x5 on s900 s920 s1000
123
16847 87 2016-1-2
ducpeter
Flight distance : 62175 ft
i already answered  we use 6S 22,2V connection with XT30 to XT60 on the mainboard from S900/1000
2017-1-29
Nilsblix
Flight distance : 23047543 ft
katarinaconnors Posted at 2017-1-29 09:36
No one answered the power requirement as far as i can see??  Please
It is solved - you can use the 6s lipo current
2017-1-29
nicholasbowersm
Flight distance : 5282280 ft
New Zealand
Can you use 4s and or up to 8s as a power supply?  I have a custom build that can use 4s to 8s....
2017-2-8
fans00d93ffc
Flight distance : 1250728 ft
duzak.darryl@gm Posted at 2016-6-22 09:23
So let's see. The x5 series is compatible w LB2. The LB2 is compatible w a2. But somehow, the a2 isn't compatible w x5? I don't see how that's possible. In fact, I will be doing extensive testing immediately.
Hi,
Have you made any head way with the A2 - LB2 and X5 camera connections?  My first look, it seems that  a CAN1 cable is needed to connect to the top of camera mount.  The cable is available IF you have the A3 controller.  For the A2 the CAN1 connectors are different.
I thought I also saw that LB2 is powered by the A3 controller.  If the LB2 is used with the A2 controller, LB2 is powered by the Z15 gimbal
Buying a new controller is was bloody waste of money if these are the only 2 issues that need to be resolved.
2017-7-17
bougat
why make us buy an FC each time a new camera shows up. so make the FC affordable
2018-2-19
Dragon-Fly
Good afternoon friends
I would like to know if there is finally some type of configuration possible to adapt the Zenmuse X5, X5S, X5R ... in the Dji S1000
Has anyone managed to make this configuration and work with it?
Thanks a lot
2020-12-30
Rudi Bruyninckx
Belgium
Dragon-Fly Posted at 2020-12-30 05:49
Hi there, I am also converting a S 1000/A3/LB2/X5.
Did You got it working OK.
I am still a bit afraid to power the X5 with 6S 22.2V
2021-2-15
Willie69
duzak.darryl@gm Posted at 2016-7-23 11:07
I have my s1000+/A3/LB2/X5R combo working perfectly!! What a setup. Man. I can't believe how well it all goes together.[Image]
Hi I wonder if you could help please.I realise it is a long time ago but I just built the exact same drone and not sure if the X5 would work on my 6 cell 22.2 v Battery.Can you please confirm the battery voltage for your X5 gimbal please?
2022-4-19
123
