Is this a problem?
1201 13 2016-8-9
blades
I'm new to my DJI Inspire Pro with X5, done a firmware update 1.9.1.30+, 4 bleeps during, 3 bleeps when finished but I didn't get the green light on the camera? Since the update, all seems ok, I've calibrated the IMU. The camera seems to be out of focus now? Should I calibrate the camera?
Remote is 1.7.40
Camera is 1.9.1.10
DJI Go is 2.8.6
The green light comes on doing power up but I don't get a solid green status light?
Everything I read indicates that the green light should be solid green?
Thanks in advance for any guidance.
2016-8-9
DJI-Jamie
Flight distance : 112405 ft
I would recommend calibrating the gimbal and lens as well.
2016-8-9
blades
OK I will do that. Please see below the result following the firmware update as described above.
========== 2014.01.01 00:01:56 remo-con disconnect======
Packet: WM610_FC550_FW_V01.00.00.30.bin
Upgrading ...
========== 2014.01.01 00:01:26 remo-con disconnect======
Upgrading ...
========== 2014.01.01 00:00:23 remo-con disconnect======
Packet: WM610_FC550_FW_V01.04.00.70.bin
Upgrading ...
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: WM610_FC550_FW_V01.01.00.40.bin
Upgrading ...
Packet: WM610_FC550_FW_V01.08.01.00_FCam.bin
Upgrading ...
Result: Success.
========== 2015.10.10 09:03:13 =====================
Packet: WM610_FC550_FW_V01.08.01.00.bin
Upgrading ...
Result: Success.
========== 2016.08.09 18:29:27 =====================
Packet: WM610_FC550_FW_V01.09.01.30.bin
Upgrading ...
Result: Success.
2016-8-9
Insieme Agency
Flight distance : 420449 ft
Hungary
If it was solid green than its okey!
2016-8-10
blades
Insieme Agency Posted at 2016-8-10 10:58
It wasn't solid green... I had no green light. I get the green light during start up and x5 positioning but then no solid green light.
2016-8-10
Insieme Agency
Hungary
blades Posted at 2016-8-10 12:31
It wasn't solid green... I had no green light. I get the green light during start up and x5 positi ...
I have the same, I think the LED doesn't that much strong in the new FW! But give it a try at night! Maybe than you can see something!
2016-8-10
blades
Insieme Agency Posted at 2016-8-10 13:00
I have the same, I think the LED doesn't that much strong in the new FW! But give it a try at nigh ...
Thank you for your help. I will check this later today.
2016-8-10
DJI-Jamie
blades Posted at 2016-8-10 18:31
There is no longer a continual green LED when the camera is stationary, that was changed in a recent firmware update. If all the other LED indications appear as normal and your not experiencing any performance issues, then you would be fine.
2016-8-10
blades
DJI-Jamie Posted at 2016-8-10 16:27
There is no longer a continual green LED when the camera is stationary, that was changed in a rece ...
Thank you Jamie.
2016-8-10
DJI-Jamie
You're welcome. Please let me know if you have any additional questions or concerns.
2016-8-10
ZEN.alfa
Indonesia
i have same problem with u guys, same with other member : http://forum.dji.com/forum.php?m ... D380%26typeid%3D380
i have inspire 1 pro black edition, and now green led is dissapear since i upgrade firmware to v.1.9 , ...
and today i have downgrade to firmware v.1.8, and dont change anything, green led still dissapear..
2016-9-29
Donnie
Flight distance : 3636782 ft
ZEN.alfa Posted at 2016-9-30 02:50
i have same problem with u guys, same with other member : http://forum.dji.com/forum.php?mod=viewthr ...
It is normal , it more than likely changed the setting for good regardless of rolling back to 1.8.  Just like if you update a battery once it is done you cant take it back .  You are fine.
donnie
2016-9-30
ZEN.alfa
Indonesia
DJI-Jamie Posted at 2016-8-10 23:27
why DJI change this?? i feel comfort if i see continual solid green led shown, ... because in my mind solid green led indicate the gimble in normal condition without see in dji go app, ... and i think many owner i1p will not like that dji do.
please dji, come back gimble green led continual for us...
2016-9-30
Aeromirage
Flight distance : 1778045 ft
That was one of the issues I forgot to mention in this thread: http://forum.dji.com/thread-52361-1-1.html
Camera did lots of very strange things.........
2016-9-30
