Phantom 4 Experience
123Next >
10956 83 2016-3-10
DJI-Tim
The P4 was announced about a week ago, and I was delighted when I had the opportunity to borrow one from the company this weekend. In this post, I would like to share my experience with it.
Below is a photo I took with the Phantom 3 on top of the Phantom 4.
The P4`s battery is a bit thicker than the P3`s. That is because the battery cells are further apart, so that heat dissipates more effectively. You can see in the pictures that there is no single cell has swelled up.
  Plugging in and pulling out the P4`s battery is considerably easier than it was with the P3. P4 batteries have grooved, rubber clips on both sides, not just one side. The battery socket is also designed to be more ergonomic.
Below, you can see the P4 battery`s air vents.
The LEDs on the aircraft arms are now concave. Unfortunately, because the P4’s shell is sized differently, so it doesn’t fit so well into the P3’s hard-shell backpack. The batteries also don’t fit.
This GIF shows the Active Track function, which is amazing and very useful. I am wondering if the Phantoms can detect and be controlled by body language in the future. Then we could control drones without a remote controller!
In the GIF, the Phantom is following a person running on a curved track while flying backwards. However, there is no obstacle sensors on the P4’s tail, so if you’re flying backwards, make sure there are no obstacles its way.
  I’m going to have a lot of fun with ActiveTrack in the future.
The new lens on the P4’s camera produces much clearer images than the P3.
You can also now shoot at videos at 120 frames per second at 1080p. 120fps makes for much better slow motion when you’re shooting at close range (like in the picture below), but if you’re shooting from high altitudes (like in the picture below), you won’t need to shoot at such a high frame rate.
The image above shows the aircraft’s motion in S Mode
  The Forward Obstacle Sensing system won’t work while using the S Mode. So make sure to use S Mode in an open area. Then have a blast flying crazy fast.
The aircraft is flying straight backwards in the image above.
Conclusion
The P4’s battery life has increased a lot, and the Active Track function is really amazing. However, there are some conditions under which you may lose track of the object or person you’re following. Make sure that the object is well contrasted with the background, and fly around the object or person before starting to track it. This way, the P4 can study the subject from all sides and learn its shape and characteristics. Also, make sure to keep the object in the center of the frame.
    My time with the P4 was limited, so I haven’t had the chance to check out all the new functions. Hoping to take it out again soon!
2016-3-10
salvosky
Flight distance : 120253 ft
Good stuff! Thank you!
2016-3-10
tmygun1
Flight distance : 2972497 ft
Pretty cool!
Thanks Tim!!
2016-3-10
kowssarie
Awesome! Thanks!!!
2016-3-10
Rob W
Flight distance : 94390 ft
Sweden
Thank's Tim! I've got my on pre-order.
Do you know, or someone else from DJI here, what the size of the Phantom 4 is (height, rotor diameter, length, width)? On DJI.com it only states the weight. I would like to fill in the forms to get the P4 approved with the Department of Transportation, and in order to get it approved they need those numbers.
Thank's in advance,
Rob
2016-3-10
MM55
Flight distance : 628527 ft
Thanks Tim.
2016-3-10
leo.s
Flight distance : 205696 ft
You can look at here What are the dimensions of the P4?
2016-3-10
marlonlopez15
Nice i love my p3s
2016-3-10
Rob W
Sweden
leo.s Posted at 2016-3-10 18:13
Thank you so much, Leo.s!
2016-3-10
lignow
Good Job Tim. ( i thinking about selling a 3 for a  4)
2016-3-10
Rebel Gal
Great updates...Thanks Tim
2016-3-10
ross.evans11.gm
I'd like to know how robust the collision avoidance is.
2016-3-10
RedHotPoker
Flight distance : 165105 ft
Mucho Gracias Señor, & Thanks for keeping  all of us, the plebes, informed. Hahaha
It's nice to see you are having fun, as it must be quite awesome, ranking. ;-)
Please continue sharing them good times and tidings.
RedHotPoker
2016-3-10
R&L Aerial
Flight distance : 298100 ft
You don't really notice how much weight the phantom 4 has put on until you see a side by side with the p3. I see why some call it the "phantom pillow"
2016-3-10
RedHotPoker
Reminds me of an official Ball Park Frank. They plump when you cook them... ;-)
But oh so tasty, practically reaching delicious status. Hahaha
I actually prefer a gal, with a little wholesome meat on her bones. Ha
RedHotPoker
2016-3-10
jrm11
Flight distance : 224577 ft
"Conclusion
The P4’s battery life has increased a lot,"
Thanks for the preview.
How much is "a lot?"
2016-3-10
DJI-Tim
hahah nice avatar
2016-3-10
ArtistFirst
Flight distance : 986716 ft
That's awesome! But where do I get my DJI Go APP that will support the one I have.  This sucks to be starting at and not flying!!!!
2016-3-10
Harb
I am soooooo close to putting money down on one of these to add to my kit......make a great traveling platform.
Is there anywhere we can download the highest quality files it is capable of ?
2016-3-11
R&L Aerial
ChiefPilot Posted at 2016-3-10 17:57
What size is the micro SD card?
16gb micro sd card
2016-3-11
rodger
Flight distance : 20145135 ft
salvosky Posted at 2016-3-10 07:32
Thanks Tim. Hopefully mine will arrive next week.
2016-3-11
R&L Aerial
Harb Posted at 2016-3-11 04:18
I am soooooo close to putting money down on one of these to add to my kit......make a great travelin ...
I ordered the p4 for just that reason.
2016-3-11
Harb
Let me know what you think.......
2016-3-11
Bhujang
Flight distance : 534587 ft
Looks great,  unfortunately I just bought and am highly stisfied with my p3p so won't be upgrading for the forseable future. By the time I'm ready to upgrade it will probably be on the next generation if not even further down the line ;)
2016-3-11
wellingtonsique
Flight distance : 181358 ft
Brazil
So, as seen, the lack of sensors around and behind the craft makes it vulnerable to collision by sides and back. Another weak point is the disabling of the anti-collision while using the S Mode, what can only be explained by limitations (Processing speed, maybe?) of the avoidance system as for quick-popping objects into the field of view...
Sure it's a great product, but I hope an Inspire 2/Phantom 5 brings 360º avoidance  detection and one that works in ALL MODES, even in Sport mode, because safety is necessary anytime/flight mode you fly...ah, and a 15.000/20.000 mAh battery to really jump the flight time up once and for all...
2016-3-11
Slow Down
Flight distance : 163599 ft
China
Great job!
2016-3-11
iherzog97
Brazil
wellingtonsique Posted at 2016-3-11 12:24
So, as seen, the lack of sensors around and behind the craft makes it vulnerable to collision by sid ...
Avoidance is disabled in sport mode because the angle of the aircraft (45o), so the cameras cannot see the obstacule
2016-3-11
Derek Spear
Tim, how would you compare the Phantom 4's image quality versus the X3 camera on the Inspire 1?
2016-3-11
DJI-Ken
Flight distance : 1515312 ft
Derek Spear Posted at 2016-3-12 00:39
The image quality is much better.
The Phantom 4 camera has been improved in terms of image quality. Chromatic aberration has been reduced by 56% and lens distortion had been reduced by 36% compared to Phantom 3 Professional. In addition to lens improvements, camera firmware has been tweaked to enable the camera to capture 120fps video in full 1080p FHD (the camera’s field of view will be reconfigured to 47° when recording in this mode) for smooth slow motion.
2016-3-11
dobova
Flight distance : 664337 ft
DJI-Ken Posted at 2016-3-11 17:51
The Phantom 4 camera has been improved in terms of image quality ...
Interesting .. but the FOV how is reconfigured ? Optically or digitally ?
2016-3-11
DJI-Ken
dobova Posted at 2016-3-12 00:59
There is a new lens with 8 elements.Here's a video.
2016-3-11
Derek Spear
Interesting.  I have an aerial project coming up next month and was debating whether to use the Inspire 1 or the Phantom 4.  I guess with the image quality being better on the P4...the only determining factor at this point would be how strong the wind is on the day of the shoot...as I typically prefer the better handling characteristics of the Inspire 1 due to its size.
2016-3-11
iherzog97
Brazil
DJI-Ken Posted at 2016-3-11 14:08
https://www.youtube.com/watch?v=JJPSSqMQajA
Can we use the P3P camera filters on the P4 camera?
2016-3-11
DJI-Ken
iherzog97 Posted at 2016-3-12 01:35
Yes you can, I have DJI and Polar Pro filters and they fit perfect on the P4
2016-3-11
microcyb
Flight distance : 1095955 ft
DJI-Ken Posted at 2016-3-11 11:44
So seriously question to the DJI folks who had a chance to use the phantom 4.
What did you think about the tracking features?
Was wondering about doing my ATV riding.
How sharp of turns can the tracking handle (degree wise)?
Say, the bird would be up at about 196 feet (60 meters) and going about 20 mph (32 kph).
If what would be the sharpest turn someone might be able to do without having to look back to see if the Phantom 4 is still tracking?
I seen folks walking and running and taking a sharp 90 degree turn and it loses tracking, but many are flying very low, so that really doesnt help much and the high altitude ones they are normally in a straight line.
2016-3-11
ghtracey
Flight distance : 7224 ft
ArtistFirst Posted at 2016-3-10 23:39
That's awesome! But where do I get my DJI Go APP that will support the one I have.  This sucks to be ...
That's what you get for getting an Apple store to sell you one before the release date
2016-3-11
ghtracey
wellingtonsique Posted at 2016-3-11 07:24
Seriously? Weak points? This is the first drone to have ANY type of collision avoidance and you are listing weak points and vulnerabilities? Compared to every other drone currently available, this is miles ahead in automatic safety features. Imagine the processing power needed to look in 360 degrees (plus vertical), build a 3d image of the world and then decide if you are moving in that particular direction and whether you need to alter your course. Then imagine fitting all those cameras (8 additional cameras) and the processing power needed to  run them into a phantom sized chassis. Weight and cost become large limiting factors.
The avoidance is disabled in sport mode because the forward facing point cloud cameras have a +/- 15* vertical view. Sport mode can tilt 45* so the cameras will be looking at the ground making them useless. And its SPORT mode, you should be watching where its going anyhow at that speed. As you said safety is necessary anytime you fly, keep your eyes on your drone and keep it in LOS in sport mode and you shouldn't fly into things. If you feel that sport mode isn't safe for you to fly in, then don't use it.
2016-3-11
Zigman
Flight distance : 2791296 ft
Thanks Tim, just received a text fromApple, mine will be delivered on Tuesday 3/15/2016, just ordered it on the 8th.
2016-3-11
simonst
Thanks Tim!
But were you the one who won the 20-days trial?
2016-3-11
ArtistFirst
http://forum1.djicdn.com/data/attachment/forum/201603/10/194121ms...
THIS WAS AWESOME!
Thanks TIm.  Next best thing to having the app.
Actually it's raining all day today.
Also, I just want to say, I appreciate that nail!  What a beauty!
2016-3-11
123Next >
