osmonauta
Hungary
When you reset the camera to factory settings (or turn it on for the first time), it gives you a couple of languages to choose from. This implies character input would need to support all those languages at the minimum. You can't put a keyboard on that tiny screen because some people have bigger fingers so that would create a problem with character input. A different input method would be required. When you consider how many people would find this feature a "must", if I were in the driver's seat, I would certainly not implement it. It just simply doesn't worth it.
Look at the custom folder name function somewhere in the settings menu. Even though that's just 3 or 4 characters, you have to fiddle with the input for ages because scrolling up/down to find each character is a daunting task. I bet barely anyone uses that feature. And that's just for 3 characters. Now imagine you'd need to do the same for an entire word or two. There's simply no point doing it.
As far as highway signs, I'm not sure what the logic is behind comparing highway signs to character input on a camera, but highway exits are labelled as "A" or "B", depending on the type of exit. Not to mention, they are all represented by numbers, eg Exit 32, Exit 32A, Exit 32B, "Convention Center Use Exit 4B", etc. not "Convention Center Use Exit Martin Luther King Blvd".
Either way, you can certainly put in a request and DJI will forward it to the appropriate department :-)
