Guide: Phantom 3 Firmware 1.4.0010/1.1.0030 Update
1234Next >
153022 132 2015-9-7
quasimodo
Malaysia
tq very much for the detail guide thru. here's my problem. i've done this update bfore reading ur post.
1st i update the firmware. done. read the log file it says success.
2nd i tried to update the controller but nothing happened no blue light appear only green. i opened up the log file there is no log file. after i read ur post yes no need to upgrade the controller version.
3rd. i on the controller on the craft. open DJI Go. to confirm my update i checked it in the about menu...it says controller 1.3.20.......craft 1.4.0010.....dji go 2.10. everthing is correct.
so i try to get the intelligent flight mode i couldn't get. i have switch to f mode also nothing happen. but i can get the 2.7K resolution. so its the intelligent mode that i want...but its not there.
2015-9-8
heyandy
Flight distance : 413009 ft
Just upgraded my Phantom 3 Pro.  Curious, did anyone else notice that the gimbal mount got nice and warm?
2015-9-8
alirz1
Flight distance : 609833 ft
Has anyone come across this?  https://play.google.com/store/ap ... .djiultimateflight3
Beta firmware and that app ( DJI Ultimate flight) allows several good features INCLUDING offline waypoints and other features. What's the deal? If the beta firmware allows it then how come its disabled in the latest public release by DJI?
2015-9-8
HOHLV
Flight distance : 3114 ft
heyandy Posted at 2015-9-9 07:52
Just upgraded my Phantom 3 Pro.  Curious, did anyone else notice that the gimbal mount got nice and  ...
Yes. Got the same problem, also the 4 motors got a bit hotter than the older version.
2015-9-9
renpal2173
My husband owns the P3 standard and I hope I'm reading right that you can get these new features like the follow me through the APP and thats why for 1 day they had the firmware on the website and then they pulled it down. He is furious at the moment thinking that they promised these features for the P3 standard and now they are not giving them.
2015-9-9
sploodge
Flight distance : 809350 ft
renpal2173 Posted at 2015-9-9 15:28
My husband owns the P3 standard and I hope I'm reading right that you can get these new features lik ...
You do the P3 Standard firmware from the App, they pulled the firmware, can only assume its because the app does the update )
2015-9-9
renpal2173
thanks for responding and I hope when he gets home he'll know how to do this. I'm not familiar with the app at all, he's been doing everything. I just looked into these forums bc I saw how upset he was that he thought he wasn't getting the new features. I really hope he can figure it out. He's so excited about he follow me feature, he'll be devastated if its not for P3 standard
2015-9-9
renpal2173
sploodge Posted at 2015-9-9 09:30
You do the P3 Standard firmware from the App, they pulled the firmware, can only assume its becaus ...
do you know if the copter will be messed up now that he installed the firmware that was there on the website 1.1.30? he put the sd card in the camera slot but nothing happened. it was waiting for you to fly like you did nothing to the copter. he's hoping he didn't mess anything up by doing the download. thanks for being patient!!!lol
2015-9-9
gr8pics
Flight distance : 5365522 ft
Norway
Problem updating the transmitter, nothing happens when i turn it on with the usb stick in, its the same stick i use for upgrade everytime.
Update via app is not available.
P3 has successfully been updated to 1.4, and the app to the latest version.
Any suggestions?
2015-9-9
gr8pics
Norway
Do you need to press the radio power button in special way? Dont remember from last time, says nothing the the document file...
2015-9-9
sploodge
renpal2173 Posted at 2015-9-9 17:59
do you know if the copter will be messed up now that he installed the firmware that was there on t ...
Will be fine after being updated using the firmware file from DJI website..
Worth checking the "About" section of the app to see the version of firmware. Some have received their P3 Standard already updated.
2015-9-9
Stealth...
Bosnia and Herzegovina
Thanks sploodge for this guide. Keep up the good work!
2015-9-9
renpal2173
sploodge Posted at 2015-9-9 12:26
Worth checking the "A ...
so glad to say its working...thank you so much for your advice. He is so happy to have follow me and home lock/course lock. He wants to know when you should format your SD card? does that mean to clear it? would you do this after you transfer to your computer?
2015-9-9
hig
THANK YOU,
I watched your video's and followed them step by step and it was a breeze,  thank you
2015-9-9
danwahoo
heyandy Posted at 2015-9-8 17:52
Yes. I am in the process of updating and my gimbal mount is very warm.
On another note, I'm at ~40 minutes since inserting my SD card for the firmware update. Aircraft still in process of updating... should I be worried?
EDIT: I had moved my aircraft at ~33-35 minutes and did not check the light for 5 minutes or so. Light was green, log successful. Will update if further issues:
========== 2015.09.09 19:30:08 =====================
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
2015-9-9
danwahoo
danwahoo Posted at 2015-9-9 20:10
On another note, I'm at ~40 ...
Here is a question. I plan on upgrading SD card size in the following days. I only have the 16GB that came with the aircraft. Do I need to do this update again? Or simply copy bin file/text file to new SD card?
Update successful. Managed to figure out how to switch flight modes, access Follow Me. Then I started running down the street and this drone started following me
2015-9-9
yogi
Good work on this post mate.
Thanks
yogi
2015-9-9
quasimodo
Malaysia
it seems nobody assist to my problems..anyway...i knew that my firmware was successful but yet can't excess the intelligent flight because i need to hover the craft above ground and switch to F mode and it worked!!!!! but when i land...dji go some how wont let me see the intelligent flight menu. even the logo itself didn't appear. my dji go is version 2.1. i think version 2.0 can excess intelligent flight modes when on ground. i hope these help others with same issue as mine.
2015-9-9
info.filmtwist
1 - Phantom 3 Professional
2.- IOS latest version
3 - iphone 5S
4 - On the first two try it shows upgrading, but now it is always showing as failed.
Basically tried doing the new update and it keeps on failing. Have followed the steps and basically when i put SD card into camera then it starts out alright but after about 5 minutes get the long sound that it has failed. Something else i noticed now is that i cannot connect with the camera directly at all from controller. So i am not able to reformat card in camera.
Have tried two different micro SD cards including original SD card. Tried swapping out battery and waiting...just not working
Please help!
2015-9-10
Nailobi
thank you for the post
2015-9-11
sploodge
info.filmtwist Posted at 2015-9-11 00:00
3 - iphone 5S
On the SD card there is a hidden folder called /MISC/LOG - In here is a TXT file, can you post the contents of this file please..
2015-9-11
info.filmtwist
sploodge Posted at 2015-9-11 02:14
On the SD card there is a hidden folder called /MISC/LOG - In here is a TXT file, can you post the ...
[00014248][01 00] Firmware upgrade finished successfully.
[00014357]Done.
[00014394]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x6acbdcfb].
[00014437]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014500]Version checking[2]...
[00014580][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014659][03 06][00] v2.1.6.18 -> v2.2.6.19 need upgrade.
[00014701][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014763][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014880][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014968][12 00][00] v1.8.0.0 -> v1.8.0.0
[00015048][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015133][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015213][12 03][00] v1.8.0.0 -> v1.8.0.0
[00018070][15 00][00] device not detected.
[00018153][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00018265][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00018323][19 00][00] v1.0.8.96 -> v1.0.8.96
[00018361][01 00][05] v1.23.3419 -> v1.23.3419
[00018397][01 01][00] v1.6.2736 -> v1.23.3419 need upgrade
[00018453][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00018487]Done.
[00018522]Firmware upgrading[2]...
[00018676][01 01] Firmware upgrade start...
[00048937][01 01] Firmware upgrade finished successfully.
[00049850][08 00] Firmware upgrade start...
[00592455][08 00] Firmware upgrade finished successfully.
[00592524][17 00] Firmware upgrade start...
[00716708][17 00] Firmware upgrade finished successfully.
[00716760][17 01] Firmware upgrade start...
[00786471][17 01] Firmware upgrade finished successfully.
[00786519][11 00] Firmware upgrade start...
[00834446][11 00] Firmware upgrade finished successfully.
[00834691][03 06] Firmware upgrade start...
[01150517][03 06] Firmware upgrade finished successfully.
[01150582][04 00] Firmware upgrade start...
[01208557][04 00] Firmware upgrade finished successfully.
[01208592]Done.
[01208629]Version checking[3]...
[01208715][03 05][00] v34.2.0.9 -> v34.2.0.9
[01208795][03 06][05] v2.2.6.19 -> v2.2.6.19
[01208839][04 00][05] v1.40.0.0 -> v1.40.0.0
[01208992][09 00][00] v1.7.0.3 -> v1.7.0.3
[01209152][11 00][05] v1.7.0.0 -> v1.7.0.0
[01209242][12 00][00] v1.8.0.0 -> v1.8.0.0
[01209333][12 01][00] v1.8.0.0 -> v1.8.0.0
[01209433][12 02][00] v1.8.0.0 -> v1.8.0.0
[01209520][12 03][00] v1.8.0.0 -> v1.8.0.0
[01212564][15 00][00] device not detected.
[01212641][17 00][05] v1.1.1.7 -> v1.1.1.7
[01212766][17 01][05] v1.0.2.7 -> v1.0.2.7
[01212830][19 00][00] v1.0.8.96 -> v1.0.8.96
[01212869][01 00][05] v1.23.3419 -> v1.23.3419
[01212904][01 01][05] v1.23.3419 -> v1.23.3419
[01212953][08 00][05] v0.12.0.4 -> v0.12.0.4
[01212991]Packet upgrade failed at version checking.
[00012484]========== remo-con disconnect. boot(15) ============
[00012527]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x6acbdcfb].
[00012565]Packet upgrade start...
[00012623]Packet checking...
[00012658]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012734]Done.
[00012772]Version checking[1]...
[00012844][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012929][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012973][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013028][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013148][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013250][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013333][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013424][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013524][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013672][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013753][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013873][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013929][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013967][01 00][00] v1.23.3419 -> v1.23.3419
[00014011][01 01][00] v1.23.3419 -> v1.23.3419
[00014067][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014110]Packet upgrade cancelled at version checking.
[00012462]========== 2015.08.22 22:48:42. boot(15) ============
[00012503]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x6acbdcfb].
[00012540]Packet upgrade start...
[00012586]Packet checking...
[00012629]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012758]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012792]Done.
[00012832]Version checking[1]...
[00012907][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012986][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013040][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013091][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013207][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013302][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013381][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013481][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013556][12 03][00] v1.8.0.0 -> v1.8.0.0
[00016679][15 00][00] device not detected.
[00016773][17 00][00] v1.1.1.7 -> v1.1.1.7
[00016916][17 01][00] v1.0.2.7 -> v1.0.2.7
[00016972][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017013][01 00][00] v1.23.3419 -> v1.23.3419
[00017049][01 01][00] v1.23.3419 -> v1.23.3419
[00017096][08 00][00] v0.12.0.4 -> v0.12.0.4
[00017135]Packet upgrade failed at version checking.
[00012770]========== remo-con disconnect. boot(15) ============
[00012807]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x6acbdcfb].
[00012848]Packet upgrade start...
[00012888]Packet checking...
[00012926]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012962]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013001]Done.
[00013039]Version checking[1]...
[00013108][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013188][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013233][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013293][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013408][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013500][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013574][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013663][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013744][12 03][00] v1.8.0.0 -> v1.8.0.0
[00022382][15 00][00] device not detected.
[00022455][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022578][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022634][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022672][01 00][00] v1.23.3419 -> v1.23.3419
[00022721][01 01][00] v1.23.3419 -> v1.23.3419
[00022767][08 00][00] v0.12.0.4 -> v0.12.0.4
[00022875]Packet upgrade failed at version checking.
[00012784]========== remo-con disconnect. boot(15) ============
[00012820]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x6acbdcfb].
[00012859]Packet upgrade start...
[00012923]Packet checking...
[00012964]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013002]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013041]Done.
[00013080]Version checking[1]...
[00013162][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013227][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013274][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013352][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013463][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013543][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013633][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013717][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013797][12 03][00] v1.8.0.0 -> v1.8.0.0
[00022433][15 00][00] device not detected.
[00022513][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022633][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022693][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022730][01 00][00] v1.23.3419 -> v1.23.3419
[00022770][01 01][00] v1.23.3419 -> v1.23.3419
[00022828][08 00][00] v0.12.0.4 -> v0.12.0.4
[00022864]Packet upgrade failed at version checking.
[00012782]========== remo-con disconnect. boot(15) ============
[00012822]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x6acbdcfb].
[00012863]Packet upgrade start...
[00012924]Packet checking...
[00012965]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013005]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013048]Done.
[00013092]Version checking[1]...
[00013159][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013223][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013267][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013330][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013440][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013514][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013589][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013680][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013780][12 03][00] v1.8.0.0 -> v1.8.0.0
[00022512][15 00][00] device not detected.
[00022591][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022710][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022770][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022812][01 00][00] v1.23.3419 -> v1.23.3419
[00022852][01 01][00] v1.23.3419 -> v1.23.3419
[00022899][08 00][00] v0.12.0.4 -> v0.12.0.4
[00022939]Done.
[00024979]Waiting for user confirm...
[00035018]Timeout, start upgrade automatically.
[00035093]Firmware upgrading[1]...
[00035156][11 00] Firmware upgrade start...
[00083059][11 00] Firmware upgrade finished successfully.
[00083095]Done.
[00083138]Version checking[2]...
[00083203][03 05][00] v34.2.0.9 -> v34.2.0.9
[00083263][03 06][00] v2.2.6.19 -> v2.2.6.19
[00083310][04 00][00] v1.40.0.0 -> v1.40.0.0
[00083394][09 00][00] v1.7.0.3 -> v1.7.0.3
[00083504][11 00][05] v1.7.0.0 -> v1.7.0.0
[00083595][12 00][00] v1.8.0.0 -> v1.8.0.0
[00083678][12 01][00] v1.8.0.0 -> v1.8.0.0
[00083783][12 02][00] v1.8.0.0 -> v1.8.0.0
[00083878][12 03][00] v1.8.0.0 -> v1.8.0.0
[00012759]========== remo-con disconnect. boot(15) ============
[00012799]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x6acbdcfb].
[00012839]Packet upgrade start...
[00012902]Packet checking...
[00012943]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012983]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013024]Done.
[00013067]Version checking[1]...
[00013134][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013213][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013261][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013318][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013434][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013530][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013630][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013709][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013784][12 03][00] v1.8.0.0 -> v1.8.0.0
[00022438][15 00][00] device not detected.
[00022525][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022640][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022702][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022743][01 00][00] v1.23.3419 -> v1.23.3419
[00022854][01 01][00] v1.23.3419 -> v1.23.3419
[00022990][08 00][00] v0.12.0.4 -> v0.12.0.4
[00023033]Packet upgrade failed at version checking.
[00012968]========== remo-con disconnect. boot(15) ============
[00013007]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00013045]Packet upgrade start...
[00013115]Packet checking...
[00013153]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013193]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013231]Done.
[00013277]Version checking[1]...
[00013352][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013416][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00013463][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00013521][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013636][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013722][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013801][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013886][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013966][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00022606][15 00][00] device not detected.
[00022702][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022824][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022882][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022927][01 00][00] v1.23.3419 -> v1.23.3419
[00022967][01 01][00] v1.23.3419 -> v1.23.3419
[00023031][08 00][00] v0.12.0.4 -> v0.12.0.4
[00023071]Done.
[00025117]Waiting for user confirm...
[00035152]Timeout, start upgrade automatically.
[00035233]Firmware upgrading[1]...
[00035307][12 00] Firmware upgrade start...
[00101005][12 00] Firmware upgrade finished successfully.
[00101058][12 01] Firmware upgrade start...
[00166874][12 01] Firmware upgrade finished successfully.
[00166934][12 02] Firmware upgrade start...
[00231173][12 02] Firmware upgrade finished successfully.
[00231231][12 03] Firmware upgrade start...
[00300073][12 03] Firmware upgrade finished successfully.
[00300316][03 06] Firmware upgrade start...
[00040871]========== 2015.09.07 14:22:16. boot(15) ============
[00040996]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00041047]Packet upgrade start...
[00041111]Packet checking...
[00041151]Packet vlink 01.04.0010 <-> 01.03.0020.
[00041198]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00041238]Done.
[00041279]Version checking[1]...
[00041366][03 05][00] v34.2.0.9 -> v34.2.0.9
[00041446][03 06][00] v0.0.0.0 -> v2.3.0.13 need upgrade.
[00041492][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00041556][09 00][00] v1.7.0.3 -> v1.7.0.3
[00054097][11 00][00] device not detected.
[00012957]========== remo-con disconnect. boot(15) ============
[00012997]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00013035]Packet upgrade start...
[00013099]Packet checking...
[00013139]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013180]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013224]Done.
[00013269]Version checking[1]...
[00013329][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013389][03 06][00] v0.0.0.0 -> v2.3.0.13 need upgrade.
[00013443][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00013499][09 00][00] v1.7.0.3 -> v1.7.0.3
[00026040][11 00][00] device not detected.
[00038578][12 00][00] device not detected.
[00051126][12 01][00] device not detected.
[00063667][12 02][00] device not detected.
[00076210][12 03][00] device not detected.
[00079303][15 00][00] device not detected.
[00091849][17 00][00] device not detected.
[00104388][17 01][00] device not detected.
[00104445][19 00][00] v1.0.8.96 -> v1.0.8.96
[00104486][01 00][00] v1.23.3419 -> v1.23.3419
[00104531][01 01][00] v1.23.3419 -> v1.23.3419
[00107087][08 00][00] v0.12.0.4 -> v0.12.0.4
[00107127]Done.
[00109169]Waiting for user confirm...
[00119214]Timeout, start upgrade automatically.
[00119296]Firmware upgrading[1]...
[00119539][03 06] Firmware upgrade start...
[00428203][03 06] Firmware upgrade finished successfully.
[00428286][04 00] Firmware upgrade start...
[00486404][04 00] Firmware upgrade finished successfully.
[00486441]Done.
[00486484]Version checking[2]...
[00486567][03 05][00] v34.2.0.9 -> v34.2.0.9
[00486647][03 06][05] v2.3.0.13 -> v2.3.0.13
[00486698][04 00][05] v1.41.0.0 -> v1.41.0.0
[00486767][09 00][00] v1.7.0.3 -> v1.7.0.3
[00486895][11 00][00] v1.7.0.0 -> v1.7.0.0
[00486982][12 00][00] v1.10.0.0 -> v1.10.0.0
[00487081][12 01][00] v1.10.0.0 -> v1.10.0.0
[00487181][12 02][00] v1.10.0.0 -> v1.10.0.0
[00487306][12 03][00] v1.10.0.0 -> v1.10.0.0
[00490360][15 00][00] device not detected.
[00490456][17 00][00] v1.1.1.7 -> v1.1.1.7
[00490576][17 01][00] v1.0.2.7 -> v1.0.2.7
[00490647][19 00][00] v1.0.8.96 -> v1.0.8.96
[00490690][01 00][00] v1.23.3419 -> v1.23.3419
[00490740][01 01][00] v1.23.3419 -> v1.23.3419
[00490798][08 00][00] v0.12.0.4 -> v0.12.0.4
[00490840]Packet upgrade failed at version checking.
[00013002]========== remo-con disconnect. boot(15) ============
[00013043]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00013088]Packet upgrade start...
[00013154]Packet checking...
[00013193]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013235]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013281]Done.
[00013324]Version checking[1]...
[00013400][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013500][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013547][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013613][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013739][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013855][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013958][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014033][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014113][12 03][00] v1.10.0.0 -> v1.10.0.0
[00022748][15 00][00] device not detected.
[00022828][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022948][17 01][00] v1.0.2.7 -> v1.0.2.7
[00023013][19 00][00] v1.0.8.96 -> v1.0.8.96
[00023056][01 00][00] v1.23.3419 -> v1.23.3419
[00023101][01 01][00] v1.23.3419 -> v1.23.3419
[00023344][08 00][00] v0.12.0.4 -> v0.12.0.4
[00023479]Packet upgrade failed at version checking.
[00013113]========== remo-con disconnect. boot(15) ============
[00013156]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00013201]Packet upgrade start...
[00013252]Packet checking...
[00013291]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013333]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013379]Done.
[00013421]Version checking[1]...
[00013511][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013611][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013658][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013725][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013855][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013960][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014060][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014159][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014259][12 03][00] v1.10.0.0 -> v1.10.0.0
[00022916][15 00][00] device not detected.
[00023020][17 00][00] v1.1.1.7 -> v1.1.1.7
[00023160][17 01][00] v1.0.2.7 -> v1.0.2.7
[00023227][19 00][00] v1.0.8.96 -> v1.0.8.96
[00023287][01 00][00] v1.23.3419 -> v1.23.3419
[00023330][01 01][00] v1.23.3419 -> v1.23.3419
[00023399][08 00][00] v0.12.0.4 -> v0.12.0.4
[00023440]Packet upgrade failed at version checking.
[00056958]========== 2015.09.07 15:57:43. boot(15) ============
[00056999]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00057041]Packet upgrade start...
[00057095]Packet checking...
[00057135]Packet vlink 01.04.0010 <-> 01.03.0020.
[00057178]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00057226]Done.
[00057268]Version checking[1]...
[00057347][03 05][00] v34.2.0.9 -> v34.2.0.9
[00057427][03 06][00] v2.3.0.13 -> v2.3.0.13
[00057475][04 00][00] v1.41.0.0 -> v1.41.0.0
[00057572][09 00][00] v1.7.0.3 -> v1.7.0.3
[00057691][11 00][00] v1.7.0.0 -> v1.7.0.0
[00057781][12 00][00] v1.10.0.0 -> v1.10.0.0
[00057881][12 01][00] v1.10.0.0 -> v1.10.0.0
[00057981][12 02][00] v1.10.0.0 -> v1.10.0.0
[00058081][12 03][00] v1.10.0.0 -> v1.10.0.0
[00061238][15 00][00] device not detected.
[00061313][17 00][00] v1.1.1.7 -> v1.1.1.7
[00061452][17 01][00] v1.0.2.7 -> v1.0.2.7
[00061513][19 00][00] v1.0.8.96 -> v1.0.8.96
[00061564][01 00][00] v1.23.3419 -> v1.23.3419
[00061607][01 01][00] v1.23.3419 -> v1.23.3419
[00061667][08 00][00] v0.12.0.4 -> v0.12.0.4
[00061713]Packet upgrade failed at version checking.
[00012691]========== remo-con disconnect. boot(15) ============
[00012735]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00012777]Packet upgrade start...
[00012831]Packet checking...
[00012870]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012914]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012958]Done.
[00013006]Version checking[1]...
[00013095][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013174][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013229][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013435][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013528][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013628][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013728][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013828][12 03][00] v1.10.0.0 -> v1.10.0.0
[00022474][15 00][00] device not detected.
[00022578][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022698][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022754][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022800][01 00][00] v1.23.3419 -> v1.23.3419
[00022849][01 01][00] v1.23.3419 -> v1.23.3419
[00023016][08 00][00] v0.12.0.4 -> v0.12.0.4
[00023063]Packet upgrade failed at version checking.
[00012571]========== remo-con disconnect. boot(15) ============
[00012619]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00012663]Packet upgrade start...
[00012715]Packet checking...
[00012761]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012806]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012850]Done.
[00012895]Version checking[1]...
[00012982][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013162][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013238][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013316][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013441][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013546][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013646][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013749][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013846][12 03][00] v1.10.0.0 -> v1.10.0.0
[00022495][15 00][00] device not detected.
[00022592][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022726][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022797][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022841][01 00][00] v1.23.3419 -> v1.23.3419
[00022889][01 01][00] v1.23.3419 -> v1.23.3419
[00023061]Packet upgrade failed at version checking.
[00012567]========== 2015.09.07 17:44:10. boot(15) ============
[00012618]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00012762]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012807]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012853]Done.
[00012898]Version checking[1]...
[00012983][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013064][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013126][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013182][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013324][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013419][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013514][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013615][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013711][12 03][00] v1.10.0.0 -> v1.10.0.0
[00022377][15 00][00] device not detected.
[00022492][17 00][00] v1.1.1.7 -> v1.1.1.7
[00022628][17 01][00] v1.0.2.7 -> v1.0.2.7
[00022682][19 00][00] v1.0.8.96 -> v1.0.8.96
[00022729][01 00][00] v1.23.3419 -> v1.23.3419
[00022779][01 01][00] v1.23.3419 -> v1.23.3419
[00022835][08 00][00] v0.12.0.4 -> v0.12.0.4
[00022878]Packet upgrade failed at version checking.
[00012696]========== remo-con disconnect. boot(15) ============
[00012745]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00012875]Packet upgrade start...
[00012932]Packet checking...
[00012976]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013024]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013074]Done.
[00013120]Version checking[1]...
[00025670][03 05][00] device not detected.
[00038215][03 06][00] device not detected.
[00038305][04 00][00] v1.41.0.0 -> v1.41.0.0
[00050854][09 00][00] device not detected.
[00063402][11 00][00] device not detected.
[00075958][12 00][00] device not detected.
[00088502][12 01][00] device not detected.
[00101047][12 02][00] device not detected.
[00113591][12 03][00] device not detected.
[00118536][15 00][00] device not detected.
[00131080][17 00][00] device not detected.
[00143624][17 01][00] device not detected.
[00156168][19 00][00] device not detected.
[00156217][01 00][00] v1.23.3419 -> v1.23.3419
[00156281][01 01][00] v1.23.3419 -> v1.23.3419
[00158844][08 00][00] v0.12.0.4 -> v0.12.0.4
[00158892]Packet upgrade failed at version checking.
[00012620]========== remo-con disconnect. boot(15) ============
[00012664]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00012709]Packet upgrade start...
[00012783]Packet checking...
[00012827]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012869]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012914]Done.
[00012965]Version checking[1]...
[00025509][03 05][00] device not detected.
[00038052][03 06][00] device not detected.
[00038104][04 00][00] v1.41.0.0 -> v1.41.0.0
[00050654][09 00][00] device not detected.
[00063197][11 00][00] device not detected.
[00075743][12 00][00] device not detected.
[00088289][12 01][00] device not detected.
[00100842][12 02][00] device not detected.
[00113385][12 03][00] device not detected.
[00118322][15 00][00] device not detected.
[00130872][17 00][00] device not detected.
[00143415][17 01][00] device not detected.
[00155959][19 00][00] device not detected.
[00156081][01 00][00] v1.23.3419 -> v1.23.3419
[00156128][01 01][00] v1.23.3419 -> v1.23.3419
[00161319][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161365]Packet upgrade failed at version checking.
[00012575]========== remo-con disconnect. boot(15) ============
[00012619]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00012664]Packet upgrade start...
[00012712]Packet checking...
[00012763]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012804]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012852]Done.
[00012902]Version checking[1]...
[00025447][03 05][00] device not detected.
[00037991][03 06][00] device not detected.
[00038052][04 00][00] v1.41.0.0 -> v1.41.0.0
[00050602][09 00][00] device not detected.
[00063144][11 00][00] device not detected.
[00075687][12 00][00] device not detected.
[00088233][12 01][00] device not detected.
[00100778][12 02][00] device not detected.
[00113327][12 03][00] device not detected.
[00118269][15 00][00] device not detected.
[00130812][17 00][00] device not detected.
[00143362][17 01][00] device not detected.
[00155903][19 00][00] device not detected.
[00155947][01 00][00] v1.23.3419 -> v1.23.3419
[00155996][01 01][00] v1.23.3419 -> v1.23.3419
[00161064][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161110]Packet upgrade failed at version checking.
[00012580]========== remo-con disconnect. boot(15) ============
[00012625]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00012668]Packet upgrade start...
[00012713]Packet checking...
[00012849]Done.
[00025437][03 05][00] device not detected.
[00037980][03 06][00] device not detected.
[00038047][04 00][00] v1.41.0.0 -> v1.41.0.0
[00050597][09 00][00] device not detected.
[00063139][11 00][00] device not detected.
[00075682][12 00][00] device not detected.
[00088234][12 01][00] device not detected.
[00100869][12 02][00] device not detected.
[00113412][12 03][00] device not detected.
[00118373][15 00][00] device not detected.
[00130914][17 00][00] device not detected.
[00143456][17 01][00] device not detected.
[00155998][19 00][00] device not detected.
[00156048][01 00][00] v1.23.3419 -> v1.23.3419
[00156093][01 01][00] v1.23.3419 -> v1.23.3419
[00161327][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161377]Packet upgrade failed at version checking.
[00013652]========== remo-con disconnect. boot(15) ============
[00013699]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00013739]Packet upgrade start...
[00013786]Packet checking...
[00013838]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013882]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013929]Done.
[00013972]Version checking[1]...
[00026523][03 05][00] device not detected.
[00039066][03 06][00] device not detected.
[00039121][04 00][00] v1.41.0.0 -> v1.41.0.0
[00051664][09 00][00] device not detected.
[00064212][11 00][00] device not detected.
[00076756][12 00][00] device not detected.
[00089299][12 01][00] device not detected.
[00101852][12 02][00] device not detected.
[00114396][12 03][00] device not detected.
[00121334][15 00][00] device not detected.
[00133878][17 00][00] device not detected.
[00146422][17 01][00] device not detected.
[00158973][19 00][00] device not detected.
[00159017][01 00][00] v1.23.3419 -> v1.23.3419
[00159061][01 01][00] v1.23.3419 -> v1.23.3419
[00159121][08 00][00] v0.12.0.4 -> v0.12.0.4
[00159171]Packet upgrade failed at version checking.
[00013492]========== remo-con disconnect. boot(15) ============
[00013536]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x60ce5380].
[00013578]Packet upgrade start...
[00013633]Packet checking...
[00013676]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013723]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013765]Done.
[00013811]Version checking[1]...
[00026433][03 05][00] device not detected.
[00038986][03 06][00] device not detected.
[00039040][04 00][00] v1.41.0.0 -> v1.40.0.0
[00051589][09 00][00] device not detected.
[00064137][11 00][00] device not detected.
[00076690][12 00][00] device not detected.
[00089234][12 01][00] device not detected.
[00101779][12 02][00] device not detected.
[00114324][12 03][00] device not detected.
[00121261][15 00][00] device not detected.
[00133809][17 00][00] device not detected.
[00146356][17 01][00] device not detected.
[00158901][19 00][00] device not detected.
[00158950][01 00][00] v1.23.3419 -> v1.23.3419
[00158993][01 01][00] v1.23.3419 -> v1.23.3419
[00159056][08 00][00] v0.12.0.4 -> v0.12.0.4
[00159106]Packet upgrade failed at version checking.
[00247536]========== remo-con disconnect. boot(15) ============
[00247587]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00247634]Packet upgrade start...
[00247695]Packet checking...
[00247743]Packet vlink 01.04.0010 <-> 01.03.0020.
[00247796]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00247844]Done.
[00247902]Version checking[1]...
[00260454][03 05][00] device not detected.
[00012646]========== remo-con disconnect. boot(15) ============
[00012695]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6acbdcfb].
[00012747]Packet upgrade start...
[00012808]Packet checking...
[00012859]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012907]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012965]Done.
[00013016]Version checking[1]...
[00025567][03 05][00] device not detected.
[00038121][03 06][00] device not detected.
[00038182][04 00][00] v1.41.0.0 -> v1.41.0.0
[00050754][09 00][00] device not detected.
[00063307][11 00][00] device not detected.
[00075855][12 00][00] device not detected.
[00088401][12 01][00] device not detected.
[00100948][12 02][00] device not detected.
[00113494][12 03][00] device not detected.
[00118433][15 00][00] device not detected.
[00131073][17 00][00] device not detected.
[00143622][17 01][00] device not detected.
[00156171][19 00][00] device not detected.
[00156219][01 00][00] v1.23.3419 -> v1.23.3419
[00156293][01 01][00] v1.23.3419 -> v1.23.3419
[00158855][08 00][00] v0.12.0.4 -> v0.12.0.4
[00158909]Packet upgrade failed at version checking.
[00013613]========== remo-con disconnect. boot(15) ============
[00013661]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00013706]Packet upgrade start...
[00013761]Packet checking...
[00013808]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013853]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013903]Done.
[00013949]Version checking[1]...
[00026497][03 05][00] device not detected.
[00039043][03 06][00] device not detected.
[00039105][04 00][00] v1.41.0.0 -> v1.41.0.0
[00051653][09 00][00] device not detected.
[00064204][11 00][00] device not detected.
[00076753][12 00][00] device not detected.
[00089304][12 01][00] device not detected.
[00101848][12 02][00] device not detected.
[00114394][12 03][00] device not detected.
[00121301][15 00][00] device not detected.
[00133852][17 00][00] device not detected.
[00146393][17 01][00] device not detected.
[00158939][19 00][00] device not detected.
[00158983][01 00][00] v1.23.3419 -> v1.23.3419
[00159030][01 01][00] v1.23.3419 -> v1.23.3419
[00159095][08 00][00] v0.12.0.4 -> v0.12.0.4
[00159142]Packet upgrade failed at version checking.
[00012795]========== remo-con disconnect. boot(15) ============
[00012843]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00012895]Packet upgrade start...
[00012957]Packet checking...
[00013004]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013057]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013110]Done.
[00013162]Version checking[1]...
[00025711][03 05][00] device not detected.
[00038257][03 06][00] device not detected.
[00038318][04 00][00] v1.41.0.0 -> v1.41.0.0
[00050974][09 00][00] device not detected.
[00063521][11 00][00] device not detected.
[00076070][12 00][00] device not detected.
[00088617][12 01][00] device not detected.
[00101183][12 02][00] device not detected.
[00113730][12 03][00] device not detected.
[00118781][15 00][00] device not detected.
[00131329][17 00][00] device not detected.
[00143892][17 01][00] device not detected.
[00156439][19 00][00] device not detected.
[00156488][01 00][00] v1.23.3419 -> v1.23.3419
[00156539][01 01][00] v1.23.3419 -> v1.23.3419
[00159106][08 00][00] v0.12.0.4 -> v0.12.0.4
[00159153]Packet upgrade failed at version checking.
[00012739]========== remo-con disconnect. boot(15) ============
[00012791]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00012843]Packet upgrade start...
[00012906]Packet checking...
[00012960]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013008]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013067]Done.
[00104548]========== remo-con disconnect. boot(15) ============
[00104605]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00104656]Packet upgrade start...
[00104714]Packet checking...
[00104772]Packet vlink 01.04.0010 <-> 01.03.0020.
[00104822]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00104876]Done.
[00104927]Version checking[1]...
[00117479][03 05][00] device not detected.
[00130027][03 06][00] device not detected.
[00130087][04 00][00] v1.41.0.0 -> v1.41.0.0
[00142658][09 00][00] device not detected.
[00155214][11 00][00] device not detected.
[00167764][12 00][00] device not detected.
[00180319][12 01][00] device not detected.
[00013626]========== remo-con disconnect. boot(15) ============
[00013675]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x60ce5380].
[00013721]Packet upgrade start...
[00013779]Packet checking...
[00013829]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013877]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014010]Done.
[00014065]Version checking[1]...
[00026609][03 05][00] device not detected.
[00039158][03 06][00] device not detected.
[00039212][04 00][00] v1.41.0.0 -> v1.41.0.0
[00051776][09 00][00] device not detected.
[00064323][11 00][00] device not detected.
[00076872][12 00][00] device not detected.
[00089423][12 01][00] device not detected.
[00101983][12 02][00] device not detected.
[00114531][12 03][00] device not detected.
[00123264][15 00][00] device not detected.
[00135813][17 00][00] device not detected.
[00148367][17 01][00] device not detected.
[00160910][19 00][00] device not detected.
[00160959][01 00][00] v1.23.3419 -> v1.23.3419
[00161009][01 01][00] v1.23.3419 -> v1.23.3419
[00161079][08 00][00] v0.12.0.4 -> v0.12.0.4
[00161123]Packet upgrade failed at version checking.
2015-9-11
sploodge
info.filmtwist Posted at 2015-9-11 17:49
[00014357]Done.
Wow that log does not look good at all. It seems like the firmware cannot detect a few modules that need updating ( device not detected ) parts..
I'm waiting to find out from DJI if there is a fix to this but if I were you, get onto DJI too..
2015-9-11
info.filmtwist
sploodge Posted at 2015-9-11 10:41
Wow that log does not look good at all. It seems like the firmware cannot detect a few modules tha ...
Meaning i need to return it...or what is the process of connecting with them
2015-9-11
sploodge
info.filmtwist Posted at 2015-9-11 20:05
Contact them first. Details here for your region - http://www.dji.com/support
2015-9-11
info.filmtwist
sploodge Posted at 2015-9-11 12:31
DJI is impossible to get a hold of on the phone. They basically just disconnect me after waiting for 15-20min each time as call volume is too high.
Any tips or ideas to get someone to respond quickly.
I'm a pro cinematographer and i need my phantom back up and running soon for projects i have coming up in the next week.
Any help is greatly appreciated! Thanks!
2015-9-11
carcharias
I couldn't update the firmware. I'm guessing it's because my brand new 4k camera snapped off and I'm waiting for the new one to arrive. Must need that on there, right?
2015-9-13
radius
Indonesia
i wonder if we have updated to firmware 1.4.0010, is it possible to roll back to firmware 1.1.9?
as i remember, the previous 1.3.2.0 firmware only let us roll back to 2 latest versions, which is 1.1.9 & 1.2.6.
does this 1.4.0010 firmware still have this roll back limitation?
if so, then it would be impossible to roll back to 1.1.9, as now the 2 latest versions would be 1.2.6 & 1.3.2.0.
2015-9-15
ecobcg
Flight distance : 3609728 ft
Portugal
Hello. I have a doubt regarding thr P3 RC calibration. Can anyone explain me the exact steps of doing that? is there any video of such a calibration? (didn'd find anyone till this moment...).
I know it's done from the GO App... but what should we do with the stocks during the calibration?
Thank you.
2015-9-16
KimDJI
Sweden
Very good guide!
Thanks!
2015-9-16
Johncoffee
Flight distance : 1502290 ft
Switzerland
sploodge or anyone!
How do I make sure that all of my 3 batteries have been updated correct? (I just updated all from 1.19 -> via 1.32 -> 1.40)
Phantom 3: 1.40
RC: 1.32
Batteries (3pc): unknown....
Thanks for a hint.
*John*
2015-9-16
rickyram
Mexico
sploodge
i have problems upgrading my RC GL300B, it was working great until i made the last upgrade to my P3A.
1.- I upgraded the P3A successful
2.- Then my APP upgraded automatically and when i connect my ipad or android phone it says "Need to upgrade the RC", i click that option, begin download the FW, install it and says that i have to reboot my RC, so i turn off and turn on my RC and it show "No connection" in RED, and there is no video signal, and it says again "Need to upgrade the RC", so i did this a lot of times and nothings happens, it seem that the new APP version doesn`t keep the upgrade in my RC, or don't recognize it, so is there any way to get older APP, or what can i do?
Thank you for your help¡¡¡
2015-9-16
hrenotan
Russia
Hi to everyone! Thank you for all the info. I have P3 Pro, succsessfully updated drone itself to the latest FW 1.4.0010. However my RC is still 1.1.8. Reply from DJI support was that I can update straight to FW 1.3.20. However still nothing happens when I insert a card with it and switch RC on. Anyone has any idea why?
2015-9-17
rickyram
Mexico
what is your RC model? if you have the 300B, it can`t be updated from the USB, only from the APP, i am having problems when i try to update, because the APP don`t  recognize de upgrade
2015-9-17
carcharias
carcharias Posted at 2015-9-13 19:35
I couldn't update the firmware. I'm guessing it's because my brand new 4k camera snapped off and I'm ...
It's because the camera needed replacing.
2015-9-17
hrenotan
Russia
I have GL300A, it was standard with my Ph3 Pro.
2015-9-17
hrenotan
Russia
Problem has been solved the following way: just used another USB. First one I used that didn't work was 32GB micro SDHC card. One that worked was 64GB Leef flash drive. And it had other files on it. Still worked!
2015-9-17
rodhassler
Thank you for taking the time to put this together, it was very helpful! If you've ever in the Philadelphia area I owe you a beer!
2015-9-18
asfodelo42
hi, buying a second battery after upgrading the P3A, I need to update the second battery, or happens automatically when I insert the P3A already updated?
2015-9-23
sploodge
asfodelo42 Posted at 2015-9-23 16:45
hi, buying a second battery after upgrading the P3A, I need to update the second battery, or happens ...
You will need to update it. Same process, just put the latest firmware BIN on the SD and urn the P3 on.. Takes minutes to do a battery..
2015-9-23
1234Next >
