DJI Gamora
Hi, Feizhuthegreat. Thank you for reaching out. Flight logs can be viewed using the software called DJI Assistant 2 (Consumer Drones Series). You may download it from this link. After downloading, just connect your drone to your PC/laptop using a USB cable then follow the instruction for the first time setup. The flight Logs are .DAT files that are under Log export. |
