kamildrone
Poland
CloudVisual Posted at 10-21 04:47
Ok, that explains a lot then. Absolutely nothing wrong with that footage.
You are essentially complaining that the 28x zoom shows a tiny bit of shake, which is just a magnified version of the x7. The shake in the x28 is also there in the x7, you're simply magnifying it.
thanks for your answer, please look at the recording carefully. on x28 you can clearly see image shakes, on x7 there are none, but look further - I enlarge the material from x7 in Premiere Pro x 400% (to make it more or less the same scale as the one from x28) - and there are no shakes here either. i.e. in the clean x7 recording there are no vibrations in the drone, only when we select x 28 the vibrations are added - as if something had broken down in the hardware. my old drone had no such problems, everything was smooth. |
