Phantom 3: Firmware v1.5.0030 Install Guide and Support Thread
166757 186 2015-11-23
perseas
Greece
ericdimsum@gmai Posted at 2015-12-1 10:28
Hi guys quick question. Just got my phantom p3 pro. Current firmware is 1.3.20. Should I update to 1 ...
Hi mate,
I got my P3 pro last week  with firmware 1.3.20 and I updated directly to 1.5.3 without any issue following the instructions. Before you do it, read carefully the pros and cons of the recent update which can be found in various threads and decide according your needs. Once you update to the latest version, you can go back only to the prior 1.4 version.
2015-12-1
rox68
Hi, it's my log file after upgrade.... I do not understand well.... Do you think that upgrade to 1.5.0030 is OK? THANKS FOR YOUR ANSWERs
[00012227][01 00] Firmware upgrade finished successfully.
[00012337]Done.
[00012367]Packet [C:\P3X_FW_V01.04.0010.bin] resumed, card sn [0x28113573].
[00012405]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012467]Version checking[2]...
[00012577][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012696][03 06][00] v2.1.6.18 -> v2.3.0.13 need upgrade.
[00012739][04 00][00] v1.38.0.0 -> v1.41.0.0 need upgrade.
[00012781][09 00][00] v1.7.0.3 -> v1.7.0.3
[00012936][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013050][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013160][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013277][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013385][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013519][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013642][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00013802][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00013861][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013893][01 00][05] v1.23.3419 -> v1.23.3419
[00013930][01 01][00] v1.6.2736 -> v1.23.3419 need upgrade
[00013977][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00014008]Done.
[00014041]Firmware upgrading[2]...
[00014182][01 01] Firmware upgrade start...
[00044459][01 01] Firmware upgrade finished successfully.
[00045334][08 00] Firmware upgrade start...
[00587101][08 00] Firmware upgrade finished successfully.
[00587155][12 00] Firmware upgrade start...
[00682031][12 00] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 53, los = 45, ng = 0).
[00712078][12 01] Firmware upgrade start...
[00857386][12 01] Firmware upgrade finished successfully.
[00857438][12 02] Firmware upgrade start...
[00920378][12 02] Firmware upgrade finish failed (step = 4, err = 0xaa, idx = 53, los = 32, ng = 0).
[00950430][12 03] Firmware upgrade start...
[01113100][12 03] Firmware upgrade finish failed (step = 5, err = 0xaa, sum = 0xb68f).
[01143153][17 00] Firmware upgrade start...
[01308299][17 00] Firmware upgrade finished successfully.
[01308435][17 01] Firmware upgrade start...
[01431729][17 01] Firmware upgrade finish failed (step = 5, err = 0xaa, sum = 0x2ede).
[01461773][11 00] Firmware upgrade start...
[01549063][11 00] Firmware upgrade finished successfully.
[01549279][03 06] Firmware upgrade start...
[01882369][03 06] Firmware upgrade finished successfully.
[01882425][04 00] Firmware upgrade start...
[01941752][04 00] Firmware upgrade finished successfully.
[01941787]Done.
[01941820]Version checking[3]...
[01941886][03 05][00] v34.2.0.9 -> v34.2.0.9
[01941946][03 06][05] v2.3.0.13 -> v2.3.0.13
[01941986][04 00][05] v1.41.0.0 -> v1.41.0.0
[01942055][09 00][00] v1.7.0.3 -> v1.7.0.3
[01942147][11 00][05] v1.7.0.0 -> v1.7.0.0
[01942230][12 00][00] v0.0.0.0 -> v1.10.0.0 need upgrade.
[01942321][12 01][05] v1.10.0.0 -> v1.10.0.0
[01942400][12 02][00] v0.0.0.0 -> v1.10.0.0 need upgrade.
[01942477][12 03][00] v0.0.0.0 -> v1.10.0.0 need upgrade.
[01942616][15 00][00] v1.1.2.0 -> v1.1.2.0
[01942700][17 00][00] v0.0.0.0 -> v1.1.1.7 need upgrade.
[01942780][17 01][00] v0.0.0.0 -> v1.0.2.7 need upgrade.
[01942835][19 00][00] v1.0.8.96 -> v1.0.8.96
[01942866][01 00][05] v1.23.3419 -> v1.23.3419
[01942896][01 01][05] v1.23.3419 -> v1.23.3419
[01942945][08 00][05] v0.12.0.4 -> v0.12.0.4
[01942976]Done.
[01943013]Firmware upgrading[3]...
[01943057][12 00] Firmware upgrade start...
[02007178][12 00] Firmware upgrade finished successfully.
[02007232][12 02] Firmware upgrade start...
[02070347][12 02] Firmware upgrade finished successfully.
[02070398][12 03] Firmware upgrade start...
[02130377][12 03] Firmware upgrade finished successfully.
[02130434][17 00] Firmware upgrade start...
[02204028][17 00] Firmware upgrade finished successfully.
[02204077][17 01] Firmware upgrade start...
[02265211][17 01] Firmware upgrade finished successfully.
[02265246]Done.
[02265276]Version checking[4]...
[02265348][03 05][00] v34.2.0.9 -> v34.2.0.9
[02265427][03 06][05] v2.3.0.13 -> v2.3.0.13
[02265544][04 00][05] v1.41.0.0 -> v1.41.0.0
[02265594][09 00][00] v1.7.0.3 -> v1.7.0.3
[02265707][11 00][05] v1.7.0.0 -> v1.7.0.0
[02265801][12 00][05] v1.10.0.0 -> v1.10.0.0
[02265901][12 01][05] v1.10.0.0 -> v1.10.0.0
[02265981][12 02][05] v1.10.0.0 -> v1.10.0.0
[02266081][12 03][05] v1.10.0.0 -> v1.10.0.0
[02266213][15 00][00] v1.1.2.0 -> v1.1.2.0
[02266324][17 00][05] v1.1.1.7 -> v1.1.1.7
[02266437][17 01][05] v1.0.2.7 -> v1.0.2.7
[02266491][19 00][00] v1.0.8.96 -> v1.0.8.96
[02266526][01 00][05] v1.23.3419 -> v1.23.3419
[02266560][01 01][05] v1.23.3419 -> v1.23.3419
[02266610][08 00][05] v0.12.0.4 -> v0.12.0.4
[02266644]Packet upgrade finish successfully.
[00013069]========== remo-con disconnect. boot(15) ============
[00013114]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x28113573].
[00013149]Packet upgrade start...
[00013189]Packet checking...
[00013223]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013259]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00013297]Done.
[00013333]Version checking[1]...
[00013416][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013496][03 06][00] v2.3.0.13 -> v2.3.0.13
[00013537][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013594][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013716][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013804][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013895][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013984][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014084][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014228][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014324][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014444][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014495][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014531][01 00][00] v1.23.3419 -> v1.23.3419
[00014566][01 01][00] v1.23.3419 -> v1.23.3419
[00014622][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014656]Done.
[00016689]Waiting for user confirm...
[00026724]Timeout, start upgrade automatically.
[00026797]Firmware upgrading[1]...
[00026841][11 00] Firmware upgrade start...
[00078978][11 00] Firmware upgrade finished successfully.
[00079016]Done.
[00079052]Version checking[2]...
[00079124][03 05][00] v34.2.0.9 -> v34.2.0.9
[00079198][03 06][00] v2.3.0.13 -> v2.3.0.13
[00079263][04 00][00] v1.41.0.0 -> v1.41.0.0
[00079318][09 00][00] v1.7.0.3 -> v1.7.0.3
[00079441][11 00][05] v1.7.0.0 -> v1.7.0.0
[00079541][12 00][00] v1.10.0.0 -> v1.10.0.0
[00079627][12 01][00] v1.10.0.0 -> v1.10.0.0
[00079712][12 02][00] v1.10.0.0 -> v1.10.0.0
[00079812][12 03][00] v1.10.0.0 -> v1.10.0.0
[00079956][15 00][00] v1.1.2.0 -> v1.1.2.0
[00080047][17 00][00] v1.1.1.7 -> v1.1.1.7
[00080187][17 01][00] v1.0.2.7 -> v1.0.2.7
[00080279][19 00][00] v1.0.8.96 -> v1.0.8.96
[00080319][01 00][00] v1.23.3419 -> v1.23.3419
[00080355][01 01][00] v1.23.3419 -> v1.23.3419
[00080397][08 00][00] v0.12.0.4 -> v0.12.0.4
[00080434]Packet upgrade finish successfully.
[00012647]========== remo-con disconnect. boot(15) ============
[00012681]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xdab93249].
[00012722]Packet upgrade start...
[00012762]Packet checking...
[00012797]Packet vlink 01.05.0030 <-> 01.04.0010.
[00012830]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012863]Done.
[00012898]Version checking[1]...
[00012976][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013036][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00013079][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013196][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013270][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013350][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013425][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013505][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013636][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013700][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013830][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013880][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013915][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00013949][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00014003][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade.
[00014160][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00014202]Done.
[00016237]Waiting for user confirm...
[00026270]Timeout, start upgrade automatically.
[00026347]Firmware upgrading[1]...
[00038503][01 00] Firmware upgrade start...
[00012331][01 00] Firmware upgrade finished successfully.
[00012366]Done.
[00012402]Packet [C:\P3X_FW_V01.05.0030.bin] resumed, card sn [0xdab93249].
[00012447]Packet vlink 01.05.0030 <-> 01.04.0010.
[00012485]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012526]Version checking[2]...
[00012601][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012662][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00012704][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012822][11 00][00] v1.7.0.0 -> v1.7.0.0
[00012916][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013018][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013091][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013187][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013315][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013411][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013531][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013586][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013620][01 00][05] v1.26.4315 -> v1.26.4315
[00013668][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00013721][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade.
[00013788][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00013825]Done.
[00013864]Firmware upgrading[2]...
[00014022][01 01] Firmware upgrade start...
[00044279][01 01] Firmware upgrade finished successfully.
[00045225][08 00] Firmware upgrade start...
[00563781][08 00] Firmware upgrade finished successfully.
[00564044][03 06] Firmware upgrade start...
[00871429][03 06] Firmware upgrade finished successfully.
[00871497][09 00] Firmware upgrade start...
[00942984][09 00] Firmware upgrade finished successfully.
[00943020]Done.
[00943054]Version checking[3]...
[00943126][03 05][00] v34.2.0.9 -> v34.2.0.9
[00943211][03 06][05] v2.4.0.5 -> v2.4.0.5
[00943251][04 00][00] v1.41.0.0 -> v1.41.0.0
[00943466][11 00][00] v1.7.0.0 -> v1.7.0.0
[00943560][12 00][00] v1.10.0.0 -> v1.10.0.0
[00943660][12 01][00] v1.10.0.0 -> v1.10.0.0
[00943760][12 02][00] v1.10.0.0 -> v1.10.0.0
[00943860][12 03][00] v1.10.0.0 -> v1.10.0.0
[00943985][15 00][00] v1.1.2.0 -> v1.1.2.0
[00944075][17 00][00] v1.1.1.7 -> v1.1.1.7
[00944196][17 01][00] v1.0.2.7 -> v1.0.2.7
[00944246][19 00][00] v1.0.8.96 -> v1.0.8.96
[00944287][01 00][05] v1.26.4315 -> v1.26.4315
[00944327][01 01][05] v1.26.4315 -> v1.26.4315
[00944386][08 00][05] v0.13.0.7 -> v0.13.0.7
[00944445][09 00][05] v2.13.0.0 -> v2.13.0.0
[00944482]Packet upgrade finish successfully.
2015-12-1
sploodge
Flight distance : 809350 ft
rox68 Posted at 2015-12-2 00:29
Hi, it's my log file after upgrade.... I do not understand well.... Do you think that upgrade to 1.5 ...
Looks OK..
2015-12-1
EYECON
perseas Posted at 2015-12-1 00:44
Hi mate,
I got my P3 pro last week  with firmware 1.3.20 and I updated directly to 1.5.3 without  ...
Thanks for the quick reply.   I take it you upgraded yours via micro USB too right?  And not through the DJI Go App?
I am a bit confused with the instructions from the DJI download page.  Are we supposed to update teh Firmware via the DJI GO app?  If that is the case, how do we do that?  Connect a cable from the Mobile Device to the DJI Phantom Gimbal?
I'm asking this since all I see from this page are updates using the Micro SD.
2015-12-1
achmad_ariefian
Indonesia
Hi all,
I need a help, my drone starts to drive me crazy. I had thecamera problem (no signal status) on my P3P since I upgrade the FW using 3X_FW_V01.04.0010 on mynew battery couple weeks ago. The upgrade was failed. I tried every possible wayto re try the upgrade (format the micro sd card on the go app, down grade to earlierversion) but doesn’t works. I heard that many people experience the sameproblem. So I wait until DJI release the new FW.
Unfortunately, when the new FW released, it still doesn’t fixthe problem, I try to upgrading the FW P3X_FW_V01.05.0030, it still doesn’t works.The upgrade was failed, the aircraft led turn red with a long beep sound.
The drone was alright, I can turn it on and fly it, but thecamera just doesn’t works. Blank with no signal status.
Does anyone experience the same problem and could finallysolve it?
I live in Indonesia and there is no authorized DJI storehere, so it will be difficult for me to send my drone to DJI nearest DJIauthorized office (Australia/Japan) for checking the problem.
So, any help or advice will greatly appreciated.
This is the LOG from the report, I attached below the otherLOG from the hidden directory
========== 2015.12.02 15:02:17 =====================
Packet: P3X_FW_V01.05.0030.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Result: Failed.
Result: Failed.
Here is the LOG from the hidden directory
[00014899]Packetchecking...
[00014958]Packetvlink 01.05.0030 <-> 01.04.0010.
[00015017]Recordvlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015077]Done.
[00015137]Versionchecking[1]...
[00015230][03 05][00]v34.2.0.9 -> v34.2.0.9
[00015331][03 06][00]v2.4.0.5 -> v2.4.0.5
[00015394][04 00][00]v1.41.0.0 -> v1.41.0.0
[00015531][11 00][00]v1.7.0.0 -> v1.7.0.0
[00015639][12 00][00]v1.10.0.0 -> v1.10.0.0
[00015739][12 01][00]v1.10.0.0 -> v1.10.0.0
[00015839][12 02][00]v1.10.0.0 -> v1.10.0.0
[00015939][12 03][00]v1.10.0.0 -> v1.10.0.0
[00028495][15 00][00]device not detected.
[00028596][17 00][00]v1.1.1.7 -> v1.1.1.7
[00028736][17 01][00]v1.0.2.7 -> v1.0.2.7
[00028816][19 00][00]v1.0.8.96 -> v1.0.8.96
[00028873][01 00][00]v1.26.4315 -> v1.26.4315
[00028931][01 01][00]v1.26.4315 -> v1.26.4315
[00041489][08 00][00]device not detected.
[00041576][09 00][00]v2.13.0.0 -> v2.13.0.0
[00041633]Packetupgrade failed at version checking.
[00014992]==========remo-con disconnect. boot(15) ============
[00015236]Packet[C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x6b0156df].
[00015295]Packetupgrade start...
[00015358]Packetchecking...
[00015418]Packetvlink 01.04.0010 <-> 01.03.0020.
[00015475]Recordvlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015535]Done.
[00015591]Versionchecking[1]...
[00015704][03 05][00]v34.2.0.9 -> v34.2.0.9
[00015805][03 06][00]v2.4.0.5 -> v2.3.0.13
[00015879][04 00][00]v1.41.0.0 -> v1.41.0.0
[00015963][09 00][00]v2.13.0.0 -> v1.7.0.3
[00016104][11 00][00]v1.7.0.0 -> v1.7.0.0
[00016207][12 00][00]v1.10.0.0 -> v1.10.0.0
[00016334][12 01][00]v1.10.0.0 -> v1.10.0.0
[00016534][12 02][00]v1.10.0.0 -> v1.10.0.0
[00016633][12 03][00]v1.10.0.0 -> v1.10.0.0
[00029190][15 00][00]device not detected.
[00029308][17 00][00]v1.1.1.7 -> v1.1.1.7
[00029449][17 01][00]v1.0.2.7 -> v1.0.2.7
[00029523][19 00][00]v1.0.8.96 -> v1.0.8.96
[00029584][01 00][00]v1.26.4315 -> v1.23.3419
[00029640][01 01][00]v1.26.4315 -> v1.23.3419
[00042199][08 00][00]device not detected.
[00042260]Packetupgrade failed at version checking.
[00014721]==========remo-con disconnect. boot(15) ============
[00014783]Packet[C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x6b0156df].
[00014841]Packetupgrade start...
[00014904]Packetchecking...
[00014964]Packetvlink 01.05.0030 <-> 01.04.0010.
[00015022]Recordvlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015080]Done.
[00015142]Versionchecking[1]...
[00015221][03 05][00]v34.2.0.9 -> v34.2.0.9
[00015321][03 06][00]v2.4.0.5 -> v2.4.0.5
[00015388][04 00][00]v1.41.0.0 -> v1.41.0.0
[00015520][11 00][00]v1.7.0.0 -> v1.7.0.0
[00015634][12 00][00]v1.10.0.0 -> v1.10.0.0
[00015734][12 01][00]v1.10.0.0 -> v1.10.0.0
[00015834][12 02][00]v1.10.0.0 -> v1.10.0.0
[00015934][12 03][00]v1.10.0.0 -> v1.10.0.0
[00028492][15 00][00]device not detected.
[00028590][17 00][00]v1.1.1.7 -> v1.1.1.7
[00028731][17 01][00]v1.0.2.7 -> v1.0.2.7
[00028811][19 00][00]v1.0.8.96 -> v1.0.8.96
[00028869][01 00][00]v1.26.4315 -> v1.26.4315
[00028928][01 01][00]v1.26.4315 -> v1.26.4315
[00041491][08 00][00]device not detected.
[00041571][09 00][00]v2.13.0.0 -> v2.13.0.0
[00041629]Packetupgrade failed at version checking.
2015-12-2
admvfaf
Hi everybody, I'm trying to force the firmware to be reinstalled v1.5 but it keeps getting this error: Can anybody point me in the right direction please?
[00014793]========== remo-con disconnect. boot(15) ============
[00014837]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x2810ea66].
[00014876]Packet upgrade start...
[00014916]Packet checking...
[00014954]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015027]Done.
[00015067]Version checking[1]...
[00027607][03 05][00] device not detected.
[00040147][03 06][00] device not detected.
[00040196][04 00][00] v1.41.0.0 -> v1.41.0.0
[00052735][11 00][00] device not detected.
[00065274][12 00][00] device not detected.
[00077812][12 01][00] device not detected.
[00090367][12 02][00] device not detected.
[00102907][12 03][00] device not detected.
[00115447][15 00][00] device not detected.
[00127987][17 00][00] device not detected.
[00140527][17 01][00] device not detected.
[00153070][19 00][00] device not detected.
[00153109][01 00][00] v1.26.4315 -> v1.26.4315
[00153147][01 01][00] v1.26.4315 -> v1.26.4315
[00165687][08 00][00] device not detected.
[00165741][09 00][00] v0.0.0.0 -> v2.13.0.0 need upgrade.
[00165778]Done.
[00167816]Waiting for user confirm...
[00177938]Timeout, start upgrade automatically.
[00178022]Firmware upgrading[1]...
[00178086][09 00] Firmware upgrade start...
[00231544][09 00] Firmware upgrade finished successfully.
[00231582]Done.
[00231623]Version checking[2]...
[00231702][03 05][00] v34.2.0.9 -> v34.2.0.9
[00231777][03 06][00] v2.4.0.5 -> v2.4.0.5
[00231822][04 00][00] v1.41.0.0 -> v1.41.0.0
[00231941][11 00][00] v1.7.0.0 -> v1.7.0.0
[00232037][12 00][00] v1.10.0.0 -> v1.10.0.0
[00232125][12 01][00] v1.10.0.0 -> v1.10.0.0
[00232215][12 02][00] v1.10.0.0 -> v1.10.0.0
[00232336][12 03][00] v1.10.0.0 -> v1.10.0.0
[00244876][15 00][00] device not detected.
[00244966][17 00][00] v1.1.1.7 -> v1.1.1.7
[00245086][17 01][00] v1.0.2.7 -> v1.0.2.7
[00245141][19 00][00] v1.0.8.96 -> v1.0.8.96
[00245179][01 00][00] v1.26.4315 -> v1.26.4315
[00245222][01 01][00] v1.26.4315 -> v1.26.4315
[00257767][08 00][00] device not detected.
[00257823][09 00][05] v2.13.0.0 -> v2.13.0.0
[00257865]Packet upgrade failed at version checking.
Many Thanks
2015-12-2
Fulgerite
So far so good.  My update seems to have gone smoothly.
2015-12-2
Mordorr
Portugal
Today i receive my P3A from Germany RMA.....
Turn it ON than RC on......
My surprise no Signal and RC shows a Red light.
Update RC to 1.5. Suceess. Reboot and still no conection between RC and P3A.
Sorry, i will be offensive, but this is the 2 time i send the P3 to Germany, and i receive it even WORSE than first time.
Thank you DJI for make my life miserabley and a NON- Professional work.
Now, i have something dead here at my home.
Gonna try force 1.4........
Shame on you DJI Service.
2015-12-2
Mordorr
Portugal
Problem solved, thanks to other user on a forum:
- Update DJI app.
- Re-link frequency macth, betwheen RC and P3.
Now, test flights.
BAD GERMANY SERVICE!!! ((((
2015-12-2
perseas
Greece
EYECON Posted at 2015-12-2 08:34
Thanks for the quick reply.   I take it you upgraded yours via micro USB too right?  And not throu ...
The DJI Go app upgrades the rest parts too. The aircraft, the RC, the batteries and the app have different versions and all need to be updated in a certain order as per instructions. I simply followed the tutorial and everything ended smoothly. You have to apply the instructions without any impovisations
2015-12-2
crodit
Singapore
achmad_ariefian Posted at 2015-12-2 17:47
Hi all,
I need a help, my drone starts to drive me crazy. I had thecamera problem (no signal statu ...
Hi Acmad Ariefian.
Im Dody from Indonesia also.
Seems you have same case with me, have no signal after update and blank live feed.
kindly email your contact no to me at crodit@yahoo.com
let see how we can do some work together to  solved this problem
thanks
2015-12-3
admvfaf
Hi Guys,
Is there anyone that could shed some light on this, as DJI support just said to send it to them for them to inpsect, I have just bought it and it has firmware 1.5 DJI pro 3 but I get no video feed, it records fine to the SD and I can watch the videos and check the pictures on the computer.
When I try to re-install the firmware I get this error log:
[00232008]Version checking[2]...
[00232088][03 05][00] v34.2.0.9 -> v34.2.0.9
[00232167][03 06][00] v2.4.0.5 -> v2.4.0.5
[00232215][04 00][00] v1.41.0.0 -> v1.41.0.0
[00232367][11 00][00] v1.7.0.0 -> v1.7.0.0
[00232461][12 00][00] v1.10.0.0 -> v1.10.0.0
[00232560][12 01][00] v1.10.0.0 -> v1.10.0.0
[00232741][12 02][00] v1.10.0.0 -> v1.10.0.0
[00232841][12 03][00] v1.10.0.0 -> v1.10.0.0
[00245389][15 00][00] device not detected.
[00245499][17 00][00] v1.1.1.7 -> v1.1.1.7
[00245635][17 01][00] v1.0.2.7 -> v1.0.2.7
[00245705][19 00][00] v1.0.8.96 -> v1.0.8.96
[00245749][01 00][00] v1.26.4315 -> v1.26.4315
[00245791][01 01][00] v1.26.4315 -> v1.26.4315
[00258341][08 00][00] device not detected.
[00258415][09 00][05] v2.13.0.0 -> v2.13.0.0
[00258469]Packet upgrade failed at version checking.
Many Thanks
2015-12-3
Rob W
Flight distance : 94390 ft
Sweden
Hi,
I just got my Phantom 3 Pro. I haven't checked the current firmware on it yet (just charged the batteries and controller last night, so they are ready), but I guess it's an older one.
Since the latest released firmware does not include battery firmware upgrades, do I need to install an older firmware first, before upgrading to the latest 1.5.0030? If so, which firmware contains the latest battery firmware?
Many thank's in advance,
2015-12-3
sploodge
Rob W Posted at 2015-12-3 10:57
Hi,
I just got my Phantom 3 Pro. I haven't checked the current firmware on it yet (just charged the ...
From what I understand, although you cannot downgrade from say 1.5 to 1.3, 1.3 on an SD card will still "update" a battery if its not current.. This is my understanding but I cannot test it as all my batteries are updated. So even if the aircraft is on 1.5 and you had batteries with an older firmware you could just pop an older firmware 1.3 on the SD and have it update the battery only.
I would love to test this or if DJI could confirm if its the case.
2015-12-3
Rob W
Sweden
sploodge Posted at 2015-12-3 12:59
From what I understand, although you cannot downgrade from say 1.5 to 1.3, 1.3 on an SD card will  ...
Thank's Sploodge. When I get back home from work I will start the Phantom up for the first time, and check the current firmware. I'll guess it would be safe to upgrade one revision at a time if the current firmware is really old, that way I should get a battery update sooner or later
2015-12-3
sploodge
Rob W Posted at 2015-12-3 12:40
Thank's Sploodge. When I get back home from work I will start the Phantom up for the first time, a ...
If its on 1.3 then download that firmware and do any other batteries that you might have the I suggest going to 1.4 then 1.5, it seems to be the most successful route
2015-12-3
imbastos
i have a brand new p3 i believe it came with 1.3 and i upgraded to 1.5.  while in 1.3, my raw images were fine.  now, in 1.5 they have blue/magenta/etc pixelation in the dark areas.  im going to downgrade to 1.4 and back up to 1.5 to hopefully remedy this issue.
2015-12-3
1487kenny
Argentina
Buenas tengo un problemita en mi phantom 3 standard .  les agradecería de corazón si me pueden ayudar por que es mi primer phantom .. y no puedo calibrarlo ni hacerlo andar ... l
les dejo el error q me da .
estado general, actualizaciones necesarias:    se requiere la aeronave para actualizar, por favor marque la actualización del firmware videos tutoriales en la academia
        se requiere la cámara de actualizar, por favor marque la actualización del firmware videos tutoriales en la academia
y no se donde saco el software por que solo encuentro para el advans o profecional
les agradecería la ayudaaa..
2015-12-3
imbastos
imbastos Posted at 2015-12-3 20:00
i have a brand new p3 i believe it came with 1.3 and i upgraded to 1.5.  while in 1.3, my raw images ...
so, i downgraded to 1.4 and the raw images were still horribly pixelated.  then, i upgraded up to 1.5 and the images still remain pixelated and unusable.  anyone else have these issues?  perhaps there's a problem going straight from 1.3 to 1.5?  you can see my samples of what im experiencing in my thread here: http://forum.dji.com/thread-36454-1-1.html
2015-12-3
Rob W
Sweden
sploodge Posted at 2015-12-3 14:02
If its on 1.3 then download that firmware and do any other batteries that you might have the I sug ...
Hi,
I updated to 1.3, 1.4 and lastly to 1.5. At the 1.3 the firmware upgrade "stuck" with the Phantom sending out a constant noise (not the 4 beeps indicating a running upgrade, and not the "Brrrrrrrr, beep, beep" indicating a successful upgrade, but a constant noise(!)). I waited a long time then turned the Phantom off and on again. It continued updating a short time (4 beeps), then came the successful beeps. After that the 1.4 and 1.5 upgrades went well!
Hope the weather will be nice this weekend so I can test fly the Phantom, and also calibrate the X5 on the Inspire.
Wish you all happy flying,
2015-12-3
philml420
When u say phantom 3,does it cover all phantoms? Or like the rest of the posts, phantom 3 truely means phantom 3 all but standard!
2015-12-3
philml420
This forum is agravated!
2015-12-3
headkumquat
Flight distance : 16060 ft
sploodge Posted at 2015-11-30 06:29
Hi, not sure exactly what changed in the P3A in terms of the camera.. Strange that it only failing ...
Hi Sploodge;
took your advice and tried the "reinstall" technique you came up with. Worked like a charm. 1.5 installed with no problems whatsoever. Re-started the quad after update, and it linked with the R/C and GO app. All updates show as current, and the camera update reminder has gone. All calibrations went smoothly, and now I just have to wait for some decent weather to test it.
I don't know how this works, but it did work for me. Huge thanks to you for coming up with this alternative to beating my head against a wall, which didn't seem to be working out too well. I owe you a can of maple syrup.
2015-12-4
sploodge
headkumquat Posted at 2015-12-4 09:16
Hi Sploodge;
took your advice and tried the "reinstall" technique you came up with. Worked like a  ...
You are welcome..
Hope the weather clears up for you.. In the UK it really does not look like I will get to fly much between now and spring, its either rain and/or wind at the moment
2015-12-4
whelliot1
Phantom 3 Advanced
I reformatted the sd card and installed the v1.05.0030 bin on it. I put the sd card in the aircraft ,turn it on and then the gimbal moved then got beeping. Then really quick I got the D DD and green light, but didn't get a txt sheet saying successful. At first something updated but the app says aircraft and camera still need updating. What can be done?
2015-12-5
imbastos
Hi mate,
any issues with your RAW/DNG photo files?
2015-12-5
spencer_hamons
Flight distance : 292208 ft
I would add to check your DJI App version to assure the app is at the latest version as well.  I use my Android tablet with my Phantom, but I use my tablet for all kinds of uses, not only for flying.  Because I travel a lot and am on airplanes with their high-latency Wi-Fi, I have disabled automatic updating of applications (it sucks when trying to get through some emails, and your tablet spends half the flight trying to do useless updates).
I updated my Phantom 3 Pro, and updated my controller, but things weren't working correctly. My battery status showed at 0%, IMU Calibration worked - but never showed progress, just a bunch of weird stuff.  I went into the Play Store, and found there was an update for the DJI app.  Once I did that update, all problems were solved.
I suspect most will never experience this problem as most people have auto-updates enabled on their Android tablets, but wanted to bring this point up in the event anyone else experienced similar problems.
Spencer H.
Angel Fire, NM
2015-12-6
rustya31
I seem to be having a problem with the Phantom 3 Professional Firmware v1.5.0030 update.  I keep getting the solid red indicator and the high pitch noise. LOG file always ends with "Packet upgrade failed at version checking" each time I try. Any advice?
My equipment:
Android App 2.4.2
Remote Controller 1.5.70
Firmware 1.5.30
LOG file:
[00017232]========== remo-con disconnect. boot(15) ============
[00017345]Firmware [C:\DM368Fw.bin] detected, card sn [0x40ce003b].
[00017374][08 00] Firmware upgrade start...
[00526245][08 00] Firmware upgrade finished successfully.
[00526282]Done.
[00013086]========== remo-con disconnect. boot(15) ============
[00013114]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce0bff].
[00013146]Packet upgrade start...
[00013185]Packet checking...
[00013217]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013278]Done.
[00013307]Version checking[1]...
[00013378][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013438][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013480][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013522][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013642][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00013733][12 00][00] v1.10.0.0 -> v1.8.0.0
[00013808][12 01][00] v1.10.0.0 -> v1.8.0.0
[00013898][12 02][00] v1.10.0.0 -> v1.8.0.0
[00013973][12 03][00] v1.10.0.0 -> v1.8.0.0
[00014098][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014168][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00014289][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00014342][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014378][01 00][00] v1.23.3419 -> v1.23.3419
[00014409][01 01][00] v1.23.3419 -> v1.23.3419
[00014457][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014486]Done.
[00016514]Waiting for user confirm...
[00026544]Timeout, start upgrade automatically.
[00026612]Firmware upgrading[1]...
[00026669][17 00] Firmware upgrade start...
[00206919][17 00] Firmware upgrade finished successfully.
[00206967][17 01] Firmware upgrade start...
[00300998][17 01] Firmware upgrade finished successfully.
[00301048][11 00] Firmware upgrade start...
[00353732][11 00] Firmware upgrade finished successfully.
[00353766]Done.
[00353802]Version checking[2]...
[00353882][03 05][00] v34.2.0.9 -> v34.2.0.9
[00353958][03 06][00] v2.2.6.19 -> v2.2.6.19
[00353996][04 00][00] v1.40.0.0 -> v1.40.0.0
[00354062][09 00][00] v1.7.0.3 -> v1.7.0.3
[00354262][11 00][05] v1.7.0.0 -> v1.7.0.0
[00354359][12 00][00] v1.10.0.0 -> v1.8.0.0
[00354436][12 01][00] v1.10.0.0 -> v1.8.0.0
[00354511][12 02][00] v1.10.0.0 -> v1.8.0.0
[00354601][12 03][00] v1.10.0.0 -> v1.8.0.0
[00354728][15 00][00] v1.1.2.0 -> v1.1.2.0
[00354808][17 00][05] v1.1.1.7 -> v1.1.1.7
[00354927][17 01][05] v1.0.2.7 -> v1.0.2.7
[00354981][19 00][00] v1.0.8.96 -> v1.0.8.96
[00355018][01 00][00] v1.23.3419 -> v1.23.3419
[00355049][01 01][00] v1.23.3419 -> v1.23.3419
[00355097][08 00][00] v0.12.0.4 -> v0.12.0.4
[00355130]Packet upgrade finish successfully.
[00015122]========== remo-con disconnect. boot(15) ============
[00015155]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x28508ba1].
[00015195]Packet upgrade start...
[00015232]Packet checking...
[00015266]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015300]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015339]Done.
[00015372]Version checking[1]...
[00015444][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015504][03 06][00] v2.2.6.19 -> v2.4.0.5 need upgrade.
[00015544][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015644][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015733][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015814][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015898][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015979][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028517][15 00][00] device not detected.
[00028590][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028715][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028769][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028802][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00028836][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00041379][08 00][00] device not detected.
[00041431][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00041464]Done.
[00043497]Waiting for user confirm...
[00053536]Timeout, start upgrade automatically.
[00053599]Firmware upgrading[1]...
[00064733][01 00] Firmware upgrade start...
[00042575]Packet upgrade failed at resume checking.
[00015049]========== 2015.12.06 14:15:15. boot(15) ============
[00015083]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x28508ba1].
[00015121]Packet upgrade start...
[00015160]Packet checking...
[00015196]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015232]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015270]Done.
[00015304]Version checking[1]...
[00015371][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015435][03 06][00] v2.2.6.19 -> v2.4.0.5 need upgrade.
[00015478][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00015571][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015669][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015744][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015830][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015935][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028471][15 00][00] device not detected.
[00028557][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028677][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028737][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028769][01 00][00] v1.26.4315 -> v1.26.4315
[00028810][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00041348][08 00][00] device not detected.
[00041398][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00041434]Done.
[00043472]Waiting for user confirm...
[00053505]Timeout, start upgrade automatically.
[00053571]Firmware upgrading[1]...
[00053697][01 01] Firmware upgrade start...
[00083923][01 01] Firmware upgrade finished successfully.
[00084125][03 06] Firmware upgrade start...
[00410361][03 06] Firmware upgrade finished successfully.
[00410419][09 00] Firmware upgrade start...
[00481901][09 00] Firmware upgrade finished successfully.
[00481963][04 00] Firmware upgrade start...
[00541114][04 00] Firmware upgrade finished successfully.
[00541155]Done.
[00541188]Version checking[2]...
[00541270][03 05][00] v34.2.0.9 -> v34.2.0.9
[00541345][03 06][05] v2.4.0.5 -> v2.4.0.5
[00541389][04 00][05] v1.41.0.0 -> v1.41.0.0
[00541504][11 00][00] v1.7.0.0 -> v1.7.0.0
[00541584][12 00][00] v1.10.0.0 -> v1.10.0.0
[00541738][12 01][00] v1.10.0.0 -> v1.10.0.0
[00541818][12 02][00] v1.10.0.0 -> v1.10.0.0
[00541893][12 03][00] v1.10.0.0 -> v1.10.0.0
[00554432][15 00][00] device not detected.
[00554511][17 00][00] v1.1.1.7 -> v1.1.1.7
[00554640][17 01][00] v1.0.2.7 -> v1.0.2.7
[00554690][19 00][00] v1.0.8.96 -> v1.0.8.96
[00554725][01 00][00] v1.26.4315 -> v1.26.4315
[00554761][01 01][05] v1.26.4315 -> v1.26.4315
[00567295][08 00][00] device not detected.
[00567351][09 00][05] v2.13.0.0 -> v2.13.0.0
[00567387]Packet upgrade failed at version checking.
[00014524]========== 2015.12.06 15:00:28. boot(15) ============
[00014556]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x28508ba1].
[00014589]Packet upgrade start...
[00014633]Packet checking...
[00014669]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014704]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014739]Done.
[00014779]Version checking[1]...
[00014858][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014939][03 06][00] v2.4.0.5 -> v2.4.0.5
[00014983][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015100][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015186][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015267][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015358][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015466][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028005][15 00][00] device not detected.
[00028112][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028221][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028296][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028335][01 00][00] v1.26.4315 -> v1.26.4315
[00028368][01 01][00] v1.26.4315 -> v1.26.4315
[00040901][08 00][00] device not detected.
[00040962][09 00][00] v2.13.0.0 -> v2.13.0.0
[00040997]Packet upgrade failed at version checking.
[00015112]========== remo-con disconnect. boot(15) ============
[00015147]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x28508ba1].
[00015182]Packet upgrade start...
[00015220]Packet checking...
[00015262]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015386]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015421]Done.
[00015461]Version checking[1]...
[00015529][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015610][03 06][00] v2.4.0.5 -> v2.4.0.5
[00015659][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015774][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015868][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015969][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016068][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016168][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028705][15 00][00] device not detected.
[00028799][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028943][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028990][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029028][01 00][00] v1.26.4315 -> v1.26.4315
[00029065][01 01][00] v1.26.4315 -> v1.26.4315
[00041599][08 00][00] device not detected.
[00041670][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041706]Packet upgrade failed at version checking.
[00014629]========== remo-con disconnect. boot(15) ============
[00014673]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x28508ba1].
[00014712]Packet upgrade start...
[00014753]Packet checking...
[00014794]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014831]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014864]Done.
[00014900]Version checking[1]...
[00014976][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015032][03 06][00] v2.4.0.5 -> v2.4.0.5
[00015074][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015195][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015285][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015392][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015485][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015565][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028112][15 00][00] device not detected.
[00028200][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028342][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028400][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028438][01 00][00] v1.26.4315 -> v1.26.4315
[00028481][01 01][00] v1.26.4315 -> v1.26.4315
[00041020][08 00][00] device not detected.
[00041082][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041194]Packet upgrade failed at version checking.
2015-12-6
g3n0n
Kazakhstan
rustya31@gmail. Posted at 2015-12-7 04:40
I seem to be having a problem with the Phantom 3 Professional Firmware v1.5.0030 update.  I keep get ...
Same issue for me, please keep updating if you find any solution.
2015-12-7
g3n0n
Kazakhstan
Hi all, first of all thanks Sploodge for this manual,
Please I need help with my issue - I cannot update 1.5 firmware for aircraft - red LED is solid red and also solid DDDDD signal.
Complete details here
http://forum.dji.com/forum.php?mod=viewthread&tid=36557
What I already did:
Updated iOS and Android apps,
Reset iOS and Android device
Updated RC without any issues
Tried to format and use other SD card - didnt help
Jerry also suggested to start firmware update with pressing Link buttojn - didn't help
Trtied to downgrade to 1.4 and 1.3 - same result, shorts beeps as ussual firmware update starts and the solid D and Red light on the camera.
Does somebody know how to make factory reset? or some other radical option. For example - put it into the fireplace, wait a bit, go to sleep.
2015-12-7
perseas
Greece
imbastos Posted at 2015-12-6 04:27
I haven't checked it yet, thanks for the notice.
2015-12-7
perseas
Greece
As I comprehended it, you update everything through the DJI Go app and the micro USB, I didn't see any reference to mobile device connected to gimbal. The instructions are pretty clear to me and every step is described separately. Did you upate your P3 sucessfully or you decided to remain to the older version?
2015-12-7
mvn591014
Flight distance : 38537 ft
acenothing Posted at 2015-11-23 12:55
Wow so many responses and yet I have no idea what this was about.  What are you all talking about?
Nothing acenothing.
Just go back to sleep and put away your DJI Phantom, if you have one.
2015-12-12
mvn591014
DJI-Patrick Posted at 2015-11-23 22:39
Hi ,sploodge
The new firmware is going to be released in a few hours . Everything is fine !
New firmware and new screwup problems. I see.
2015-12-12
whelliot1
Hello sploodge
I have tried all of these thing and still the camera and aircraft still need updates. I never got a txt file saying anything and I did everything on your thread. What can I do?
Thanks
2015-12-12
stephenshea
Hi,
Another case off device 15 and 08 - device not detected - failed update...
Tried reinstalling about 10 times, with different cards, reformatting card in Dji App.  Leaving it on for 30 minutes+
Tried downgrading to 1.4 won't install...tried with RC on first (suggested on another forum) - no luck with that.
Any other suggestions would be appreciated, my Phantom is about a month old and has less than 5 hours off flight time on it...
Stephen
2015-12-13
Kleeprop
Eswatini
stephenshea Posted at 2015-12-13 18:43
Hi,
Hey folks,
I changed my main board this weekend due to an ESC error and in trying to re-start my drone I went through the firmware update process.  Now I can't get the initial B - B - B to stop but the firmware upgrade seems to have been successful.  I've even tried downgrading to 1.4.1 (which seemed to have worked) and then re-upgrading.  My iPhone says everything is updated and normal, the light on the gimbal took less than 5 minutes to turn green, the GPS locks on, the camera works, the LEDs give the right indications ... everything indicates all is well - but I can't get it to stop the B - B - B.  I've included a 10s video of what it does ... by the HOUR ... without ever changing.  If I try to start the motors with the beeping going, I get the dreaded ESC error I got before.  Can anybody offer any advice?  I just want to make sure it's not a firmware issue before doing anything else.  I've looked at the hidden log file and it seems to be good, can somebody confirm?  I've included part of it as well.   HELP!!!!
[00012161]========== 2015.12.13 23:48:27. boot(15) ============
[00012305]Packet [C:\P3S_FW_V01.05.0030.bin] detected, card sn [0x28ef038c].
[00012369]Packet upgrade start...
[00012435]Packet checking...
[00012500]Packet vlink 01.05.0030 <-> 01.04.0010.
[00012566]Record vlink 01.05.0030 <-> 01.04.0010 (flow = 0).
[00012631]Done.
[00012697]Version checking[1]...
[00012810][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012911][03 06][00] v2.4.0.5 -> v2.4.0.5
[00012990][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013126][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013239][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013334][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013435][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013535][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013603][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013715][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013870][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013956][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014022][01 00][00] v1.22.4095 -> v1.22.4095
[00014087][01 01][00] v1.22.4095 -> v1.22.4095
[00014179][09 00][00] v2.13.0.0 -> v2.13.0.0
[00014246]Packet upgrade cancelled at version checking.
2015-12-13
DJI-Patrick
stephenshea Posted at 2015-12-14 00:43
Hi,
Hi , Stephen
Please contact your dealer or repair center about that . I'm afraid you'll have to send it back for a repair .
2015-12-14
DJI-Patrick
mvn591014@gmail Posted at 2015-12-13 01:59
Hi , Sir
PLEASE kindly tell us what troubles you about the phantom 3 . We'll try to help you !
2015-12-14
gb
Sweden
DJI-Patrick Posted at 2015-12-14 12:47
Hi , Sir
I got the vibration as well.
Downgraded and upgraded IMU cal.
Did not help :-(
2015-12-15
