LV_Forestry
Flight distance : 4726654 ft
Latvia
Mike from NL Posted at 10-10 06:41
The problem seems to be that the actual rule about the 120m is contradicting in the different documents... In another post it is very nice depicted: The text on the eu-lex states 120m above take-off point, whereas the EASA site states above ground level. See https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=298368&pid=3140765
"the actual rule about the 120m is contradicting in the different documents"
On users side, the general rule is 120m AGL. In certain cases it is less, close to airports, prisons...
2019/947 EUR-Lex - 32019R0947 - EN - EUR-Lex (europa.eu)
Using the analogy with road rules, this corresponds to the 130km/h limit that you mention.
On manufactuers side, To obtain a C1 label and above, they are required to limit the altitude or clearly inform the user.
There is a special case, that of C0 drones which are small drones <250g, usable without the need to take the online exam. This category C0 and only this one is constrained to 120m from the take-off point.
2019/945 EUR-Lex - 32019R0945 - EN - EUR-Lex (europa.eu)
To use the Road code analogy again, a car without a license is generally limited to 45km/h. And it is not because you have the B license that you are entitled to remove the restriction which limits the speed of the vehicle.
"Who is responsible for abiding to the law?"
It is DJI who, if it wishes to place a drone with the C0 label on the European market, must present a product that complies with the requirements of this category.
"I think the warning option, AND the information about my height above take-off point, would be sufficient for me to make an informed choice on my flight altitude."
This is what is in force for C1 and above. Only C0 is affected by this limitation at 120m from the take-off point.
