djiuser_NLF8s6Io04Dx
Flight distance : 15358 ft
A post script in case anyone else has the same or similar problem. I eventually had a series of communications with DJI tech engineers who took all the details and after considering it, suggested I return the unit for repair.
However, I had the chance of trying an X7 camera before sending the drone off. Lo and behold, the X7 caused the drone to record PPK file data where previously there was none.
So, the Matrice 210 RTK will do RTK using the X5 camera, but will not do PPK, even though the data has to be passing through the device - for whatever reason, it doesn't get recorded.
The solution is to spend another £2000 to £3000 on an X7 camera, and of course a new set of lenses as the X5 and X7 have a different lens format.
I am rather surprised that the camera should make the difference, but perhaps even more surprised that DJI engineers appear not to know this, or for the information not to be available anywhere. |
