DJI Gamora
walid2 Posted at 10-23 05:51
Update: When I approach the RC to the Aircraft, i change the transmission to Manual, then the signal became normal, then i change it back to automatic (dual band) no issue at all and the signal is perfect, however when turn off the aircraft and the RC, then turn them both ON again, signal is super low, I have to approach the aircraft again, put the transmission to manual first, then change it to automatic.
any solution ? software issue ?
Hi, walid2. Thank you for reaching out. Just to confirm, the aircraft not connected error appear even without taking off? |
