quanthonytrang
Flight distance : 419980 ft
It will idle nicely on a table. The vibrations/oscillation will transfer to the table. Observe the camera when hovering near you. Also the camera footage will no show as the gimbal should be good enough to minimise the 'jello'.
I cant test on mine as I still have the old firmware.
But those with issues, can you please look at your vertical gains. Go MC settings > Gain Expo Tuning > Scroll down to Gains > and change your vertical to 80 / 90 / 100 / 110 / 120 and see which is the sweet spot. Default is 100%.
My theory, as mentioned before, is that DJI had been testing the firmware on the newer P3 with the efficient motors and updated ESC. If that's the case, then the ESC firmware may have a different rpm/resonance.
