Broke remote after Firmware update
1397 8 2023-6-15
babybang
Belgium
Hi,
My DJI RC-N1 for my  DJi Mavic Air 2 just completely died after i updated the firmware.
the Remote turned in to a brick, doesn't charge or turn on.
What can DJi do sins it's clearly the firmware update that caused this, been reading that i'm sadly not the only person this happened to (google youtube etc).
2023-6-15
TonyPHX
Flight distance : 11229610 ft
Before you throw in the towel, have you tried to see if Assistant 2 from PC or Mac can address the RC-N1?
If not, download Assistant 2 for Consumer Series, then plug a usb-c cable from the computer into the bottom USB port of the RC-N1. If you can see the device, you may be able to do a refresh or upgrade and reload the firmware.
2023-6-15
Hi there, we are sorry to know about this issue. Could you please test it with another cable/charger to see if the LED will turn on when charging? If not, you can submit a case through the link below and send it back for further diagnosis. http://www.dji.com/support
2023-6-16
babybang
Belgium
TonyPHX Posted at 6-15 21:18
thanks for your reply! i tried everything you mentioned to no avail.
2023-6-17
TonyPHX
babybang Posted at 6-17 23:17
Oh man, well, it sounds like it is time for a trip to the service department.  Good luck and hope you are back in the air soon!!
2023-6-18
djiuser_0UoQmwTg7wxt
Philippines
same happened today, how in the hell they are not getting sued for killing off RCs which cost hundreds of dollars
2023-12-17
DJI Tony
A
djiuser_0UoQmwTg7wxt Posted at 12-17 01:34
Hello there. If I may ask, have you already tried charging the remote and does it light up? And can you please confirm if it is completely powerless and not just a black screen? If you can turn it on but show a black screen, please press and hold the power button for 15 seconds to force power off the remote. If the issue persists please try refreshing the firmware using the DJI Assistant 2. Thank you.
2023-12-17
Alessia and Lee
Flight distance : 52 ft
Same here, updated the flight path and it fried my RC. Out of warranty but it's DJI's fault.
1-15 07:03
DJI Diana
Flight distance : 2408 ft
Alessia and Lee Posted at 1-15 07:03
Hi. I apologize for the inconvenience caused. I replied to you in the other post. Here's the link Please check. Thank you.
1-15 14:55
