in advance.
