Remote ID Statement (07/01/2023)
104922 373 2023-6-30
Monkeyboy
Flight distance : 31545 ft
Question is to the manufacturer DJI, "When will you submit a declaration of compliance to the FAA for their approval", for the Mavic Air 2?
Even with an up-to-date firmware load your drone is not compliant until it has an FAA-approved declaration of compliance on the website.
2023-10-17
DJI Gamora
Monkeyboy Posted at 10-17 07:41
Hi, Monkeyboy. Thank you for reaching out. We apologize for the inconvenience caused. Rest assured that the Mavic Air 2 supports FAA RID requirements from the firmware version V01.01.16.00, while it takes time to have this update on the FAA Official Website due to the changes in the format of the materials required by the FAA to apply for RID compliance. DJI is actively communicating with the FAA in a timely manner, and it is expected that  Mavic Air 2 will be announced on the FAA website soon. Thank you for your understanding and support.
2023-10-18
Monkeyboy
DJI Gamora Posted at 10-18 21:41
Hi, I appreciate you reaching out with an answer to my question.
Thanks,
2023-10-19
djiuser_4DAJht8kvPQC
I'll believe DJI's software upgrade WHEN I see it!!
2023-10-20
DJI Gamora
Monkeyboy Posted at 10-19 07:27
Thanks,
You're most welcome, Monkeyboy. Please don't hesitate to reach us if you have any inquiries or concerns. Thank you for your valued support.
2023-10-21
Jacektfc
Flight distance : 4819055 ft
Poland
What about DJI o3 air unit ?
2023-10-22
DJI Gamora
Jacektfc Posted at 10-22 02:41
Hi, Jacektfc. Thank you for reaching out. The DJI O3 Air Unit does not have a built-in GPS module, so it does not support this function.
2023-10-22
WFM
Responding for points......
2023-10-23
BenVCarlson
Belgium
Hi, I couldn't decode the S/N of my Mini 3 Pro using this tool (14 chars allowed, my S/N is 20 chars long ???) but found a date printed on the box saying 2022/08
I guess this is then the manufacturing date of the device ...August 2022...
Would this explain why, despite up-to-date firmware, I can't see any RID broadcast from the device, as per this discussion only devices manufactured after sept. 16, 2022 have RID support ?
It is not entirely clear to me if MP3's manufactured after 09/16 have "built-in" RID support because they ship with up-to-date firmware implementing RID or because they have the necessary hardware to implement it; IOW is updating the firmware on pre-09/16 devices sufficient to implement RID ? Or is RID support hopeless on these older units because they lack some hw ?.... (I do need RID in my area despite being EU "Class C0") see also this discussion)
2023-10-24
djiuser_LRNt9UYEE9dB
This sucks know I have to plug my headset up t to my phone  to the dji fly app ever time I want to fly. This sucks, Thanks alot Dji. This sucks
2023-10-24
Bischi999
Flight distance : 58661 ft
Switzerland
Hello everyone.
I'm from Switzerland and will be on vacation in Florida in mid-November.
I have a Mavic Air2 with a smart controller and have made the latest updates.
( App 1.12.2 / Aircraft 01.01.1600 / Controller 01.01.0072 )
Unfortunately there is no option to enter the remote ID in the Smartcontroller.
Has anyone already done it and can help me?
Or is that only possible when I'm in the USA?
Best regards Michael
2023-10-25
fansdd51741e
Flight distance : 33199 ft
I have a mavic air is this not the same thing as remote Id it seems promising but I don’t think it’s doing anything it says remote Identification I tried to add photo
2023-10-25
BenVCarlson
Belgium
BenVCarlson Posted at 10-24 04:10
Dear DJI,
can you please confirm that for a Mini 3 Pro manufactured before 09/16 (2022), a firmware update is enough to implement Remote ID functionality ?
(and that if my up-to-date M3P doesn't broadcast anything, it's a device malfunction ?)
Thank you
2023-10-25
DJI Gamora
BenVCarlson Posted at 10-25 23:16
Dear DJI,
Hi, BenVCarlson. Thank you for reaching out. Can you please confirm if this is for USA FAA Remote ID? If yes, the Mini 3 Pro supports FAA RID requirements with the factory firmware version. The FAA RID will only be broadcasted once you're in the USA. Hope this helps.
2023-10-26
BenVCarlson
Belgium
DJI Gamora Posted at 10-26 02:51
No, it's for the EU
The EU regulation do not require Remote ID for Class C0 UAS, HOWEVER the CTR where I used to fly adds its own requirement that mandates Remote ID for any UAS flying in category Open A1 regardless of the Cx class, as from 01/01/24
See https://forum.dji.com/forum.php? ... 559&pid=3156906
2023-10-26
djiuser_PegXocQnhxep
Any updates or time estimates for phantom 4 pro v2.0 compliance?? Where is DJI in this process? Is it DJI or FAA that is holding up the compliance declaration at this point?
2023-10-28
loflybyP4
Thank you for this information. Is the DJI O3 Air Unit coming with built-in remote ID capabilities? If not, is it planned to have it via software updates?
2023-10-28
loflybyP4
Pete Toemmes Posted at 7-5 16:22
How is DJI handling flying a remote ID compliant drone indoors when GPS and/or tethered smart device location services (GPS) is unavailable?
An unifiable brick is not an acceptable answer
You don't need RID indoors. Technically, you are not inside the NAS.
With that being said, it becomes a grey area when you are flying commercially inside a stadium for example, where the building is partially covered with a roof.
2023-10-28
DJI Gamora
BenVCarlson Posted at 10-26 08:21
No, it's for the EU
See https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=299559&pid=3156906
Hi, BenVCarlson. Thank you for the clarification. As of this writing, the Mini 3 Pro does not support Remote ID in the EU region.
2023-10-29
DJI Gamora
djiuser_PegXocQnhxep Posted at 10-28 06:10
Hi, djiuser_PegXocQnhxep. Thank you for reaching out. For Phantom 4 pro v2.0, firmware upgrade with RID compliant will be available by December 31, 2023 at the latest.
2023-10-29
DJI Gamora
loflybyP4 Posted at 10-28 13:20
Hi, loflybyP4. Thank you for reaching out. The DJI O3 Air Unit does not have a built-in GPS module, so it does not support this function.
2023-10-29
BenVCarlson
Belgium
DJI Gamora Posted at 10-29 03:56
Thank you
And....is there any chance to see this support added in a not too far away future via a firmware update ?
(Otherwise I'll have to resell the unit ASAP (before people overhere realize this model is no longer allowed to fly in large portions of the territory after 01/01/24 due to CTR requirements))
2023-10-30
Jacektfc
Poland
What about DJI o3 airunit ?
2023-11-5
DJI Wanda
Jacektfc Posted at 11-5 12:50
Hello, there. You may refer to DJI Gamora's reply.
https://forum.dji.com/forum.php? ... 343&pid=3165235
2023-11-6
ReiTumber
What about the Phantom 4?
2023-11-15
mgphoto
Flight distance : 2906398 ft
We received the RID update for the Mavic 2 Enterprise Advanced a month ago but I still don’t see the UAS Declaration of Compliance listed with the FAA.
Is there a tracking number associated with the declaration?
2023-11-16
Monkeyboy
Any announcement of when the Mavic Air 2 will be on the FAA website as compliant?
I know you said this is in the works, but the firmware was downloaded around Sept. 27th. this year.
So, I cannot register as compliant until this shows up on FAA as compliant....
I hope any day...
2023-11-16
UAViator53
Flight distance : 692090 ft
Any updates for the Phantom 4 Pro v2.0 yet?
2023-11-19
djiuser_a5L8LdyWVCgW
Flight distance : 111214 ft
My Air 2 did not receive the remote id update. I have 01.01.1600 firmware but does not indicate remote id
2023-11-19
DJI Susan
djiuser_a5L8LdyWVCgW Posted at 11-19 18:24
Hi there, the firmware V01.01.16.00 is the latest version for Mavic Air 2 to support FAA RID. Please also make sure to update the DJI Fly app as well. Thank you.
2023-11-19
DJI Gamora
Monkeyboy Posted at 11-16 21:50
Hello, there. We're sorry that we haven't received any information related to this matter. Please stay rest assured that we're continuously working on this situation. We thank you for your understanding.
2023-11-20
ReiTumber
Is the DJI Phantom 4 receiving the update or is it too old?  I just want to know before buying a remote ID device.
2023-11-20
DJI Susan Posted at 11-19 22:23
Thanks, I got it to work. Did not work on and older Android version.
2023-11-23
DJI Gamora
djiuser_a5L8LdyWVCgW Posted at 11-23 13:10
Thank you for the update. We're glad that everything has been sorted out! Please feel free to reach us anytime.
2023-11-23
fansfdb11483
Flight distance : 154 ft
What is the status for the original Mavic Air?
2023-12-4
DJI Susan
fansfdb11483 Posted at 12-4 08:06
Hi there, we are sorry that there is no firmware update for RID compliance for Mavic Air. We encourage you to consider purchasing a separate broadcast module to ensure compliance with remote ID regulations. Thank you for your understanding.
2023-12-4
DJI did in fact release an upgrade for the Mavic Pro 2, I think the date was 11/23/2023, so they met their deadline. Major problem: at last check (12/4/2023) DJI does NOT have an official DOC on file with the FAA. It is highly questionable whether the upgrade is legal. So far (12/5/2023) neither DJI nor the FAA has commented.
2023-12-5
TVeyeGuy
Flight distance : 11719 ft
Will there be a firm ware update for the Phantom 3 Standard or will it be able to use the Phantom 4 update when available?  If no firm ware update, is there an add on module capatible for the Phantom 3?
Thanks in advance
2023-12-5
Nafisgal
Flight distance : 3726460 ft
Will this firmware update make the M2P no longer able to be piloted with the DJI Pilot flight app?
2023-12-9
H4 Services
Flight distance : 2620623 ft
Are there plans to make the Inspire 2 Remote ID compliant in the US?
2023-12-10
