Phantom 3 Standard firmware v1.8.10 is now available to download!
12345678910Next >
72331 368 2016-11-9
Overview
1. All-in-One firmware Version: v1.8.10
2. DJI GO app iOS Version: v3.1.2
3. DJI GO app Android Version: v3.1.1
What’s New
1. Optimized Flight Restriction Zone management by deleting flight restrictions for some abandoned airports.
2. Slowed motor stopping time to three seconds during flight.
Notes
DO NOT turn off the remote controller or exit the DJI GO app during the update process.
Overview
1. All-in-One firmware Version: v1.7.90
2. DJI GO app iOS Version: v3.0.2
3. DJI GO app Android Version: v3.0.1
What’s New
1. Improved video downlink stability in high interference environments.
2. Fixed an Intelligent Battery auto restart issue occurring in cold environments.
Notes
Please link the remote controller to aircraft before you do the update.
2016-11-9
rr
Denmark
cant see any banner about new firmware in the dji go app??
2016-11-9
chewy
Will this also address problem with range?
2016-11-9
rr
Denmark
where can i download the 1.7.9 file its not on the phantom help page where the other firm ware is??
2016-11-9
rr@jensen.mail. Posted at 2016-11-9 18:17
Pleae try to re-link the RC to aircraft and restart the DJI GO app again.
You will see the update message.
2016-11-9
AlfexOmega
Just updated and everything went smoothly, around a minute and a half to complete, very fast. I've already noticed that the Wi-Fi connection is now working in my room where I used to never be able to connect.
2016-11-9
rr
Denmark
dji mindy still no banner here tryed to linked rc to ac with sucess but no update banner here.so i guess i have to do it by sd card instead where can i download the 1.7.9 bin file??
2016-11-9
Ciro Italy
rr@jensen.mail. Posted at 2016-11-9 13:23
dji mindy still no banner here tryed to linked rc to ac with sucess but no update banner here.so i g ...
have you switch on internet on your smartphone/tablet ?
2016-11-9
maichelvnl
Flight distance : 315348 ft
Wow finally! So now the question is should I upgrade or wait until others have tried it first? I am back on 1.5.7 which is reasonable, after having so many problems on 1.6.8.
2016-11-9
mr.fly
"Improved video downlink stability in high interference environments."
I really hope this means: Drone will no longer lose signal after altitude of 30m.
If anyone will try it please let us know, I will try to update it in couple of days.
2016-11-9
Da Lata
Flight distance : 1008297 ft
Brazil
rr@jensen.mail. Posted at 2016-11-9 20:23
I use android and I had the same problem as you, I reconnected several times and the warning for update did not appear. To solve I disconnected the quadcopter wifii, quit the DJI app, reconnected to my network and opened the DJI go app. Then I reconnect to Phantom wifii close app and when a reopened the banner was there!
Good luck!
2016-11-9
rr
Denmark
have done that but still no banner and i cant update it via sd card either
2016-11-9
Da Lata
Brazil
rr@jensen.mail. Posted at 2016-11-9 20:53
Is your app DJI Go uptodate?
2016-11-9
Da Lata
Brazil
After update I did a 15 minutes flight at 50M high and 300M distance using course lock... everything seems OK
2016-11-9
rr
Denmark
dont know where can i see this??
2016-11-9
rr
Denmark
i cant update anything at all not via app and not via sd card??
2016-11-9
Da Lata
Brazil
rr@jensen.mail. Posted at 2016-11-9 21:31
Open the app (no need to connect with phantom) and at the bottom of the screen click the "me" tab, select "settings" ... at the bottom will be written which version you are using. The most current one is 3.0.1 (8)
2016-11-9
rr
Denmark
i have sent the drone in to where i bought it and they will send it to dji in europe
2016-11-9
rr
Denmark
it is version 3.0.1(8) and how do i see if its autoupdate?
2016-11-9
fansdcf34e53
Flight distance : 158675 ft
Poland
I have the same problem. I do not see information about new ver in DJI GO I tried everything (restarts app, aircraft, wifi connection)
2016-11-9
markku.viitanen
Finland
The new firmware seems to be downloadable in Phantomhelp website: http://www.phantomhelp.com/Phantom-3-Standard/
Scroll down to the bottom, there you find the FW archive.
2016-11-9
Da Lata
Brazil
rr@jensen.mail. Posted at 2016-11-9 22:54
on android... Settings>about device>...you can set automatic update.
2016-11-9
rr
Denmark
i have sent my drone in for evaluation
2016-11-9
fans4c281ddf
Flight distance : 71778 ft
Russia
Da Lata Posted at 2016-11-9 21:31
After update I did a 15 minutes flight at 50M high and 300M distance using course lock... everything ...
Glad to hear that
2016-11-9
fans4c281ddf
Russia
Just manually updated from sd card, but I can't check now cause weather conditions. But in dji go I see version 1.6.8+ dji is this ok?
2016-11-9
fans0e105feb
Flight distance : 220830 ft
Turkey
There is no banner in app. How can we update?
2016-11-9
wmcvey
Flight distance : 904364 ft
fans4c281ddf Posted at 2016-11-9 12:43
Just manually updated from sd card, but I can't check now cause weather conditions. But in dji go I  ...
Personally I'd do it the correct way, via the Go app. Everyone is so impatient with just waiting a bit for the update to show in the app. Maybe their servers are a bit busy at the moment. And no that's not corrent, it should say the correct version number.
2016-11-9
Da Lata
Brazil
I did the update, check the txt file on SD Card (OK), I test flying the drone and like other user the version on app show 1.6.8+. Before was only 1.6.8 without +
2016-11-9
wmcvey
Da Lata Posted at 2016-11-9 14:20
I did the update, check the txt file on SD Card (OK), I test flying the drone and like other user th ...
But did you do it through the Go app and wifi, or did you download it to the SD card yourself?
2016-11-9
Da Lata
Brazil
wmcvey Posted at 2016-11-10 03:56
Through DJI Go app, like the video on the first post!
You can see what steps I did on post #11
2016-11-9
JpNL
Flight distance : 428245 ft
Da Lata Posted at 2016-11-9 20:20
People who have done the update (1.7.90) Please indicate the results after a test flight.
Lot P3S pilots have whined and complained about the poor (1.6.8 update) firmware. (incl me)
Let then please know that this update fixes addresses issues and the distance signal.
This is better for all of us, and for the developers. (DJI)
Thanks and regards.
2016-11-9
Betamace
Flight distance : 2133 ft
DJI Mindy Posted at 2016-11-9 18:43
You will see the update  ...
I'm on FW 1.6.8, GO app version 3.0.1 and I still don't get an update banner. Flight log sign-in screen stays up about 1/20 second then screen goes white for 2 seconds returns to the app home screen. Always worked before with previous GO app versions. Thank you DJI for another broken app.
2016-11-9
Da Lata
Brazil
JpNL Posted at 2016-11-10 04:22
Lot P3S p ...
I gave my opinion about that on post #15
2016-11-9
Gerardo Rejec
Flight distance : 120141 ft
Da Lata Posted at 2016-11-9 15:26
so before the update how far could you fly?
2016-11-9
Da Lata
Brazil
Gerardo Rejec Posted at 2016-11-10 04:28
Before update I did some flights with 700 meters distance, I do not test the complete range because I live in a dense area... but 300meters with a very good signal quality seems to be OK!
2016-11-9
BobABooey
I only tried maybe 25 to 30 times. But I don't see any banner thingy.
Is my wifi supposed to look like this? .
2016-11-9
Da Lata
Brazil
BobABooey Posted at 2016-11-10 06:05
Is my wifi supposed to look l ...
Yes, exactly like this!
I think the DJI server is to busy, when I try was 6AM UTC (9AM brazilian local time) and I connect and reconnect several times before I have success!
2016-11-9
BobABooey
Da Lata Posted at 2016-11-10 06:36
I think the DJI server is to busy, when I try was 6AM UTC (9AM brazilian l ...
okay, ill keep trying   thank u
2016-11-9
wmcvey
BobABooey Posted at 2016-11-9 17:05
You are connecting to your home wifi when your trying to connect to DJI, right?
2016-11-9
BobABooey
wmcvey Posted at 2016-11-10 07:06
What do u mean? Should i hook to dji wifi then switch to my house wifi?
2016-11-9
12345678910Next >
