Pocket Extension Rod Not Returning to Home
554 5 2023-3-26
etiger
Hello- My extension pocket 2 does not return to its home (protected position) when I turn it off with the extension rod.  I have made sure I have to most recent firmware.  What else can I do or is this one defective?
Thanks!
2023-3-26
DJI Tony
Hi, etiger. Thanks for reaching out, and we're sorry you're experiencing such issues. To better isolate the issue, kindly post a short video showing the behavior of the device for further checking. We will be waiting for your update. Thank you, and have a good day.
2023-3-26
etiger
Sure, here you go.  Thanks!
https://photos.app.goo.gl/RzGZtujN9YbF3W6J6
2023-3-27
HGDC84
Finland
Mine is doing the same thing, not folding the gimbal position the way it does when using the Pocket 2 without an extension rod. I'm not sure if somebody thought it doesn't need to when used with the extension rod. So how is it DJI?
One question though, regarding the way the camera part points up at an angle. Are you sure your Pocket 2 is not in the Water-proof Case Mode when turning off? For me, it seems to shutdown in a similar way it does when that mode is activated. It can be turned off using the touchscreen when powered on, if it's enabled.
2023-3-27
etiger
Just checked, WP mode is not on.
2023-3-27
HGDC84
Finland
etiger Posted at 3-27 08:55
Okay, thanks for the update. We will see what DJI has to say about this then.
2023-3-28
