Phantom 3 standard loud beeping noise
123
42066 107 2015-12-24
ben_drone_P3
DJI-Ken Posted at 2015-12-31 10:08
I am trying to assist you, can you make a video of you trying to update. I'm still not totally fol ...
I am not currently with my aircraft so I will make a video when I get there
2015-12-30
ben_drone_P3
ben_drone_P3 Posted at 2015-12-31 10:22
What do you want me to take a video of?
2015-12-30
DJI-Ken
Flight distance : 1515312 ft
ben_drone_P3 Posted at 2015-12-31 10:23
Of the Phantom during the update process. I don't get why it's not updating.
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-31 10:42
Do you mean just when I turn it on? Because I do not have the update button on the DJI go app. Do I leave the aircraft on connected to the remote or not? And are you able to share with me a .bin file because I believe mine is corrupt.
2015-12-30
DJI-Ken
Go to the general settings and scroll down to About and tell me what the aircraft firmware says. The latest update is 1.3.0050
First you said the aircraft was totally fine but just the gimbal wheel did not make the camera tilt up/down.
Now you're saying that the aircraft won't fly. I'm trying to figure out what you are doing wrong.
And there is no BIN file for the Phantom Standard, it is updated through the app. You have to have internet to download the firmware to the app. Then follow the instructions in the app to update.
When you power it up, in the "Aircraft State" menu and overall status, does it say upgrade required?
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-31 11:16
Go to the general settings and scroll down to About and tell me what the aircraft firmware says. The ...
The aicraft firmware says unknown, the only thing I can control the aircraft with through the remote is taking photos and videos but I cannot move the camera up and down. There is no option for me to upgrade the aircraft through the DJI go app and before formatting the SD card, it I need to update (but there was still no upgrade button) and now after formatting the SD card the aircraft status on the DJI go app is normal and it does not say firmware upgrade required.
2015-12-30
DJI-Ken
There is no formatting the SD card for update, again the Phantom Standard does not update from the SD card it ONLY updates through the GO App. You may have bricked your system because you tried to install the Phantom Advance BIN file onto your Standard.
You need to call tech support tomorrow and send it in for repair. 818-235-0789.
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-31 11:34
There is no formatting the SD card for update, again the Phantom Standard does not update from the S ...
What is the point of formatting the SD card?
2015-12-30
ben_drone_P3
It was beeping before I tried to manually put a .bin file on it.
2015-12-30
DJI-Ken
ben_drone_P3 Posted at 2015-12-31 11:38
ok, call support tomorrow and send it i for repair.
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-30 20:39
Wouldn't it just be easier for me to return it because it is still under warranty?
2015-12-30
DJI-Ken
ben_drone_P3 Posted at 2015-12-31 11:42
Yes, then return it from where you bought it from. If you bought it from DJI then there is a 7 day return.
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-30 20:46
Yes, then return it from where you bought it from. If you bought it from DJI then there is a 7 day ...
Is it tipicaly an exchange or just a cash back if I go to the store I bought it from?
2015-12-30
DJI-Ken
ben_drone_P3 Posted at 2015-12-31 11:52
I don't know, you need to take it to the store you bought it from and ask them.
Good Luck.
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-30 20:56
Good Luck.
All right, thank you very much for all of your help.
2015-12-30
DJI-Ken
ben_drone_P3 Posted at 2015-12-31 11:57
Thanks, and again good luck.
2015-12-30
ben_drone_P3
DJI-Ken Posted at 2015-12-31 11:59
Ken - Could you diagnose my issue or do I have to call?
2015-12-31
DJI-Ken
ben_drone_P3 Posted at 2016-1-1 12:38
I already tried to assist you for several days, it's best you return your Phantom and get another one or send it in for repair.
You can can call the support center Monday.
2015-12-31
ben_drone_P3
DJI-Ken Posted at 2016-1-1 12:41
I already tried to assist you for several days, it's best you return your Phantom and get another  ...
I just don't want to show up to the store and have them say they can't do anything. Could I send it in for repair without having someone officially diagnose a problem because I know it does not work?
2015-12-31
DJI-Ken
ben_drone_P3 Posted at 2016-1-1 12:43
I just don't want to show up to the store and have them say they can't do anything. Could I send it ...
Call the store and see if you can return it.
2015-12-31
ben_drone_P3
DJI-Ken Posted at 2016-1-1 12:46
Alright, thanks.
2015-12-31
rshipman3
Flight distance : 325725 ft
ben_drone_P3 Posted at 2015-12-30 12:06
What do you mean by start over from scratch? Was the upgrade button available for you on the app wh ...
The initial update failed at about 30% complete and then the beeping started.  So I shut everything down and the next day I started the update again from the beginning and it beeped all the way through until the end when the program said the update was complete.  I'm not sure what you mean by update button.  Anyway, it seems to have worked, but it doesn't seem like that should have been normal procedure.
2016-1-5
ben_drone_P3
rshipman3 Posted at 2016-1-5 23:02
The initial update failed at about 30% complete and then the beeping started.  So I shut everythin ...
The phantom 3 standard only upgrades via the DJI go app and the button to upgrade was not there for me, anyhow, I have sent my aircraft to DJI and they will hopefully have it fixed soon.
2016-1-21
wulkie
Romania
This is how it worked for me:
Issue started when I was prompted to upgrade software. At 50% it crashed and after that you can no longer get rid of those loud beeps.
This is what I did:
-        Updated firmware: 2 or 3 times it went really fast, like 2 minutes, with a message successfully updated but beeps did not stop and in the camera view I kept getting the notification that I need to upgrade. Conclusion: id tit not upgrade
-        Format to FAT32 – not sure this has anything to do with it
-        At another try it started quite slow with the update and failed at around 24%. I was prompted to restart but I didn’t
-        I started again the upgrade, really slow. During all this time it beeped like crazy and with every beep motors and gimbal got powered for a few milliseconds but without turning.
-        At 48% it seemed to have stopped but I waited for more than 10 minutes and I started to see 49% 50% etc…
-        At 55% all that loud noise stopped and I could only hear the soft bzzz bzzz sounds that are normal during the update
-        After 10 more minutes it was successfully updated and ready to fly.
Hope it works for you too
2016-3-19
mcphipps900
wulkie Posted at 2016-3-19 05:44
  Issue started when I was prompted to upgrade software. At 50% it c ...
This is just about what happened to me.
I purposely stayed out of this thread while DJI was trying to help. It just gets very confusing when 15 people are trying to tell you what to do. It becomes a cluster f*ck.
The standard for me has always taken a long time for an update. Although the Standard hasn't had as many updates as the other models.
Mine will usually stop at around 44% , for about 10 minutes. It will beep like you are  standing on it's  tail for about ten minutes. Sometimes longer. Usually it will beep through out the whole process if you had to abort the update from it failing.
Also I had a problem with using an android device to load the update. This was the first time I used DJI GO on an android device to update the bird. After it failed two times, I switched to my Ipad to do the update. I had to let the GO app download the update firmware like normal. Did the update using the Ipad. Had zero issues.
That was my experience with this latest update. Hope this information will help you out.
Mike
2016-3-19
zezul
Flight distance : 266243 ft
Russia
New Phantom 3  standard. firmware failed.loud beeping noise.the lights are off.Wi fi connection is not an aircraft.help me
2016-3-26
sloneczny40
Poland
I was in the same situation. Try to get to the microSD card firmware file. You can find them on your phone in DJI folder (android). Leave it for about 30 minutes. It helped me.
2016-3-27
zezul
Russia
Phantom 3 standard has no micro SD card slot, the card is inserted only in the professional and advans.Standart only updated wifi. I make a copy from the phone to the laptop file that loaded Dji go before upgrading (P3C_FW_V01.04.0060.bin) 63,3m. Trying to bridge the phantom to the micro usb laptop and copy this file to the aircraft
2016-3-28
123
