SkyHigh UAV
Flight distance : 2838921 ft
Mavic Pro Release Notes
http://www.dji.com/mavic
Copyright © 2017 DJI All Rights Reserved. 1
Date : 2017.02.14
Firmware : v01.03.0400
DJI GO 4 App iOS : v4.0.4
DJI GO 4 App Android : v4.0.2
What’s New?
Added a self-diagnostic test function for ultrasonic sensors every time the aircraft is powered on.
Improved the Interval Mode performance.
Upgraded the D-Log color mode to extend dynamic range.
Optimized the video transmission by reducing the transmission signal loss ratio.
Notes:
Restart the aircraft and remote controller after upgrade is complete.
If the firmware upgrade fails, restart aircraft, remote controller and DJI GO 4, and retry.
Copyright © 2017 DJI All Rights Reserved. 2
Date : 2016.12.26
Firmware : v01.03.0200
DJI GO 4 App iOS : v4.0.2
DJI GO 4 App Android : v4.0.1
What’s New?
Improved gimbal performance when flying in low temperatures.
Added Cinematic Mode for smoother the footage, refer to the user manual for details.
Notes:
Copyright © 2017 DJI All Rights Reserved. 3
Date : 2016.12.06
Firmware : v01.03.0000
DJI GO 4 App iOS : v4.0.0
DJI GO 4 App Android : v4.0.0
What’s New?
Added AR route display in TapFly mode when used with the DJI GO 4 app.
Added a vibration warning for the remote controller when the aircraft enters ATTI mode.
Added wind speed evaluation and a high wind speed warning.
Added more film looks and color modes (when used with the DJI GO 4 app).
Improvements:
Optimized the compass algorithm to reduce switching from GPS Mode to ATTI Mode.
Improved magnetic detection for the remote controller. The aircraft will now return to home when
strong magnetic interference is detected.
Improved the speed at which the HD video link connection can be regained after disruption.
Optimized altitude maintenance capabilities when flying over water.
Optimized Gesture Mode.
Improved the indoor flying experience by shortening the minimum distance from an obstacle from 3m
to 1m.
Optimized power management for long-term battery storage.
Notes:
Copyright © 2017 DJI All Rights Reserved. 4
Date : 2016.11.09
Firmware : v01.02.0900
DJI GO App iOS : v3.0.2
DJI GO App Android : v3.0.1
What’s New?
Optimized Remote Controller Calibration.
Adjusted default gimbal pitch smoothing value from 10 to 15 for smoother movement.
Increased USB connection stability.
Adjusted camera color.
Fixed occasional remote control command timeout.
Fixed occasional unresponsiveness to remote controller commands.
Deleted support for using C1 or C2 button to launch the DJI GO app on iOS.
Notes:
If the firmware upgrade fails, restart aircraft, remote controller and DJI GO, and retry.
Copyright © 2017 DJI All Rights Reserved. 5
Date : 2016.10.21
Firmware : v01.02.0800
DJI GO App iOS : v3.0.1
DJI GO App Android : v3.0.0
What’s New?
Optimized the Return-to-Home and Landing (refer to the user manual for details).
Reduced descent issue caused from flying indoors to outdoors.
Minimized an overheating issue resulting from not removing the gimbal clamp after powering on the
aircraft.
Improved the stability of the aircraft when switching between Portrait and Landscape.
Optimized the ActiveTrack experience, keeping moving subjects in center frame more effectively and
smoothing footage.
Optimized control parameters to improve the flight experience.
Fixed occasional issue of GPS signal loss.
Notes:
If the firmware upgrade fails, restart aircraft, remote controller and DJI GO, and retry. |
