LV_Forestry
Flight distance : 4726654 ft
Latvia
In the morning when I wake up I start by giving him a kiss, saying sweet words to him.
Before the flight I say a prayer.
During the flight i cross finger.
After the flight i check if all files are there, LDR, RTK (the two most important), in total there must be 8 files + 1 RTB if NTRIP + 3 bin and MRK.The LDR file must have a substantial volume depending on the mission. Dot density vs flight time.
Then i put the RTK file in RTKLib (RTKconv), under RTCM3 format. The process takes a few seconds and validates the file. This is the one that causes the problem in 99% of cases.
On this one everything is fine:
On this one you have to redo the flight :
If you have no more battery you put yourself in the fetal position and you try to make sense of things.
You can even go further by checking the base OBS (or RTB) file with RTKconv.
