I have set a custom C1 , C2, and I want my DJI mic 2 transmitter gain to be set to -3db. All I need to do is set up, swipe down in the custom, and hit Overwrite, and the next time we turn on we have 0 db, this is not the way a save should work, seems DJI engineers missed this in their set up, they did it correctly if we simply go to the video Mode, not customs, and set to -3 db the next time turning on saves, so Houston no one is on Planet earth with a proble.
see video if the writing is off the wall.
I should get 1K points for bringhtis to tehir attention no credits are ever given for finding DJI's issues ha ha ha
Hi. The custom setting will only save camera parameters, which will not save MIC 2 gain parameters. But normally after setting the gain and then restarting, it will keep the last setting. The one you are experiencing is not normal. If the DJI MIC 2 and Osmo Action 4 are already up to update and the issue happens all the time, please send us the camera logs and exact test date for us to further check. Thank you for your patience.
