WARNING! Upgraded to v1.4.0010 lost my drone
12
5531 52 2015-9-8
Flyhigh7887
Sweden
stevegreentechy Posted at 2015-9-9 12:24
Do you have the video from the SD card on the Phantom??
ummm, the video is 10 posts up.
edit: 11 from here.
2015-9-9
linus.norden
Flight distance : 4724 ft
Sweden
the file is broken
2015-9-9
linus.norden
Sweden
Now i change the shell, cleaned to motors but when i want to do a take off its said Error code 45 ???? anyone knows what that is?
2015-9-9
gr8pics
Flight distance : 5365522 ft
Norway
AerialLens Posted at 2015-9-8 21:45
You are certainly correct. In fact, I will not even do a compass calibration unless the K Index is ...
NONSENSE!
Nothing drops out of the sky because the gps signals gets weak, the holding power will only get less accurate.
You need a much higher KP index before things starts to black out,,,
2015-9-9
sgeprods
Flight distance : 57841 ft
linus.norden Posted at 2015-9-9 23:35
Now i change the shell, cleaned to motors but when i want to do a take off its said Error code 25 ?? ...
That was quick... how did you get a new shell in such a short time?
2015-9-9
linus.norden
Sweden
sgeprods Posted at 2015-9-9 23:12
Have a shop just 30 min from here
2015-9-9
Flyhigh7887
Sweden
linus.norden Posted at 2015-9-10 07:47
Linus, did you ever find out what the error 45 is?
Might be worth a call to support!? Please share if you find out.
2015-9-9
linus.norden
Sweden
Hi everyone... i've been working hard to fix my drone! No answer from support. But i notice that one  capacitor on the mainboard was missing so i went back to where i found the drone and i found it! crazy i know, whats the chans of that happening. The thing is that these components is glued to the motherboard but i put it in place an had my finger on in and tried to start the drone and it works!
But now i need to find out what white glue they are using to keep the capacitor in place.. and the in can fly again!!!! So anyone, what glue should i use?!
2015-9-10
andreas_kreuz
pretty cool... you find a capacitor? a surface mounted device?
What´s the size of this component?
You have to solder the cap and then you can add any glue you want
silicone, cyanacrylat (<-- the word should be similar in english, so U understand what I wanna say..superglue is up to 60°C stable, worst case)
I would prefer silicone, I think you call it silicone sealant or silicone adhesive
congratulations anyway
2015-9-10
stevegreentechy
Flight distance : 558031 ft
Flyhigh7887 Posted at 2015-9-9 12:09
edit: 11 from here.
That was the cached video from the mobile device not the video from the SD card.
2015-9-28
firatuysal
Turkey
I had a similar issue in Zanzibar, Africa last week. I was flying my drone in the beautiful coastline. It was coming down from 150 meters. At around 60 meters, I got no signal. No video, no data on APP. RTH not triggered. I realized that I can control the drone. I landed it successfully. I restarted the APP and got the signal back. Till that time I could not get any connection to drone via APP. I use Iphone6 Plus.
2015-9-29
dji-jjrc
andreas_kreuz Posted at 2015-9-9 11:28
An asshole with a jammer could cause exactly this scenario...
http://www.jammer4uk.com
GPS, WiFi, wh ...
Actually, the same thing happened to me. I was flying my mini drone when this dude came up to me with a portable jammer because I had been wondering what was wrong with my drone. He said he bought it online on this site: http://www.jammerspro.com
I asked him if it was legal to interfere with WiFi frequencies, given that the RC uses 2.4GHz commonly used for wireless communications and the act of interfering with such frequencies is illegal in Italy. And he shrugged his shoulders and said "who cares? Until they don't catch me." Unbelievable.
2016-4-4
djiuser_SKDFJgsUNzRS
I think this kind of situation can easily occur with special jammers for drones. And buying this kind of equipment is also very simple.
jammers.store
This is difficult to prevent.
2021-12-21
12
