fans987d278a
Flight distance : 124180 ft
Bruce Bodnyk Posted at 2017-4-28 05:16
I've been using the Litchi app for sometime and don't use the DJI Go at all. While Litchi allows you to create missions, it can be time consuming for complex missions. Having a programming background, I decided to create an application I'm calling the Waypoint Path Generator to be able to programmatically create paths for a drone to follow. The following are a set of Youtube videos I've created to demonstrate the program.
Waypoint Path Generator - Circular/Helical Paths
MicroB - Using Litchi once you upload the waypoint mission to your bird, it will fly the entire mission, whether you loose connection or not, The hard part is looking at your monitor, seeing "disconnected " message with no picture & waiting for the sounds of your motors as you comes to last waypoint!
My last mission, over a small forest, lost signal 5 minutes into a 16 min, mission. I;ve flown this site before, but theforest, trees leaves have grown in since I last flew here, so I assume why lost signal so quickly,
But, 12 min,. later, I hear my P3A;s motors n the distance & home she came!
Certainly ets your heart beating! |
