OSMO MOBILE: How to Get Your Video Out Easily in iOS
12
83394 49 2016-10-22
TimGorski
Flight distance : 72723 ft
Taiwan
HouseofHaute Posted at 2017-3-12 22:01
I'm not sure if anyone else has repeated this (or if there's been an update since) as I'm short on time and haven't gotten through most of this thread.
There is a way to export all photos/videos at once from the Library using most of TheodoreRex's advice above. I will copy/paste his instructions and then add the other steps:
Unfortunately as of right now, you still have to go through the device to export without going through the editor.
There is no save option on Android. What's up with that?
2017-5-10
fans89b57f7c
Hello Guys,
I was able to copy the files and then delete them fairly easy
This method worked for me
First I use the method described by Thor which is
Connect your iPhone/iPad to your computer,
Launch iTunes
Select your iPhone under “Devices” on the left. If it’s not there, unplug/replug your iPhone/iPad.
Select Apps from the top menu
Scroll down; under File Sharing, Find DJI Go and select it
Find the two folders "HD300 Storage"  and "Video Cache"
THEN, (once I made sure files were stored in my computer)
I opened the DJI Go app
Went to the ME tab
Entered the SETTINGS
Entered CLEAR CACHE
and clear both the photo CACHE and the video CACHE
Then I double checked in iTunes and the space was freed
Hope this help
2017-6-16
BoomStrike
Is there any way to delete the files in I tunes after you copy them to the Mac?
Thanks
2017-6-22
Mike Mas
Sagology Posted at 2017-4-8 03:34
Here is an easy way: https://youtu.be/m3fUoeatGN8
Sagology,
Thanks for the video however if you do the same save using the "HG Storage" instead,  you'll get your Jpeg's and video files. only video are in the Video Cashe folder
Thanks Mike
2017-6-22
Montfrooij
Flight distance : 2560453 ft
Thanks a lot!
2017-11-1
kosmelnikov
Flight distance : 634098 ft
Ukraine
omg...
Guys seems you have to try 'Sync for DJI' app (now it is only for iOS)
This app allows you download recorded images and videos just by few taps. As for me after flying I open 'Sync for DJI' app, choose images and then tap on download button. After that you even can minimize the app. And it will download in background.
find it on Appstore or use this link https://itunes.apple.com/ua/app/sync-for-dji/id1255799480?mt=8
2017-12-4
djiuser_1veRlIKmKkTG
Sweden
Hi all,
Just want to share with you that after iTunes 12.7, the file sharing has been removed from the APPS section to the left menu.
Read more: https://support.apple.com/en-us/HT201301
2018-2-25
Lilli Keinaenen
Just got my Osmo Mobile 2. Shot my first video, WITH audio. So I'm like cool, let me send that to a client. Click "share". It forces me to add music. Okay, no problem, I'll choose "no music". The saved file now doesn't have the ORIGINAL audio either. There is no Save button on Android. The "select & share" also leads to the music editing window.
Superbly annoying.
2018-10-10
fansdcebf7f7
Colombia
Hola. Tengo un problema con osmo mobile + iPhone 8 Plus, usando la aplicación dji Go. Los videos están en formato .mov, cuando los descargo a la P.C. aparecen corruptos y no se pueden editar. Ayuda
2018-12-9
Alekos63
What about the extension? My files are all .rec!
2019-6-12
12
