DJI GO - Supported Xiaomi phones for Mavic
12
37965 60 2016-11-2
user6ad8cb177c
Flight distance : 203245 ft
I have a redminote4 all is updated to the last version and... Lag is INCREDIBLE I can't see nothing the video is totally pixelade! What can I do?
2017-11-27
Luca Ceraso
Argentina
Hi, I'm about to get a Xiaomi and I need to ensure the compatibility with my DJI Mavic Pro. I was thinking in a Redmi Note 4 4g but from what I've read it can't ensure a proper functioning. The next best choice based of what i've read (this post was the most helpful one) I've changed my choice to a Mi5s Plus. I'll appreciate experiences with this phone in relation with the app or confirmed alternatives within that range of prices (150/350e)
Thanks
2018-1-2
djiuser_4SCUXtk
Czechia
Luca Ceraso Posted at 2018-1-2 12:05
Thanks
I have xiaomi redmi note 4x (Global) with MIUI 8, using GO4 .14 version without problems with mavic pro. Litchi in second space works but only if connected to internet, if not connected to internet it doesnt connect to mavic  (dont know why).
2018-1-20
trel0s
Greece
I have xiaomi redmi note 4x and it works fine with dji go 4 app @ 5.8ghz when I switch the image transmission settings to  to manual in order to  connect @ 2.4ghz for better range the phone's wi-fi   can not find the remote control even after restart! I nave to reset both aircraft and remote control in order for everything to work again.
Has anyone any solution to this problem?
2018-3-10
SBasso
Malta
I do own a Mavic Air and I fly it with Redmi Note 4!
2018-3-10
SBasso
Malta
I had a couple of fights and so far, it works well...
However, today, the remote got disconnected from the Drone!
Not sure what caused that, still investigating, however, I believe, it's my fault as my phone was on Battery Saver and the GPS was deactivated.
Keep yous updated!
2018-3-10
SBasso
Malta
Reinheart Posted at 2016-12-9 02:33
I just bought Xiaomi Redmi Note 4 for my Mavic, DJI go succesfully Installed but it cant run?? Why?? Pls help.... Thank you.
Yes, it will...
As I do have one and no issue so far!
2018-3-10
SBasso
Malta
My Redmi Note 4 works like a charm for the Mavic Air.
I do like to close all the apps before & leave in Airplane Mode.
2018-4-21
Sanatana2008
I have HP Xiaomi Redmi 4 Note. Was so complicated conect software DJI Go 4 with this mobile. Still conect and disconnect. Wasn´t possible download actually firmware for control and drone Mavic Pro. Latter I used  another HP a and second day I tried connect control with my Xiaomi Redmi 4 Note again and was working and no have problem more. So I can say, Xiaomi Redmi 4 Note is compatible.
2018-6-1
fred plo
Austria
Xiaomi Mi Max 2 64GB,works great with Litchi+DJi go,just install on 2.workspace.
2018-8-1
plainman007
India
fans6d131b63 Posted at 2017-1-27 12:56
For a long time could not find a solution until i found it himself: To  Xaomi Mi Max connected to the RC Mavic without problems - all of you need  to do is disable the USB debugging mode ;) Good luck to all!
Turn off Debug on USB mode.
Turn off debugging ? I thought you have to enable USB debugging right ?
2018-9-8
skan
I have a Xiaomi Mi8, and it works but when I connect it to the RC through the cable the battery drains very quickly.  The RC absorbs the power from the phone.
With older phones you could try with an OTG cable but this one uses USB type-c and the OTG cables work reversed, they prevent the flow of current from the RC to the phone but we need the opposite.
And we can't interchange the connections because one is type-c and the other one is microusb.
So far the only solution I've found is using an adaptor. But it's very cumbersome.
Using a software to force the mobile to stop charging doesn't work and can break your Android.
2018-9-17
Nanolab
Flight distance : 122165 ft
skan Posted at 2018-9-17 03:10
Hello !
I've just bought an MI8 for DJI Go 4 (coming from an old Nexus 5....).
Didn't received yet but I'd like to know if you tried the 2 Usb ports on the RC ?
Do they behave the same as you described ?
Thanks in advance !
2018-9-17
JJBspark
Flight distance : 12401030 ft
Hi, i use a MiMax2 ; works great! guess the 3 works as well
cheers
JJB
2018-9-17
MS Eierfeile
Switzerland
I just got a Xiaomi Redmi Note 5. Works perfectly fine with Mavic 2 Pro with MiUI 10 and DJI Go4 4.3.2. All funktions work. No lag except when I'm capturing the screen of the Xiaomi whilst flying. But still then it's bearable. So thumbs up from me. But please notice that I exclusively use the Xiaomi as a "DJI cockpit". No other apps installed than DJI GO, GO4 and Tello!
2018-10-17
djiuser_FvwjXYdiX4xt
Flight distance : 280476 ft
Hola, soy nuevo aquí. Alguien sabe si para un Mavic 2 pro vale un Xiaomi Mi 8 Lite, o un Redmi Note 7, o un Mi A2, o un Mi A2 Lite??. Gracias.
2019-5-21
Dwi Putro Notonegoro
Indonesia
I used to use my Xiaomi Mi 6x (6/64). At first was okay, but later on, it doesn't want to connect either with my Mavic Pro nor Phantom 3 Professional. How to fix it? Should I buy new smartphone?
2019-6-24
fans013191f5
Indonesia
Hi, I'm trying to connect my xiaomi poco phone to my magic pro for the first time and somehow it won't connect. I can't proceed form the step shown in the attachment. I'm using the charging usb cable - is that maybe the problem?
2019-6-29
prakar2
India
Does Mi A3 support the DJI Fly App for DJI Mavic Mini?
2020-5-31
djiuser_yGQFPnHfUZye
Greece
I just bought Mavic air2…and it's not possible to connect my Xiaomi redmi note 6..
Do you have any suggestions?Thanks in advance.
2020-6-9
djiuser_enpaYCHc9uEY
India
Sir I have mavic air 2 . I install dji fly app 1.3.0 in my Android mobile Redmi 9 Power . Sir I face the problem the video area of fly app show only black not show any video constant other all function are worked and app show the massage is Vision problem... Sir please guide me
2021-4-12
12
