'No Image Transmission' Issue Inspire 1 - Issue is with aircraft
123
10639 92 2016-8-29
Mike-the-cat
Flight distance : 22488593 ft
Singapore
edmund Posted at 2016-9-24 16:13
Guys I experienced exactly the same issues while on a remote site in Western Australia as I was ab ...
Please see my latest post of Oct 1st documenting problem resolution. You may have a similar issue. Would love to hear about your recent flight experiences.
2016-9-30
Mike-the-cat
Singapore
siong220576@gma Posted at 2016-9-17 18:34
Hi guys, week ago i just got back my inspire1 pro back from dji for a repair. Seen like what i facin ...
See my observation about the '+' indication in my Oct 1 post. There may still be an issue with your aircraft.
2016-9-30
Mike-the-cat
Singapore
Blue Dot Posted at 2016-9-16 21:52
Hi there, I've had my Inspire 1 V2 less than a week, flew UAV this morning, with nothing untoward, a ...
Sorry for the late response. Suggest you take the aircraft to the shop for a diagnostic. See my latest Oct 1 post about this matter.
2016-9-30
jibcam
Flight distance : 1805928 ft
Argentina
Mike, I have 2 Rc, master shows in about the AC fw 1.9.1.3+ while slave Rc shows 1.9.1.30.
Could you please tell me all fw versions on your hardware actually ?
Thanks.
2016-10-4
Mike-the-cat
The FW version for the aircraft is not consistent. Most of the time it shows 1.9.1.30 but sometimes a + appears. RC is 1.7.40, camera is 1.9.1.10 A9 Plus is 01.15.18.09
2016-10-5
Mike-the-cat
Singapore
If you have a heavily used aircraft flying X5 / X5R read this http://forum.dji.com/thread-65717-1-1.html
2016-10-6
fans728d77d0
Mike-the-cat Posted at 2016-9-30 18:05
This is now quite old but thought I would let you know how I resolved the issue...
Basically the reason was that the sd card still had the firmware update installed as well as the log file
After much frustration with no video I went onto the sd log file and noted that it was attempting to reload softwareceach time and was aborting...
So I deleted both the firmware and log files and everything was ok... I was on another ptoject in remote Indonesia and had the same issue ...which upon inspection I noted the firmware was again left on following a recent update ... deleted and restarted and all ok
2017-3-2
Donnie Stugots
Flight distance : 3636782 ft
fans728d77d0 Posted at 2017-3-2 02:38
That is great information regarding the old updates  being left on the SD causing video issues.
Thanks for sharing , I will add this one to my notes , maybe it will help a member in the future.
donnie
2017-3-2
Mike-the-cat
Singapore
OK Thanks for sharing.. There are different ways this problem can arise. Your's is an infrequent one but thanks for logging it.
2017-3-2
RichJ53
Flight distance : 1837356 ft
Mike-the-cat Posted at 2017-3-2 08:00
MTC
This thread brings back memories
Aren't  you flying the I2 now with the X5S?   How are you liking it?
Rich
2017-3-2
Mike-the-cat
RichJ53 Posted at 2017-3-2 11:52
MTC
Hi Rich,
I've not been flying much the last month but have an opportunity to do so in the next days and will write on this.
2017-3-2
chief
I havent flown in a while I got out my Inspire 1 with x5 camera today it updated the firmware and I have the NO video image transmission error? I cant figure this out any suggestions.  Im using an I pad and everything else appears ok.
2017-3-3
Mike-the-cat
New Zealand
chief Posted at 2017-3-3 15:32
Donnie has an excellent post on all the things that can give this error message on the I1 pages but these are the common ones:
1. Power up sequence: RC, aircraft, app.
2. Gimbal contact poor - jiggle the gimbal - if signal comes back, test more.
3. If that fails, check the spring contacts on the aircraft for being bent
4. If that still is a problem, go hunt down Donnies checklist.
Best of lunck
2017-3-4
123
