Compass Calibration Failed
12
21881 45 2016-11-17
fans78528cc4
Flight distance : 78465 ft
I was having the same problem.  Calibration Failed!  Too Strong Magnetic Interference Detected.... bla bla bla.
I found that when I took off my Apple Watch, everything works just fine.  Who Knew???
2018-3-10
johanes 1
Colombia
Hi, I was able to solve the problem of the compas; a friend electrical engineer recommended me to do a selenoid to demagnetize the compas 2 and it works perfectly.
2018-3-14
johanes 1
Colombia
2018-3-14
FL 450
Just had this problem on a new Mavic Pro August 2018. As DJI-Ken mentioned, the arms must be unfolded to calibrate the compass. Problem resolved immediately.
2018-8-30
jimdow528
To be certain, smartphone compasses can be "way off" with their azimuth readings.
Recently I developed a new method for compensating for the residual (after calibration) deviation errors experienced by electronic compasses (smartphones).  The method is very easy to implement by smartphone compass app vendors; and it applies to handheld laser rangefinders as well.
Here are the compass deviation (compensation) curves for a well-known iPhone compass app.  These compensation curves significantly improve the results measured by the compass app - over the entire 360 degree range of measurement.
If you or your associates might be interested in this new method for correcting smartphone compass errors (Android or iPhone), please contact me. Your readership might be interested as well.  I would like to help.
Fixing Rangefinder & Smartphone Residual Compass (azimuth) Deviation Errors
https://www.amazon.com/Rangefind ... tal-text&sr=1-1
Thanks for your time and consideration
2023-4-27
jimdow528
Take a look at the following blog posts to gain a different perspective about compass azimuth errors.
https://tru-path.org/2023/05/09/case-study-1-a/
2023-5-9
12
