Hi there, may I double confirm if you're using DJI Goggles?
For DJI Goggles: The DJI Goggles do not support the Mavic 2’s 5.8 GHz frequency, and its default frequency is 2.4 GHz. It is recommended that you do not fly the drone in urban environments as there can be a lot of signal interference.
For DJI Goggles RE: The DJI Goggles RE supports the Mavic 2’s 5.8 GHz frequency. For better experience, it is recommended you attach the DJI Pagoda antenna to the DJI Goggles RE to avoid external interference on the image transmission performance. If the antenna is not attached, it is recommended to use 2.4 GHz frequency band. |
