DJI Avata Release Notes (12/08/2022)
123
19673 94 2022-11-22
SeehawerB
Flight distance : 5414203 ft
SeehawerB Posted at 12-9 01:20
WTF DJI?
First read about that yesterday and couldn't believe it.
Today I reply myself. Yesterday I did install the complete december 8th firmware update on drone, googles 2 and fpv controller 2. There was no major "tsunami" of complaints from Europe noticeable so I took the bet. Today I did a short test outside. And tadaaaah, everything is OK, there is nothing different to notice, even with FCC hack active there are neither warnings nor other problems.
So obviously nobody has to worry in Europe with this update. We will see what's next, if the EASA Remote ID is coming some day. If yes, dices will be rolling again.
2022-12-24
Jose Miguel Puech
Flight distance : 2314780 ft
Buena actualización,¿Quieres probarla?https://www.cursosdrones.com/nuevo-dji-fpv-avata/
2022-12-26
Ricardo Cerqueira
Portugal
SeehawerB Posted at 12-24 06:12
https://youtu.be/CTrk41JPWIo
Thanks a lot. I was waiting for some good feedback from europe. With the fcc hack did you needed to refresh de firmware or make reset in the googles like someone said before?
2022-12-26
Ricardo Cerqueira
Portugal
Ricardo Cerqueira Posted at 12-26 12:39
I just made all the firmware upgrade today, and what i found is that when you record in d-cinelike you have a lot of drops in MBps, is this supposed to happen? Only if you record in normal profile you get constant 50Mbps. Did a refresh firmware to the avata with the dji assistant 2, and also did a factory reset to the googles 2, reapplied the hack and nothing solves the issue with the d-cinelike signal. Any word on this? I found on reddit that other users are complaining the same.
2022-12-28
RichfromHowellNJ
Flight distance : 508255 ft
Sorry DJI for sounding negative here but the solution for Remote ID in having us tether our ourselves to our cell phone is a very poor solution to the US Requirement.  I think those of us in the USA should be offered another solution in order to meet the Remote ID requirement that the FCC has placed upon us.  Is there any chance a different solution is on the horizon?  This is a big step backwards for the pilot experience because now I have to worry about my battery on my iPhone.  Not good at all.
2023-1-9
SeehawerB
Ricardo Cerqueira Posted at 2022-12-26 12:39
No, I just upgraded, no reset. FCC still working.
2023-1-9
RichfromHowellNJ
JoeJK3D Posted at 2022-12-8 15:24
Yikes - the new RemoteID implementation does make things interesting... the need for the phone to be connected to take off and not see an error is another level of frustration... maybe we can get a small USB GPS Receiver to connect to the headset on its own?  no need for a phone then?
@JoeJK3D - I agree 100%.  Now I have to worry about does my iPhone have a full battery charge.  I also hate the fact that I'm tethered to my iPhone.  It is bad enough that I have a battery being tethered to the Goggles.  I can except that because the Goggles need power. I'm hoping that having to have our cell phone was a temporary bandaid to meet the FCC requirement in the USA and DJI will come up with an alternate solution that is much cleaner.
2023-1-9
RichfromHowellNJ
Killerbee Posted at 2022-12-9 07:58
Ok, I had some time to see what has changed for my Avata since the update.
I live in the EU, the Netherlands to be exact, and I updated all the Avata related gear yesterday. My goggles are the V2's and they have the FCC hack on them.
@Killerbee - "FCC Hack" - I found this .  Is this "FCC Hack" a way of getting around having to have my goggles connected to my cell phone in the USA?
2023-1-9
JoeJK3D
Flight distance : 618904 ft
RichfromHowellNJ Posted at 1-9 22:34
@Killerbee - "FCC Hack" - I found this link.  Is this "FCC Hack" a way of getting around having to have my goggles connected to my cell phone in the USA?
This is just for increasing the signal strength to the US FCC allowances for people outside the US.  This doesn't impact the RemoteID function which is a FAA regulated feature.
2023-1-10
RichfromHowellNJ
JoeJK3D Posted at 1-10 12:33
Okay thank you JoejK3D for the explanation.
2023-1-10
DroneBees
Flight distance : 6698159 ft
I am in Canada and I can't make the Remote ID error go away unless I have my phone plugged in the whole time. Are you planning on making the Remote ID part USA only or do I always have to have my phone plugged in from now on? It's super inconvenient to have another cable and have to make sure my phone is charged etc. etc.
2023-1-14
nickfs000
Flight distance : 1542746 ft
I live in the United States and have updated the firmware that requires me to plug in my phone in order for Remote ID to function. I am traveling to Mexico in a couple of weeks, am I going to have issues using my Avata if there is no Cell service or GPS service?
2023-1-15
fans17c4995b
Flight distance : 18832116 ft
nickfs000 Posted at 1-15 12:38
It doesn’t need any data connection, just uses the GNSS coordinates from the phone. You should be able to lock into GNSS sats when out in the open sky.
2023-1-16
TNRMQN
Flight distance : 36729 ft
Still no option to invert pitch on the right stick I know this has been a common request on other forums. Seems like a simple software fix to add the option of "invert" on certain sticks is all that is needed. Any word on that update?
2023-1-23
Elephant Apocalypse
Flight distance : 6336594 ft
I’m tempted , loss of the FPV drone from battery issue under current; hell flown dji with errors pretty much since started LOL. Plug and unplug with lots of good improvements seems like a good trade off, I do miss the avata
2023-1-29
123
