N0s3b0n3
Flight distance : 268766 ft
I've encountered the issue multiple time during a auto landing procedure and RTH and I was wondering if other users had had the same issue
the drone had the homepoint set before take-off from a round landing pad, the pad was deployed on a perfectly flat surface, take off was executed without any issues but returning to the pad to swap batteries, the drone started positioning itself above the pad, moved down to roughly 1m high and stopped, a message was displayed on the RC saying the surface was an "unsuitable landing area" and the drone kept hovering.
I then decided to land it manually but the controls refused to accomodate for slight adjustments with the right stick (mode 2)
For example pushing the stick forward, left or fight resulted in an abrupt upward movement instead, making the repositioning of the drone almost impossible, camera assist wasn't working either, refusing to point downwards so I couldnt assess if I was perfectly aligned with the pad.
I had to force land the drone by pushing the left stick down in a very sketchy way missing the pad by almost a foot and damaging a propeller, triggering a ton of error messages, blades damaged, rotor stuck, etc. etc.
Blade has been changed and drone is fine, but I'm still wondering why the drone couldn't land and was so difficult to maneuver.
Anyone has any idea how to correct/avoid this kind of scenario?
Thanks in advance.
