Skypixel Error
1703 21 2023-3-30
AlvaroRamalho
Flight distance : 161207 ft
Brazil
Hello everyone,
My DJI Fly app can't upload/share any photos or videos to my Skypixel Profile. When 98-99% give me an connection error and show the message to try again.
Do you have the same error?
How can I fix?
Thank you!
2023-3-30
Blériot53
Flight distance : 6188465 ft
It may be that the server is overloaded. Uploads to Skypixel are often very slow.  If you try again later, it may succeed.
2023-3-30
AlvaroRamalho
Brazil
Blériot53 Posted at 3-30 12:31
Thank you for letting me know.
BTW since I buyied my drone, I never can share any photos or videos at any time. I have the same error at all moments.
2023-3-30
Blériot53
AlvaroRamalho Posted at 3-30 12:53
Have you set up your account  (FREE) with Skypixel, first?
2023-3-30
AlvaroRamalho
Brazil
Blériot53 Posted at 3-30 12:56
Yes! I did
2023-3-30
AlvaroRamalho
Brazil
I'm only able to share photos by PC
2023-3-30
Blériot53
Hopefully it will only be a matter of time. Good luck
2023-3-30
AlvaroRamalho
Brazil
Blériot53 Posted at 3-30 13:00
Thanks for the help!
2023-3-30
Blériot53
One tip which may help you.
If the Site keeps trying to load constantly and looks "Stuck" copy the address line and try opening it in another tab, or webpage. That sometimes works.
2023-3-30
DJI Gamora
Hi, AlvaroRamalho. Thank you for reaching out. Please try the following steps below:
1. Ensure that the connected wireless network is functioning and stable, and avoid using networks that require two-step verification. If the Wi-Fi signal is weak, it is recommended to upload photos/videos using the Internet connection shared via a hotspot on your mobile phone (please focus on traffic consumption when using mobile hotspots).
2. Login with your account and try again.
3. It is recommended to upload a video with a shorter duration or a photo with a smaller size to conduct cross-tests and check whether the video/photo can be uploaded successfully and quickly. If only video/photos with a large size upload slowly, we recommend waiting patiently until the uploading is finished.
Please keep us posted. Thank you.
2023-3-30
AlvaroRamalho
Brazil
DJI Gamora Posted at 3-30 18:24
Hi DJI Gamora!
1 - I tryed different wifi connections and I have the same error at 98-99%
2 - I will logout and login and try again
3 - Photos with Small or Big size give me the same error
2023-4-1
AlvaroRamalho
Brazil
I made an logout and login. Shows the same connection error.
2023-4-1
DJI Gamora
AlvaroRamalho Posted at 4-1 12:46
I made an logout and login. Shows the same connection error.[view_image]
Hi, AlvaroRamalho. Thank you for the update and we're sorry to read that you're still having the same issue. We have forwarded your concern to our relevant team for further checking. We will let you know if they need more information. Thank you for your kind understanding.
2023-4-1
AlvaroRamalho
Brazil
DJI Gamora Posted at 4-1 22:20
Thank you!
I will give any information they need!
I will be waiting for a feedback!
2023-4-2
DJI Gamora
AlvaroRamalho Posted at 4-2 07:03
Thank you!
Hi, AlvaroRamalho. Thank you for patiently waiting. We now received feedback from our relevant team. Please try the following steps below:
1. Please make sure the material being uploaded is not greater than 500M and the generated should not exceed 10 minutes if you upload from the mobile end. From the App end: The file size to be uploaded cannot be greater than 500M, and there is no requirement for the duration, but the video generated by the editor cannot exceed 10 minutes, so the duration of the uploaded video is also within 10 minutes
2. Please double-check check the wi-fi you are using if it is working normally as per the screenshot, it seems that there is a network connection issue.
3. Please make sure the app has been updated to the latest version then have a try.
If the issue still persists, please provide us the app version, video operation showing the issue (including the material size, network checking, and the whole uploading process), material footage wish to be uploaded, app log, and tested time for further checking. Please keep us posted. Thank you.
2023-4-3
AlvaroRamalho
Brazil
DJI Gamora Posted at 4-3 01:10
Hi DJI Gamora!
I’m still having problems to upload photos.
Here’s my app version, connection’s speed and one of The photos
https://youtu.be/VXpavHg7UI0
In this video you Will see different photos with The sane error and The respective size.
As you can see The photo’s size is around 5MB
2023-4-3
DJI Gamora
AlvaroRamalho Posted at 4-3 04:27
Hi DJI Gamora!
Hi, AlvaroRamalho. Thank you for providing these details. I have forwarded them to our relevant team for checking. I'll let you know once we receive an update.
2023-4-5
AlvaroRamalho
Brazil
DJI Gamora Posted at 4-5 20:01
Hi DJI Gamora!
Thank you! I’ll be waiting!
Best regards!
2023-4-6
DJI Gamora
AlvaroRamalho Posted at 4-6 04:20
Hi DJI Gamora!
Hi, AlvaroRamalho. We have sent you a PM regarding this. Can you please confirm if you have received it? Please keep us posted. Thank you.
2023-4-24
AlvaroRamalho
Brazil
DJI Gamora Posted at 4-24 01:57
Hi DJI Gamora! I sucessfully uploaded a photo and a video to Skypixel via DJI Fly app! The problema is fixed!!!
2023-4-24
DJI Gamora
AlvaroRamalho Posted at 4-24 02:35
Thank you for the update, AlvaroRamalho. Glad that it has been uploaded now. Should you need further assistance, please don't hesitate to reach us here at DJI Forum.
2023-4-27
djiuser_z8aJtfnzc7rO
Vietnam
Bé g20951123
4-23 04:11
