BroomRider
Flight distance : 1262136 ft
So, prior to this most recent firmware update for the Mini 4 Pro, regarding the RID signal transmission, it was functioning the same as the Mini 3 Pro?
When will the Mini 3 Pro receive a similar firmware update, so when flying with the standard intelligent battery, it won't be automatically broadcasting an RID signal?
Please take note of my previous reply with the recommendation that, for the benefit of both non-commercial recreational & Pt.107 commercial pilots, the ability to switch off or on, respectively, the RID signal transmission, when using the standard battery & flying a UAV weighing <250gms.
Please also note that UAVs <250gms flying under the non-commercial recreational exemption, are not required to transmit the ROD signal, as stated in the FAA requirements description.
Thank you for your thoughtful consideration! |
