DJI Thor
Flight distance : 13602 ft
Hi SoFloBassin, sorry for the late response. May I know if the issue has been resolved?
Based on our last comment, here are the updates from our engineer team.
For the issue you feedback, it is recommended to try calibrating the remote control to see if it is within the hovering accuracy. You could try calibrating the aircraft IMU compass as well.
Secondly, the environment is also one of the huge influencing factors. It is recommended to try different open environments, and also please check whether it is in good GPS condition. Regarding the speed, did you fully hit the joystick? The environment may also affects speed performance.
Please try as the above saying. If the problem still occurs, it is recommended to provide data for further analysis. Thanks.
