Brand New TB50 Battery Doesn't Charge
257 2 2-16 14:05
Eponym
I just bought a Ronin 4D and setup the charger as indicated in the manual. When I plug in the battery to the charger, all four LEDs blink 10 times and then shut off. When I tap the LED indicator button, the led furthest from the indicator blinks 6 times and then shuts off. It's been on the charger for a few hours. I've tried mutiple outlets. The USB ports on the power brick seem to power other devices, so the fault is likely with the battery. Any solutions other than replacing the battery?
2-16 14:05
Eponym
I went out and bought a second tb50 battery and the 2nd one works properly. The one that came with the Ronin 4D is bad. Do I have to return the entire Ronin 4D just to replace a bad battery or will DJI allow me to send in just the battery?
2-16 17:55
DJI Thor
Flight distance : 13602 ft
Eponym Posted at 2-16 17:55
We are sorry for any inconvenience caused, Eponym. To ensure the long-term usage, we recommend sending the battery back for a check. You can create a case by registering through the link https://repair.dji.com/, and our team will process your request. If you need help, contact our customer support service http://www.dji.com/support. Thank you.
2-16 23:41
