Warning Motor obstructed
12Next >
13399 48 2016-2-25
iSkyUnmannedSys
Flight distance : 7152087 ft
So it appaears we now have a new problem with the current firmware. I keep getting "Warning Motor obstructed" on the odd occasion when in fact both my Inspires are flying perfectly fine.
Anyone know what is causing this?
2016-2-25
DJI-Tim
That is strange... Did you have any crash or motor impact? Make sure that there is no any sand or dirt inside
2016-2-26
iSkyUnmannedSys
Hi Tim. No crash, motors are clean. Nothing changed during flight I was hovering when it popped up. Decided to leave it there see if anything changed, which is didn't. Landed and checked that the motors were free and they all were fine. Took off again and no error. There are others reporting a similar situation on other forums, and only since 1.6?
I'm doing some test flying to day, will see if it happens again.
2016-2-28
DragonflyMaurit
Flight distance : 9536818 ft
Mauritius
I had an accident on Saturday because of motor obstructed warning. I took off and everything was fine, I went up to around 7m and then got the warning. The Inspire fell out of the sky and sheered the camera off, damaging the VPS and few other smaller things. This all happened wiithin 45 seconds. Surely I would of got the warning and accident sooner?
I am really happy I was flying in a safe manner and nobody got injured from the falling drone. I'm really bleak about this as I'm 99.99% sure the motors were free from dirt or "obstructions".
2016-5-22
HELJO Productio
Flight distance : 872362 ft
I had the same issue yesterday with an Inspire 1 Pro running the latest firmware.
Also got the "Motor obstructed" message for no reason. check the motors and everything seemed fine.
Never had this problem before until the latest firmware.
2016-5-24
iSkyUnmannedSys
Funny thing is, I've not had this since I reported this a couple of months back.
2016-5-24
SkyLens Aerial
Flight distance : 3879088 ft
Just had similar experience..... Ive been experiencing very persistent weak/no image transmission warnings. At one point in the flight the Inspire 1 disconnected - reconnected - was still hovering where it disconnected - initiated a RTH - then said motor obstruction (in mid air) and dropped out of the sky.
Before you ask it was in a wide open space and did not hit ANYTHING. Flight logs back us up by showing it literally dropped out of the sky!
Luckily it was in wide open farmland.
We have 3 Inspires and have been experiencing very strange issues with all of them recently...We had another last week initiate a RTH out of the blue while being brought into land and it was only 1foot of the ground. The RTH could not be cancelled by the cancel button on the screen, By pressing the RTH button once or by flicking to ATTi Mode. To make things worse we didn't even have any control of the I1 during its RTH and as a result it ended u going straight up and clipping a branch bringing it back to earth with a bump.
We have flown these things for the last year and have many many hours flying with no incidents. To have 2 RTH related incidents within a week shows something is not quite right here!
Can any one from DJI help here as its like banging your head against a brick wall trying to explain this to the support teams! Any help from the forum Mods would be hugely appreciated!
2016-5-24
DragonflyMaurit
Mauritius
I'm using another Inspire now and I am literally s**** myself every time I fly now. I can't afford to have this happen again. Apart from the obvious of checking for visible obstructions, how would I know if there is a small piece of sand or something small in the way to obstruct the motor, this being said if it is not a software fault.
2016-5-25
DJI-Jamie
Flight distance : 112405 ft
DragonflyMaurit Posted at 2016-5-23 11:40
I had an accident on Saturday because of motor obstructed warning. I took off and everything was fin ...
For clarification, did this occur right after a firmware update, or after long term storage? Did you happen to have any hard landings prior to this? If you were to turn the motors yourself, do they seem to spin freely, or does there feel like there is scrapping? Any .DAT files or Flight Records would be appreciated.
2016-5-25
DJI-Jamie
HELJO Productio Posted at 2016-5-24 17:06
Also got the "Mo ...
It would be appreciated if I could get the same information that I asked from DragonflyMaurit. It would be nice to be able to get as much information as possible to be able to get a better understanding as to what could have happened.
2016-5-25
DJI-Jamie
SkyLens Aerial  Posted at 2016-5-25 00:25
Just had similar experience..... Ive been experiencing very persistent weak/no image transmission wa ...
It seems that you have your own thread on your issue and indicated that the Europe Repair center has been assisting you. For clarification, did you send in both aircrafts in for evaluation, or are you still holding onto the one that incurred the motor obstruction error?
2016-5-25
SkyLens Aerial
DJI-Jamie Posted at 2016-5-25 21:01
It seems that you have your own thread on your issue and indicated that the Europe Repair center h ...
Jamie, Incident 1 DJI have confirmed a "quality issue" and it has been sent in for repair/replacement.
Incident 2 they we are awaiting a result from data analysis. We won't be sending it back in until we hear back.
Please see dropbox link below with access to the DAT files from incident 2.
https://www.dropbox.com/sh/sdjlf ... JbRs5rT1BY8n_a?dl=0
2016-5-28
SkyLens Aerial
To update everyone, DJI have analysed the flight data from incident to and have offered free replacement . The engineer report states that the Motor just stopped in mid air and fell to the ground.  Fair play top dji support as they have been quick to analyse the flight logs on both occasions and offer up free replacements on 2 birds in a week!
It would seem that they have sorted out their support system!
2016-5-30
leanlinao
Flight distance : 1495906 ft
Philippines
SkyLens Aerial  Posted at 2016-5-31 15:53
To update everyone, DJI have analysed the flight data from incident to and have offered free replace ...
Any chance you carried any kind of payload on the i1 and even stickers?
2016-5-31
leanlinao
Philippines
Any kind of addon or payload including stickers are the biggest causes of motor obstruction.
2016-5-31
DragonflyMaurit
Mauritius
DJI-Jamie Posted at 2016-5-25 23:50
For clarification, did this occur right after a firmware update, or after long term storage? Did y ...
No hard landings, haven't recently updated firmware and motors seemed to spin fine after the crash. Been flying the Inspire regularly, so it wasn't in long term storage. Here is the flight record for that flight. https://www.dropbox.com/sh/56yg4 ... _bWcF0VJ9A2wva?dl=0
2016-5-31
DJI-Jamie
DragonflyMaurit Posted at 2016-6-1 11:18
No hard landings, haven't recently updated firmware and motors seemed to spin fine after the crash. ...
Thank you for supplying this. Just to confirm, have you already started a ticket with support@dji.com as well for Repair?
2016-6-1
DragonflyMaurit
Mauritius
DJI-Jamie Posted at 2016-6-1 22:33
Thank you for supplying this. Just to confirm, have you already started a ticket with  as well for ...
Hi Jamie, I have not done anything yet, as to not confuse the matter.
2016-6-1
DragonflyMaurit
Mauritius
2016-6-1
Dragonfly_Aeria
Mauritius
I have given my drone to a DJI Partner here in Mauritius to assess the damage. I haven't opened a ticket as yet. Should I?
2016-6-2
leanlinao
Philippines
Dragonfly_Aeria Posted at 2016-6-3 15:31
I have given my drone to a DJI Partner here in Mauritius to assess the damage. I haven't opened a  ...
Hi is your inspire 1 a v2.0 or v1?
2016-6-3
Dragonfly_Aeria
Mauritius
leanlinao Posted at 2016-6-3 13:10
It is a V1. The prop did not come off if that's what you are wondering?
2016-6-3
leanlinao
Philippines
Dragonfly_Aeria Posted at 2016-6-3 19:01
Nope ofcourse the prop did not come off.
2016-6-3
DJI-Jamie
If you are working with someone local, then it would not be necessary. In regards to the flight data you have provided thus far, it's unfortunately unreadable in the .TXT format. If you would still like to have it reviewed, I would need the file with the .DAT extension.
2016-6-3
Dragonfly_Aeria
Mauritius
DJI-Jamie Posted at 2016-6-3 18:12
If you are working with someone local, then it would not be necessary. In regards to the flight da ...
Ok I will send that. Is it not easier to email it to you?
2016-6-3
Dragonfly_Aeria
Mauritius
Dragonfly_Aeria Posted at 2016-6-4 08:56
I managed to get this, but it doesn't seem to be correct, please can you verify? https://www.dropbox.com/sh/uai7t ... 7pTAy7PHh9K2za?dl=0
2016-6-3
DJI-Jamie
Dragonfly_Aeria Posted at 2016-6-3 22:54
I managed to get this, but it doesn't seem to be correct, please can you verify? https://www.dropb ...
It looks like the correct file format. To clarify, did you alter the file names? I will give this to the repair technicians, but there would be a delayed response due to the weekend. I'll let you know what I'm able to find out.
2016-6-4
Dragonfly_Aeria
Mauritius
DJI-Jamie Posted at 2016-6-4 20:34
It looks like the correct file format. To clarify, did you alter the file names? I will give this  ...
I pulled it off just like you see it. Did no editing to any of the file names. Thanks for the assistance, greatly appreciated.
2016-6-4
DJI-Ken
Flight distance : 1515312 ft
Dragonfly_Aeria Posted at 2016-6-5 02:23
I pulled it off just like you see it. Did no editing to any of the file names. Thanks for the assi ...
These are not DAT files from the aircraft, they are very tiny files.
A DAT file of a flight would be hundreds of megabytes.
if you can download the DAY file again, also one upload the flight in question.
There's almost 50 entries, the data analysis team cannot go through that many flights.
2016-6-6
Dragonfly_Aeria
Mauritius
DJI-Ken Posted at 2016-6-6 18:46
A DAT file of a flight would  ...
I think I have the right ones now. I have added a few from before.
2016-6-7
DJI-Ken
Dragonfly_Aeria Posted at 2016-6-7 20:49
https://www.dropbox.com/sh/56 ...
Thank you, also what is your email and I will analyze the flight from the app.
And you synced your flight records correct?
I've forwarded your DAT files on, also if your dealer has opened a ticket have him add your DAT files to it so they don't get confused when I send them off as well.
2016-6-7
Dragonfly_Aeria
Mauritius
DJI-Ken Posted at 2016-6-7 18:29
And you synced your ...
Email address is dragonflyaerial@gmail.com
Synched data and I haven't opened a ticket with DJI. I am looking at fixing my Inspire though. So no confusion to be had for the moment.
2016-6-7
DJI-Ken
Dragonfly_Aeria Posted at 2016-6-8 04:34
Email address is
Synched data and I haven't opened a ticket with DJI. I am looking at fixing my ...
I have your logs but what flight is it. Your original post said 16 days ago last Saturday which would be Saturday which is the 21st but I see 7 flights.
2016-6-7
Dragonfly_Aeria
Mauritius
DJI-Ken Posted at 2016-6-8 00:57
I have your logs but what flight is it. Your original post said 16 days ago last Saturday which wo ...
21st 13:35pm
I put a few logs before that flight. It is FLY056
2016-6-7
DJI-Ken
Dragonfly_Aeria Posted at 2016-6-8 11:37
21st 13:35pm
I'm still not seeing it, closest to what I found is a flight on my app says 16:34 and it looks like a continuation  of another flight. All I see is a signal loss and not a motor obstruction.
In your app how many minutes into the flight do you see the warning.
Also, if you can star the flight as a favorite and re-sync.
2016-6-8
Dragonfly_Aeria
Mauritius
DJI-Ken Posted at 2016-6-8 19:05
I'm still not seeing it, closest to what I found is a flight on my app says 16:34 and it looks lik ...
It is FLY056.DAT 21/05/16 13:35:02
I have deleted the other files.
2016-6-8
DJI-Ken
Dragonfly_Aeria Posted at 2016-6-8 23:17
I'll look again, but that DAT file can't be a flight because it's only 26mb and a flight is several hundred mb's
2016-6-8
DJI-Ken
Now I see the last flight is Dec 14th 2015. Did you delete all of 2016. You need to re-sync again.
Honestly, the best thing is to have the DAT file from the aircraft analyzed since the flight data recorder holds much more information that the flight records in the app does.
You would need to start a ticket to have that read.
2016-6-8
Dragonfly_Aeria
Mauritius
DJI-Ken Posted at 2016-6-8 20:46
Now I see the last flight is Dec 14th 2015. Did you delete all of 2016. You need to re-sync again. ...
This is the flight data from the aircraft. I kept the flight log from the last flight I did when the Inspire fell out of the sky. It was a total flight time of about 30 seconds...
2016-6-8
Dragonfly_Aeria
Mauritius
How do I start ticket?
2016-6-8
12Next >
