x5 on s900 s920 s1000
123Next >
16855 87 2016-1-2
duzak.darryl
Arrow1969...what flight controller were you using for this setup? I'm doing the exact same build w my s1000/LB2/A2/x5r.
2016-6-21
DJI-Jamie
Flight distance : 112405 ft
duzak.darryl@gm Posted at 2016-6-22 03:32
Arrow1969...what flight controller were you using for this setup? I'm doing the exact same build w m ...
Arrow is using the A3 flight controller. Please be advised that the A2 does not support the X3/X5/XT mounting kit.
2016-6-21
nomad65
DJI-Jamie Posted at 2016-6-22 05:46
Arrow is using the A3 flight controller. Please be advised that the A2 does not support the X3/X5/ ...
DJI Jamie , is there anything in the pipeline that would upgrade the A2 / data link , that would make it compatible with the X mount ?
Thank you
2016-6-22
DJI-Jamie
nomad65 Posted at 2016-6-23 00:08
DJI Jamie , is there anything in the pipeline that would upgrade the A2 / data link , that would m ...
Unfortunately, the X mount is not expected to have backwards compatibility at this time.
2016-6-22
duzak.darryl
So let's see. The x5 series is compatible w LB2. The LB2 is compatible w a2. But somehow, the a2 isn't compatible w x5? I don't see how that's possible. In fact, I will be doing extensive testing immediately.
2016-6-22
nomad65
duzak.darryl@gm Posted at 2016-6-22 18:23
So let's see. The x5 series is compatible w LB2. The LB2 is compatible w a2. But somehow, the a2 isn ...
Hi , how did you get on with the testing ?
2016-6-30
jem
Flight distance : 1696788 ft
Arrow1969 Posted at 2016-6-18 18:29
Some more photos from this afternoon.
Nice build, I'm just about to do exactly the same thing. All the parts have just arrived today including a x5r.
I just had a couple of question. Why did you mount the A3 on the top plate. There is room for in on top of the round connector cover but I'm not sure if it would be secure on it or free from vibrations. Also I think the feed to the x5 mounting plate is 18v, is that correct?
I'll post some photo's when I've completed it.
Cheers
2016-7-5
Arrow1969
Flight distance : 400577 ft
jem@marryat.co. Posted at 2016-7-5 12:16
Nice build, I'm just about to do exactly the same thing. All the parts have just arrived today inc ...
Hi
The reason it's mounted on the top is the A3 runs quite warm it need cooling you are not going to get that if you mount in the middle, the M600 also runs the A3 has a cooling fan.
Regarding the 18v I have had confirmation from DJI that it will run on 22v.
Have now done over 2 hours flying no vibration problems whatsoever.
2016-7-5
jem
Arrow1969 Posted at 2016-7-5 13:48
Hi
The reason it's mounted on the top is the A3 runs quite warm it need cooling you are not going ...
Cheers. Good to know about the A3 and heat. I do like to have all the bits inside so i may fit a cooling fan, although with current UK weather I don't think heat is too much of a problem.
2016-7-5
Arrow1969
jem@marryat.co. Posted at 2016-7-5 15:31
Cheers. Good to know about the A3 and heat. I do like to have all the bits inside so i may fit a c ...
One of the DJI tec guys wared me off from putting it inside, I thank the summer has gone so it's not going to be a problem
Cheers
Tony
2016-7-5
kuau714
Arrow1969 Posted at 2016-7-5 09:24
One of the DJI tec  guys wared me off from putting it inside, I thank the summer has gone  ...
Tony.
I am awaiting the arrival of the Matrice X5 mounting plate from DJI so I can mount my X5 on my S900/A3/LB2 just like you did.
Did you load the X5 firmware found on the Matric 600 support page?
Steve
2016-7-6
kuau714
I got my mounting plate today and put it all together, Tony.... I have no power to LB2 on the S900. I am using the included gimbal cable that goes to LB2 and the X5, the Dbus cable going to the A3 and the other cable that goes to Canbus 1. I also changed the X30 power connector to an X60 so I could plug in the X5 direct to the bottom of my S900.
No power to my LB now.. Ugh.....
2016-7-7
Arrow1969
kuau714 Posted at 2016-7-8 01:03
I got my mounting plate today and put it all together, Tony.... I have no power to LB2 on the S900.  ...
Hi,
Can you post me some photos of your wiring connections???
Cheers Tony
2016-7-8
kuau714
Arrow1969 Posted at 2016-7-8 07:08
Hi,
I just did my first test flight today with my S900/A3/LB2/X5 all worked fine, still having an issue with my A3 and my S900 for no reason goes into return home after about 4 minutes of flight time.
on my second flight I made s bad mistake, when I landed somehow I pushed the throttle and I flipped my S900, breaking some props and the X5 gimbal detached, no damage to the X5 but I broke the
Gimbal Attitude Cable
Is this cable available to order I do I have to order a whole new X5 mounting kit?
2016-7-11
Arrow1969
kuau714 Posted at 2016-7-12 02:14
I just did my first test flight today with my S900/A3/LB2/X5 all worked fine, still having an issu ...
Hi kuau714,
Sorry to hear you had a mishap, I can't get my return home to work must admit have not tried it from the Go app yet perhaps DJI-Jamie can help you with cable.
Cheers Tony
2016-7-11
Rob W
Flight distance : 94390 ft
Sweden
Hi,
Trying to read through the posts here. I've got an original S900, A2, Lightbridge 1 and a Futaba T8FGS. (Also have Inspire with an X5 and X5R)
In order to update the S900 to fly the X5 or X5R, I'll need:
1. An A3 flight controller.
2. Matrice X5 Gimbal kit.
3. Lightbridge 2.
Is that it? Do I need to but in a BEC somewhere in the powerline, or will it work directly? Do I have to make modifications on the gimbal plate?
2016-7-11
DJI-Jamie
Rob W Posted at 2016-7-12 15:15
Hi,
Trying to read through the posts here. I've got an original S900, A2, Lightbridge 1 and a Futab ...
You should try to follow the guidelines that are on page 64 of the M600 manual:
https://dl.djicdn.com/downloads/ ... _v1.0_en_160523.pdf
That will give you advice on how to deal with the power issue.
2016-7-14
Rob W
Sweden
DJI-Jamie Posted at 2016-7-14 22:17
https://dl.djicdn ...
Thank's, Jamie!
2016-7-16
chsi
Flight distance : 104695 ft
Hi Arrow 1969,
Nice platform setup what are you getting for flight times? And what size of lipo battery are using? As you know DJI claims approximate 28% increase in flight time and lift capacity. Any info would be appreciated.
Thanks
2016-7-20
DJI-Jamie
You're welcome.
2016-7-21
duzak.darryl
I have my s1000+/A3/LB2/X5R combo working perfectly!! What a setup. Man. I can't believe how well it all goes together.
2016-7-23
tdnatris
Flight distance : 364347 ft
Just curious: whats the total weight of the latest config posted?
2016-8-11
paulykins
Flight distance : 2538474 ft
Dont suppose anyone who has done the plate mod for the S1000+ has a template for it ??
2016-8-20
kuau714
Question, I have been flying my S900/A3/LB2/X5 setup successfully, Should I be upgrading the X5 firmware from the Matrice 600 download page?
I got my X5 from a Inspire 1 pro.
I assume if there was an update for the inspire 1, I could not perform that update because the X5 is not connected to an inspire 1.
Just need clarification
2016-9-2
DJI-Jamie
kuau714 Posted at 2016-9-3 00:40
Question, I have been flying my S900/A3/LB2/X5 setup successfully, Should I be upgrading the X5 firm ...
You do an an Inspire 1, correct? The X5 firmware itself is the same throughout the various platforms it can be used on. The X5 upgrade packet on the Inspire is the same with the M600 page.
2016-9-2
kuau714
DJI-Jamie Posted at 2016-9-2 11:06
You do an an Inspire 1, correct? The X5 firmware itself is the same throughout the various platform ...
I do not have an inspire 1 anymore. I kept the X5 from it.
So which if any firmware would I choose to upgrade my X5?
I downloaded both the M600 X5 FW and the Inspire 1 FW. They are differnt.
WM610_FC550_FW_V01.09.01.30.bin Inspire 1
MATRICE600_FC550_FW_V01.09.01.10.bin Matrice 600
Looking at this the Inspire 1 is newer.
2016-9-2
DJI-Jamie
kuau714 Posted at 2016-9-3 03:03
So which if any firmware would I choose  ...
You can use the following video to upgrade the X5 on the M600:
2016-9-2
kuau714
DJI-Jamie Posted at 2016-9-2 15:25
https://www.youtube.com/watch?v=sk ...
Jamie,
Yes I watched this video but which FW file should I use?
2016-9-2
DJI-Jamie
kuau714 Posted at 2016-9-3 07:20
Jamie,
Since you no longer have an Inspire, you would use the M600 file.
2016-9-2
kuau714
DJI-Jamie Posted at 2016-9-2 21:08
Jamie,
Are you sure, Ken and Ed say differently and the only way to up X5/X5R FW is either on a Inspire or M600
Can you please verify.
Thanks
2016-9-6
DJI-Jamie
kuau714 Posted at 2016-9-7 02:05
Jamie,
Are you sure, Ken and Ed say differently and the only way to up X5/X5R FW is either on a In ...
There may have been some miscommunication, I apologize. In regards to the standalone A3 system, the X3/X5 camera update option has not been made available. Updating the camera is currently only available with Inspire 1 and M600 set ups.
2016-9-6
kuau714
DJI-Jamie Posted at 2016-9-6 16:16
There may have been some miscommunication, I apologize. In regards to the standalone A3 system, the ...
Jamie,
Thanks for the clarification.
What about if I have an OSMOS?
2016-9-6
DJI-Jamie
kuau714 Posted at 2016-9-7 08:43
Jamie,
If you have an OSMO handle, then you can upgrade the camera that way as well.
2016-9-7
7IfEfTmcj9mG
Hi guys,
I am about to start an S900/A3 Pro/LB2/X5 build and wanted to know if there are any limitations currently that I should be aware of?
Ive been told I'll need to make up a 90º XT60 connector for the A3, and that I'll need some new JST wires as the ones that come with the A3 only work with the M600.
Additionally I have been told to look into glueing the X plate on the S900 landing gear, but also have heard its not really an issue if using the X5.
Any advice would be greatly appreciated and of course I will document the build into a tutorial for future builders to use.
One last thing, does anyone have the torque rangers to be used for the various different screws? I have a decent driver with a 0.2-1.4NM range and also have the 4200 Loctite.
2016-9-9
user9b1fc8a9d7
Flight distance : 263796 ft
Indonesia
Not sure where else to post this. I would like to buy an Align G3 gimbal for my s900 so have more camera/lens combo options for still photography. Anyone know if there is an adapter available? The align gimbal is made for rails with 135mm spacing and my s900 has 155mm spacing between the rails.
Thanks!
2016-10-15
fans9c9bcaa2
Pakistan
Will s900+ a2+z3+m600 gimbal installation bracket work together?
Just want to confirm if zenmuse z3 will give pitch functionality while used with a2.
2016-11-23
Sound Construct
Flight distance : 3784278 ft
Denmark
Hey I am interesting to know if it's still okay to run the x5 camera on 22,1 V from the
S1000 or do I need a Bec to make the 18 V
2017-1-15
fans3f39f9f6
yes you can run it off 6s battery
2017-1-15
katarinaconnors
So what was the voltage solution requirement  to this ...the start of the discussion..  regulator .. separate battery or is 22 v. Workable?
Thanks
2017-1-29
katarinaconnors
nilsblix@gmail. Posted at 2016-5-31 14:01
Great - You followed up on this  - thank you.
The power source q is still not solved - I wonder what power the x cameras get on the Inspire ? Could someone with a good voltmeter check it out ?
Anyway - it is two (at least) possibillities : 1 The x series can handle the 6s voltage, 2 We can use a BEC and step down the 6s Voltage to 18 volt.
No one answered the power requirement as far as i can see??  Please
2017-1-29
123Next >
