DJI Relay Module compatibility
154 7 4-26 20:07
Speurhond
Flight distance : 11882835 ft
hi,
the DJI Relay Module for the Agriculture drones (T40 and T20P),
I really need this for the inspire 3 and the DJI O3 air unit!!!! or the O4 unit when it comes out
I hope this can be made compatible
4-26 20:07
DJI Thor
Flight distance : 13602 ft
Hi there, thank you for reaching out. You could contact with the local dealer for the purchase. If you need to check the dealer information, please go to the where to buy link and check the details, thanks. https://www.dji.com/where-to-buy/agriculture-dealers
4-27 00:08
Speurhond
DJI Thor Posted at 4-27 00:08
is it compatible with the inspire 3 then? or the O3 air unit ?
4-27 07:11
DJI Thor
Speurhond Posted at 4-27 07:11
Hi there, thank you for reaching out. Currently the DJI Relay Module supports the Agras T50, Agras T25, Agras T40, Agras T20P and DJI RC Plus Remote Controller. Thanks.
4-27 22:43
Speurhond
DJI Thor Posted at 4-27 22:43
the DJI RC Plus Remote Controller is also used with the inspire 3, so does it work?
4-29 01:24
fichek
Flight distance : 915554 ft
Croatia
Speurhond Posted at 4-29 01:24
No, but it would definitely be nice to have it work with all O3/O4 products. Unfortunately O3 was severely fragmented with different versions of spec so might not be possible, and this relay module seems to be O3 only so not sure it would even do O4, but we can dream.
4-30 06:26
DJI Thor
Sorry for the late response. We are still checking with our engineer team. Once we get the result, I will keep you update soon.
5-4 05:03
DJI Thor
Hi there, as our engineer updates, the Relay Module can only be used for agricultural devices. There is no interface for frequency linking to relays on the DJI Inspire 3. Also the app for Agricultural device is different from the DJI Inspire 3 one, which has a dedicated interface for triggering frequency linking with relays.
5-4 05:10
