DJI Thor
Flight distance : 13602 ft
Yaman-Python Posted at 8-8 23:17
Hi Thor, thank you for looking into this.
I do not have comparison footage with OA3, just some OA4 footage. If they can be useful, I can make some of them available, though I do not think the problem is in the footage themselves but in the display or the power supply (see last comment below).
Below is a video showing how the display behaves outdoors and indoors. Clearly too dark to be normal.
Hi Yaman-Python, thank you for your reply. We forwarded the video to our engineer for check. Meanwhile, please no worries, we could find your case number and left a note there to let the corresponding team to know more background. Thanks.
For the battery issue, please know that Osmo Action 4 can shoot 4K/120fps videos at a bit rate of up to 130 Mbps, and the actual video file generated in one minute can be as large as 900 MB. With its compact and portable design, Osmo Action 4 inevitably dissipates heat when processing such a large amount of data in a short period of time, which is an irresistible physical law. The camera was designed with special attention to the heat dissipation issue. To ensure the normal performance of the camera, the internal heat is designed to be conducted to the lens cover, front and rear screens, and body itself through heat sinks and silicone grease. Additionally, we have made the strict tests to ensure that the camera temperature is within a reasonable range during long-term recording. |
