DJI Wanda
Hi there, CrystalSky can expand two Micro SD cards with a maximum memory of 128G, and you can quickly check your creations and save your favorite clips to another Micro SD card for your convenience. About how to save the cache to a microSD card in DJI CrystalSky, please do as follows, thank you.
1. Launch DJI GO 4 and go to “General Settings”. After a microSD card is inserted, a “Cache to SD Card” option will be displayed under “Video Cache” as shown below:
2. If this option is enabled for the first time, a prompt will pop up:
3. Scroll to the bottom and tap “Start Here”.
4. After this page appears, tap the three small dots in the top-right corner.
5. The “Show SD card” option will be displayed. Then tap it to display the microSD card.
6. Select the SD Card on the left (SD card 1 or SD card 2 will be displayed based on the inserted card slot).
7. Tap and select SD Card x at the bottom (x refers to 1 or 2 based on your selection). For SD card 1, tap “SELECT SD card 1”.
8. Then, “Cache to SD Card” is enabled and you can save the cache to the microSD card. If the option cannot be enabled after changing the settings, check whether DJI GO 4 has been updated to the latest version. If so, there may be a compatibility issue with the micro SD card. Try to use another micro SD card. |
