Delete this post pls
123
10019 92 2023-1-17
OldDrone1
OldDrone1 Posted at 2-4 07:26
This is the file I tried:
DJI-v4.3.14_190309-8-35864_dpad_sec.abk
And the bin file was GL300E_v1430_20200519.bin. I pulled these files from various places. I'd be happy to try another copy or something more current.
Thanks.
2-4 11:18
DJI Tony
OldDrone1 Posted at 2-4 07:23
I looked at your zip file and it looks like a bootable directory and not firmware file. Can you check the file please?
Hi. That is the firmware we are using to fix the map issue. You just need to import the file “update.zip” into the microSD card. (If the upgrade fails via an SD card, please copy the update.zip file to the internal memory of the remote controller and try to upgrade again). Power off the remote controller and insert the microSD card.  Power on the remote controller and then you will get a popup telling you that there is an update package found then tap “Install”.
2-5 00:10
djiuser_gjh6jvUmgUoN
Flight distance : 1079541 ft
Hi Ian having the same issues, could anyone help by sending a link to the update file? When I type the link provided by DJI Tony, it takes me to a ‘grand central access controller’ login page which require a login?
2-23 09:27
DJI Tony
djiuser_gjh6jvUmgUoN Posted at 2-23 09:27
Hi there. That link has already expired. I sent you a message. Please kindly check your messages. Please keep me posted. Have a great day.
2-24 00:49
djiuser_TIAMs9gpQ4AZ
Indonesia
Hai, saya juga mengalami hal yang sama, yaitu map yang tidak muncul pada remote control, apakah ada solusi dari masalah saya
3-22 08:47
DJI Paladin
Flight distance : 318 ft
djiuser_TIAMs9gpQ4AZ Posted at 3-22 08:47
Hi there. Thank you for reaching out and we do apologize for the inconvenience caused. Please confirm what specific drone and remote controller you are using so we can provide you with an accurate resolution. If you can upload a short video showing the issue that would be very helpful. We will wait for your response.
3-22 21:28
djiuser_Kr20vTG0bk1O
Flight distance : 331 ft
DJI Tony Posted at 2023-1-17 20:27
Hi, DroneHouse. Thank you for reaching out, and apologies for the inconvenience this has caused you. Our engineers have located this issue and it will be optimized in the next firmware update. In the meantime, we can provide you with firmware where the map s functional. We sent you a PM. Kindly check at your earliest convenience. Thank you, and have a nice day.
Hi Tony please could you send me the update file  am having the same problem with blank maps I have updated the firmware with the latest from Dji website and dji go 4 app and now the offline maps and just saying downloading all of the time and the Mapbox is blank just a black screen? Thank you
3-29 01:52
DJI Tony
djiuser_Kr20vTG0bk1O Posted at 3-29 01:52
Hi there: Here is the link you have requested: https://pan-sec.djicorp.com/s/RYG8R68Z3TbX8bw I hope this helps. This is only for GL300E remote controllers. Please follow the procedures below:
1.  Import the file “update.zip” into the microSD card.
Note: If the upgrade fails via an SD card, please copy the update.zip file to the internal memory of the remote controller and try to upgrade again.
2.  Power off the remote controller and insert the microSD card.
3.  Power on the remote controller and tap “Install”.
Please let us know if you encounter any issues. Have a great day ahead.
3-29 21:56
djiuser_xJ6L9JOTV2En
Flight distance : 609514 ft
Denmark
Have updated to the newest version, but the mapbox gets black, please help
4-29 07:14
Grumpy OldMan
I'd like to know how this even happens, and keeps happening???
How can an upgrade completely stop a previously fully functioning feature from working??? And get through testing to release?
I'm not expecting a DJI reply........
5-4 01:09
DJI Tony
djiuser_xJ6L9JOTV2En Posted at 4-29 07:14
Hi there. Thank you for reaching out. Have you already tried the instructions above on reply 88#? Please keep us posted so we can assist you further. Have a nice day.
5-4 03:32
ShawnRaper
I am also having the same described problem with no map data displayed and no ability to download map data.  I am using the GL300E remote with DJI Go 4 version 4.2.6 and firmware 1.04.03.  Any help will be appreciated.
5-10 15:56
DJI Tony
ShawnRaper Posted at 5-10 15:56
Hi there. Sorry about the trouble. Please follow the procedures above in reply 88# but use this link instead: https://pan-sec.djicorp.com/s/DkzFRTxQJdmEBje. Feel free to keep us posted. Thank you.
yesterday 02:24
123
