New remote controller firmware!
123456789
36726 347 2015-10-21
BillyRay
So for people who are updating their firmware through an Android phone, and flying with an iPad.  I understood it that there are different versions of the App, one version for iOS and another version for Android?  If that's true, then how are ya'll updating the iOS app with an Android phone?
2015-11-6
Positveimage
Flight distance : 2772 ft
gkeywood Posted at 2015-11-6 12:45
Re the RC rollback, there is some useful info on this thread
http://www.inspirepilots.com/threads/ ...
HI,
This link just seems to give you Chinese text?
2015-11-7
tickm4n
Flight distance : 1662484 ft
Poland
Please make available for download  RC_FW_V1.4.30.bin
thank you.
2015-11-7
gkeywood
Flight distance : 839797 ft
tickm4n@gmail.c Posted at 2015-11-7 12:57
thank you.
Hi
It looks like the link is blocked on this forum.
You have to go to a different forum called inspire pilots...easy to find. In the help section there is a thread on the RC issues specifically. It hasn't worked for me, but has for others.
I'm still without any video signal. I can even control, the camera via the screen on the app but no image at all.
I'm prob going to have to try a new camera under warranty..
Not happy.
2015-11-7
Moviedro
Hi guys i need some assistance from season drone vets.
1. i was flying my drone 11/7/15 and i was not able to record or take any photos from the app or from the remote control.
2. once the drone was in the air it constantly kept switching from video to photo mode without me manually setting it ( i was in a free fly zone,no magnetic interference )
3. the iso kept jumping from 1600 to 100
4. i cannot activate the IOC ( advance settings+multiple flight mode on but the enable IOC is grayed out ) i still can't activate it when my settings are in F-mode + course lock is activated )
this is a problem.
Just so you know,
(a) i'm using a LG G3 smartphone . Never had a problem before
(b) I never lost video on the app when flying , it just keep switching from video settings to photo on its own with out me manually changing it
(c) current firmware - APP ANDROID VERSION 2.4.0   FIRMWARE V P3X_FW_V01.04.0010.bin  RC FIRMWARE 1.4.3.0
i thought this was due to me not updating the RC remote to the latest firmware ( because the new features benefit the inspire 1 and not my Phantom 3 ) so i went ahead and update it today 11/8/15 and took the drone out for a test flight but the problem continued more than before. I changed the sd card,reset all the settings and this problem still persist .
This is a major issue
what are your suggestions for resolving these problems. Thanks for your help in advance
2015-11-7
DJI-Dave
Moviedro Posted at 2015-11-7 06:58
1. i was flying my drone 11/7/15 and i was  ...
That does not sound like something you're going to be able to fix yourself. Unfortunately I believe you will need to send the  unit in for repair.
2015-11-7
Moviedro
DJI-Dave Posted at 2015-11-7 11:23
That does not sound like something you're going to be able to fix yourself. Unfortunately I believe ...
thanks for the reply, are you DJI Technical Support ? or should i contact them via phone Monday before i download  the product repair form ?
thanks in advance i'm a newbie. lol
2015-11-7
Positveimage
Hi DJI (Dave or Tim or anyone, please help)
I am so confused.
I am running ISO 8 on an I Pad 2 mini, using Go app version 2.3. with firmware version 1.3 I have resisted updating to ISO 9 and the latest GO app version because of instabilities in the app with ISO 9 as detailed on the DJI forum.
Using this set up I had zero problems.
I have recently updated the RC only (or so I thought) to version 1.4.3 via the Go app, but it transpires the app also updated the firmware to the latest version, 1.4.00.10.
The aircraft now looses video signal , the app locks up.
I am at a loss what to do. Shall I update everything or should I revert back to what I know works.
If that is the case how do I de-install the RC and Aircraft firmware? I have the previous versions down loaded to key computer.
Please help - It's so frustrating!
2015-11-7
DJI-Dave
Moviedro Posted at 2015-11-7 08:50
thanks for the reply, are you DJI Technical Support ? or should i contact them via phone Monday be ...
Hi Moviedro,
I am DJI Technical Support, but I am only Tech Support on the forums. I do not work at any of the call centers. Not that that matters much, just for your information.
I would recommend you go ahead and call the Phone Tech Support. It does not hurt to get a second opinion, especially with the trouble you are having. I am pretty sure they will also tell you to send it in, but they might have an idea of something you could try first, that I did not think of... Ok to be a newbie, we were all newbies at some time in our lives.
Dave
2015-11-7
DJI-Dave
Hi Positiveimage,
You can downgrade your RC and Aircraft firmware by going to the DJI website and downloading the older firmware, the previous version. Then just install that firmware as you would if it were new firmware. Follow the directions in the pdf document with the instructions for updating firmware.
Directions to the IPA files for redoing the Go App.
On Mac OS you can find the IPA files by opening your "Finder" then click on Go in upper left corner then scroll down to Home. Click on Music folder, then on iTunes then on iTunes media (if you have not moved the iTunes media that is, some move it to an external drive due to its size) , then click on mobile applications folder. You will then see your IPA files.
This will work if you downloaded the Go app with your Mac computer. If you did not and you downloaded it from your iPad or iPhone they (IPA files) will not be there . If you have not put the 2.4 Go App on your iPad yet you can back up your iPad to your Mac with the 2.3 Go App if you have it. (you will not have it if you have "auto updates turned on" before back up it will ask you to "down load purchases from your iPad to your Mac" say "Yes". This will put a copy of the app on your Mac in your iTunes and a copy of the IPA files in the location I have described.
But if you have updraded the App in iTunes you will find the older version in the recycle bin if you have not deletet it! Otherwise, maybe you have a backup from the older files in your backup from the TimeMachine? (it you have TimeMachine turned on.
Then if all is working you can try putting on 2.4 knowing you have a copy of 2.3.
1. delete V2.4.0 GO App on your device
2. delete V2.4.0 GO App in iTunes folder (mentioned above)
3. copy V2.3.0 to this iTunes folder
3. open iTunes and you will see the old App
4. install V2.3.0 to your device via iTunes and sync it.
Dave
2015-11-7
de23914.gmail
DJI-Dave Posted at 2015-11-8 06:49
Hi Positiveimage,
You can downgrade your RC and Aircraft firmware by going to the DJI website and d ...
Hi,
just bought a (5 months old with ~5hrs flight on it)  pro3 from the widow of a deceased aquaintancee last week and experienced the very same problems as described above, but aditionally have the problem, that the 2.40 app on neither of my iphones/ipads even seems to find the rc at all. All i get is the startscreen with that "howto"-link, but no "cameraview"-button on all my IOS devices (all on 9.1).
I've tried on my S4 mini (didn't work either) and then in a final attempt on my old S3, where at least i was able to enter the cameraview. I was prompted to ugrade the controller, which according to the manual indeed should have been successful, but left me with a nonresponsive connection on the S3 as well (can still enter cameraview, but says "disconnected" now).
So now I have half a dozen mobiles/tablets including a brandnew Ipad mini 2, which I bought yesterday for no other purpose than for the P3, and still can't fly.  RC and bird obviously are still paired, I can start engines and probably could start flying without video, but then that's not what I bought it for. THAT I did with my old P1 for two years....
What now? I have no 2.30 app for either IOS nor Android, the rc seems to do nothing when trying to downgrade to 1.03.020 nor upgrade to 1.04.030 via USB, the bird seem to have accepted 1.04.0010, although I'm not sure as the messages in the txt are somewhat irritating. (see below, which is just the last few lines of the *.txt)
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2015.11.08 09:30:33 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
========== 2015.11.08 10:55:08 =====================
Result: Abort.
Upgrading ...
Result: Success.
So this is it. :-/ Stuck with a nonresponding rc which I could probably still fly the same way as I did my phantom I for years, but don't not dare yet, as I'm unable to calibrate the compass or anything else. Dammit :-(
any ideas?
cheers Martin
2015-11-8
Positveimage
DJI-Dave Posted at 2015-11-8 05:49
Hi Positiveimage,
Thanks Dave, I am already on V2.3 so I will back it up just in case before I update, thats a big help. What about updating as yet to IOS 9? and how can I roll back to the previous RC version? Please see my previous post. Can you shed any light on my problem?
Many Thanks
2015-11-8
DRONEFREAK55
Puerto Rico
All updates working 100 percent. Yeah
2015-11-9
Phuglie
Flight distance : 45226 ft
I updated the RC using DJI GO app - seemed to go well - not been out yet to see how differently the P3p handles though ;)
2015-11-9
DJI-Dave
Positveimage Posted at 2015-11-8 10:27
Thanks Dave, I am already on V2.3 so I will back it up just in case before I update, thats a big h ...
Hi Positiveimage,
If I were you I would wait on ios9 if you can.
2015-11-9
DJI-Dave
de23914.gmail Posted at 2015-11-8 03:40
Hi,
just bought a (5 months old with ~5hrs flight on it)  pro3 from the widow of a deceased aquai ...
If you have done all the trouble shooting suggestions I have outlined in this thread then I am not sure what else it could be. You might need to send it in. Sorry.
2015-11-9
Positveimage
DJI-Dave Posted at 2015-11-10 03:29
Hi Dave,
I am not sure I follow you. The RC and The aircraft have the latest firmware according to the app. I updated the RC firmware via the app and it also updated the aircraft which I didn't want. I now want to downgrade the firmware in the aircraft to the previous version which was problem free. This previous version is still on sd card in the aircraft so how can I do this, surely i need to remove the latest version of the aircraft and the RC firmware and the put the sd card back in?
Thanks
Thanks
2015-11-10
ryan.sletten1
olekopter Posted at 2015-10-21 05:22
I did the update :-) the peeeeep peeeeeep ..... is anointing like hell. I did it in my office and my ...
OMG its the worst sound it the world
2015-11-10
DJI-Dave
Positveimage Posted at 2015-11-10 05:55
Hi Dave,
I am not sure I follow you. The RC and The aircraft have the latest firmware according to ...
Try taking off the firmware on the sd card reinstall the old firmware on the sd card. then put the sd card back in and see if it starts to update.
You can get the older firmware from the download page on the DJI website.
2015-11-10
Moviedro
DJI-Dave Posted at 2015-11-8 00:32
Hi Moviedro,
I am DJI Technical Support, but I am only Tech Support on the forums. I do not work a ...
Hi Dave i finally got around to testing my drone after a full software reinstall and everything is working good, thanks for your advice.
2015-11-17
DJI-Dave
Moviedro Posted at 2015-11-17 17:15
Hi Dave i finally got around to testing my drone after a full software reinstall and everything is ...
Very good to hear it. Thank you for reporting back, a lot of guys don't do that.
Sorry for the inconvenience You experienced.
Dave
2015-11-17
philml420
Machoman Posted at 2015-10-22 11:07
What about the rumors of this new firmware causing reduced output power? Anyone experiences lower ra ...
My phantom 3 standard loses remote control signal at 1200 after update
2015-11-28
Machoman
Flight distance : 1036959 ft
Austria
philml420@gmail Posted at 2015-11-29 04:05
and before?
2015-11-29
philml420
Funny thing, im on a safe side, i dont go balls to the wall, so i flew short distance for like a month,then update,and finally felt comfortable, btw im comparing it with my stock vision,which did 3200 on a stock remote,and it didnt stop there,i just didn't want to go farther
2015-12-3
philml420
ow i wonder if it was update or its just the distance of a new p3s
2015-12-3
philml420
Im seriously thinking to return it the way it all going
2015-12-3
tzuldo
Puerto Rico
Swedrone Posted at 2015-10-21 08:01
Nice with a tilting crosshair for the gimbal. No need for a fix anymore
hi... did you ever find a solution for this... having same problem
2016-10-21
Swedrone
Flight distance : 14066975 ft
Sweden
tzuldo Posted at 2016-10-21 19:36
Yeah I sold the P3 and got a P4
2016-10-22
123456789
