Mavic Crash - It ate a tree branch.
12
5192 67 2016-12-5
MSavage
DJI-Ken Posted at 2016-12-5 14:52
I've only looked at the last flight, the aircraft was already at 6m at 7:51 when you gave it a very quick (not held down) on the throttle stick. Then at 7:52 it hit the tree. I think if it wouldn't have hit the tree it would have started to descend but the time from when you tapped the stick down and it hitting the tree was too quick.
I will look at another flight, star the flight and re-sync and and tell me what minute and second mark to start watching.
If you want an example of the unresponsive down / "Landing" mode behavior take a look at 3:40 @ 114m and 4:48 @ 77m on the crash flight. You can also see this behavior on most of my flights. Can you provide insight on what could be causing this?
2016-12-5
DJI-Ken
Flight distance : 1515312 ft
MSavage Posted at 2016-12-5 13:19
The few meter altitude gain at 3:40 is from going full throttle to stop sometimes the altitude will change a little bit as the barometer may be compensating from high speed to a stop.
And the lowering in altitude at 4:48 is from the aircraft entering landing mode so it started to descend then a few seconds later you cancelled landing.
I did have the data analysis team review the flight from the app and they said the aircraft is operating as it should. If you put something under the aircraft from that low of an altitude it will raise to keep the same distance from the ground.
But, they will review the flight data recorder when they receive it as that gives much more information and they will make a determination then.
2016-12-5
MSavage
DJI-Ken Posted at 2016-12-5 15:49
Ken. My question is, why is the aircraft going into Landing Mode in the first place? Is it not possible to hit the left/down control without initiating a landing mode?
2016-12-5
DJI-Ken
MSavage Posted at 2016-12-5 14:01
Let's just wait to see when the flight data recorder says as there's not enough data given by the app flight record.
2016-12-5
TrevHolland
If you were already having issues with the controls, why would you fly it at all? Am I crazy in thinking that the first sign of issues is grounds to stop flying and send it in for repair?
Not saying you deserved to have it fly into a tree branch, but I find it funny you start by saying you were already have one problem and then, because of your first problem, it crashed. When, in reality, it's because you decided to fly it again KNOWING it already had issues.
2016-12-5
MSavage
TrevHolland Posted at 2016-12-5 18:31
Hind sight is always 20/20. When I first reported my down control w/ "Landing Mode" issue on this forum. Most, including the the DJI Mods, suggested it was a calibration issue and to go ahead and recalibrate the controls and VPS. I'm not quite sure how I was supposed to see if that resolved the issue without actually flying the drone...but anyways.
What I didn't know was that the Mavic will automatically gain altitude if a car passes 10' underneath it. Combine that with luck of being under a tree and with a control/software that appears to be buggy and you have a crash.
2016-12-5
hallmark007
Flight distance : 10017858 ft
Hungary
MSavage Posted at 2016-12-6 01:08
Hind sight is always 20/20. When I first reported the down control w/ "Landing Mode" on this forum. Most, including the the DJI Mods, suggested it was a calibration issue and to go ahead and recalibrate the controls and VPS. I'm not quite sure how I was supposed to see if that resolved my issue without actually flying the drone.
What I didn't know what that the Mavic will automatically gain altitude if a car passes 10' underneath it. Combine that with bad luck of being under a tree and with a control/software that appears to be buggy and you have a crash.
I suppose if you were testing , you picked a really bad spot to do it, the outcome will be interesting I'm sure.
2016-12-5
Anthony566
Flight distance : 2488944 ft
This really looks like the Mavic did what it should and as the car passed under it the Mavic compensated for the brief change in ground clearance...  sorry you crashed.
2016-12-5
BuzzCut
So what can we learn from this (besides the tree part)?  How can others stop something similar from happening if the down control wont override the automated ascent in that scenario?  Disable VPS?  Something else?
It must have been frustrating watching that thing in a controlled rise for 5-to-6 seconds before it hit the branch with no obvious way to stop it.
2016-12-6
DJI-Ken
BuzzCut Posted at 2016-12-6 09:01
You can override the ascent, the ascent from it sensing the car was only a few seconds. The OP didn't give the  down stick input until it hit the tree branches.
So your last sentence is not correct.
If the OP will post a video of the flight record with the sticks overlaid you can see what I am talking about.
2016-12-6
BuzzCut
Thanks.  I was hoping that would be the case, and that the ascent could be interrupted at any time with a manual input.  I'd love to see the overlay here.
Also, the ascent appears to start while the car is still about 15-20 feet away from the underside of the Mavic.  So, do the bottom sensors actually propogate out like that?  Is there an approx angle of propagation?  It's of particular interest to me as I'm eagerly awaiting my Mavic and I have a number of use cases in mind where I'd want an object passing under - or close to under - the Mavic like that (a car being one of them).
2016-12-6
dotfiles
BuzzCut Posted at 2016-12-6 10:21
The OP said he gave the throttle a few blips to raise the drone up giving clearance for the car to pass under. When the drone is ascending before the car is under it, it was under his control. Then when the car passes underneath the VPS kicks in.
2016-12-6
Alansin
Flight distance : 634636 ft
Mexico
DJI-Ken Posted at 2016-12-6 10:15
How can he do that ? ( how can we all do that ) ?
2016-12-6
BuzzCut
I see what you're saying, but there appeared to be (after the multiple seemingly deliberate upward movements) a consistent slow and uninterrupted rise that lasted 5-6 seconds and started when the car was 15-20 feet away, hence the question about propagation.
Maybe that last 5-6 second rise was a combo of user input and VPS, but it appeared to be at a consistent and uninterrupted speed in the video, hence my ask.
2016-12-6
MSavage
BuzzCut Posted at 2016-12-6 12:50
It's actually closer to 40' because that's how wide the house lots are.. That's why I found it very strange indeed. I'm going to try to everlay the controls with the video. It happend very quickly but I swear I though there was enough time to have it reverse course.
2016-12-6
BuzzCut
Can't wait to see it.  I'll definitely learn something from this.  Sorry your Mavic got busted.
2016-12-6
hallmark007
Hungary
MSavage Posted at 2016-12-6 19:04
That's the thing with drones when you brake and try to reverse, there will always be a certain amount of continuous movement in the direction they were heading before braking, it takes a bit of getting used to, especially in close quarters.
2016-12-6
DJI-Ken
Alansin Posted at 2016-12-6 10:47
By lowering the throttle.
2016-12-6
MSavage
hallmark007 Posted at 2016-12-6 13:52
I realize that. I have compared the time stamp on the video with the flight data and I'm pretty sure the lower throttle command was done with enough time to reverse course. At worst, too close to call.
I have, like a few other on the forum, been experiencing a 'lower throttle' issue. The aircraft is unresponsive to a lower throttle input and subsequently enters a "Landing" mode.
Here is a video from a fellow mavic user.
Sample of the data from the flight showing unresponsive lower throttle:
latitude
longitude
ascent(feet)
speed(mph)
time(millisecond)
time(second)
max_speed(mph)
rc_elevator
rc_aileron
rc_throttle
voltageCell2
flycState
message
45.40675706
-75.647071
380.57744
0.223694
224300
224.3
21.17040016
1024
1024
1024
4.02067
GPS_Atti
45.40675706
-75.647072
380.57744
0.223694
224400
224.4
21.17040016
1024
1024
1024
4.02067
GPS_Atti
45.40675709
-75.647072
380.57744
224.5
21.17040016
1024
1024
883
4.02067
GPS_Atti
45.40675714
-75.647072
380.249356
224.6
21.17040016
1024
1024
693
4.02067
GPS_Atti
45.40675718
-75.647072
380.249356
224.7
21.17040016
1024
1024
651
3.97033
GPS_Atti
45.4067572
-75.647072
380.249356
224.8
21.17040016
1024
1024
651
3.97033
GPS_Atti
45.40675725
-75.647072
380.57744
224.9
21.17040016
1024
1024
653
3.97033
GPS_Atti
45.40675731
-75.647073
380.57744
225
21.17040016
1024
1024
603
3.97033
GPS_Atti
45.40675739
-75.647073
380.57744
225.1
21.17040016
1024
1024
568
3.97033
GPS_Atti
45.40675744
-75.647073
380.57744
225.2
21.17040016
1024
1024
544
3.97033
GPS_Atti
45.40675754
-75.647073
380.57744
225.3
21.17040016
1024
1024
571
3.97033
GPS_Atti
45.40675762
-75.647073
380.905524
225.4
21.17040016
1024
1024
648
3.97033
GPS_Atti
45.40675771
-75.647073
380.905524
225.5
21.17040016
1024
1024
635
3.97033
GPS_Atti
45.40675778
-75.647074
381.233608
225.6
21.17040016
1024
1024
581
3.97033
GPS_Atti
45.40675788
-75.647074
381.233608
225.7
21.17040016
1024
1024
526
3.98233
GPS_Atti
45.40675796
-75.647074
381.561692
225.8
21.17040016
1024
1024
528
3.98233
GPS_Atti
45.40675808
-75.647074
381.889776
225.9
21.17040016
1024
1024
540
3.98233
GPS_Atti
45.40675818
-75.647074
382.21786
226
21.17040016
1024
1024
478
3.98233
GPS_Atti
45.40675829
-75.647074
382.21786
226.1
21.17040016
1024
1024
461
3.98233
GPS_Atti
45.40675837
-75.647074
382.545944
226.2
21.17040016
1024
1024
453
3.98233
GPS_Atti
45.40675844
-75.647074
382.874028
226.3
21.17040016
1024
1024
404
3.98233
GPS_Atti
45.40675849
-75.647074
383.202112
226.4
21.17040016
1024
1024
364
3.98233
GPS_Atti
45.40675858
-75.647074
383.530196
226.5
21.17040016
1024
1024
364
3.98233
GPS_Atti
45.40675869
-75.647074
383.85828
226.6
21.17040016
1024
1024
364
3.98233
GPS_Atti
45.40675881
-75.647075
383.85828
226.7
21.17040016
1024
1024
364
4.02267
GPS_Atti
45.40675891
-75.647075
384.186364
226.8
21.17040016
1024
1024
364
4.02267
GPS_Atti
45.40675902
-75.647075
384.514448
226.9
21.17040016
1024
1024
364
4.02267
GPS_Atti
45.40675909
-75.647075
384.514448
227
21.17040016
1024
1024
378
4.02267
GPS_Atti
45.40675917
-75.647075
384.842532
227.1
21.17040016
1024
1024
389
4.02267
GPS_Atti
45.40675924
-75.647075
385.170616
227.2
21.17040016
1024
1024
404
4.02267
GPS_Atti
45.40675933
-75.647075
385.170616
227.3
21.17040016
1024
1024
406
4.02267
GPS_Atti
45.40675941
-75.647075
385.4987
227.4
21.17040016
1024
1024
406
4.02267
GPS_Atti
45.4067595
-75.647075
385.826784
227.5
21.17040016
1024
1024
406
4.02267
GPS_Atti
45.40675956
-75.647075
385.826784
227.6
21.17040016
1024
1024
408
4.02267
FORCE_LANDING
Obstacle Sensing will be disabled when   landing. Land with care.
45.40675965
-75.647075
386.154868
227.7
21.17040016
1024
1024
403
4.084
FORCE_LANDING
45.40675971
-75.647075
386.154868
227.8
21.17040016
1024
1024
403
4.084
FORCE_LANDING
45.40675979
-75.647075
386.154868
227.9
21.17040016
1024
1024
403
4.084
FORCE_LANDING
45.40675984
-75.647075
385.826784
228
21.17040016
1024
1024
403
4.084
FORCE_LANDING
45.4067599
-75.647075
385.826784
228.1
21.17040016
1024
1024
406
4.084
FORCE_LANDING
45.40675996
-75.647075
385.826784
228.2
21.17040016
1024
1024
430
4.084
FORCE_LANDING
45.40676002
-75.647075
386.154868
228.3
21.17040016
1024
1024
464
4.084
FORCE_LANDING
45.40676008
-75.647075
386.154868
228.4
21.17040016
1024
1024
589
4.084
FORCE_LANDING
45.40676017
-75.647075
386.154868
228.5
21.17040016
1024
1024
889
4.084
FORCE_LANDING
45.40676025
-75.647075
386.154868
228.6
21.17040016
1024
1024
1024
4.084
FORCE_LANDING
45.40676034
-75.647075
386.154868
228.7
21.17040016
1024
1024
1024
4.048
FORCE_LANDING
45.40676041
-75.647075
386.154868
228.8
21.17040016
1024
1024
1024
4.048
FORCE_LANDING
45.4067605
-75.647075
386.154868
228.9
21.17040016
1024
1024
1024
4.048
FORCE_LANDING
45.40676058
-75.647075
385.826784
229
21.17040016
1024
1024
1024
4.048
FORCE_LANDING
2016-12-6
Rocco12475
This must have been caused by thermal wind..
2016-12-6
hallmark007
Hungary
MSavage Posted at 2016-12-6 21:48
I do actually see where your coming from, and maybe it's a 50/50 thing and I really hope they sort it out, but really lessons need to be learnt if you had a problem, then try to sort it , not a good idea to put yourself in a position that can go so wrong when you already know there may very well be a problem, may just be better get it sorted before and be happy that the drone will 100% respond to commands and you can feel confident using in such situations.
Good Luck
2016-12-6
BuzzCut
DJI Ken, any ideas on the propagation of the lower sensors?  I think that's around 65*  That's quite a large field, even if that's the max.  That would mean that you could be in your front yard and a car could be passing or turning on the street near you and cause ascent.  Maybe that's required for Terrain Follow to be effective?  Seems pretty far reaching.
2016-12-6
DJI-Ken
MSavage Posted at 2016-12-7 04:48
Also remember DJI does not use any 3rd party data analysis as they may not read everything correctly.
Just wait until the flight data recorder is analyzed and they will tell you exactly what happened.
If you post your flight log playback with the sticks overlaid like I suggested earlier, you can see that the aircraft hit the tree one second after you gave 100 full down.
7:51 100% down stick input, 7:52 it hot the tree and you also gave 100% full forward and 100% full right bank. That was is the first part of the second, then with the same second 7:52 you gave 100% full left bank and 100% full throttle down.
So you didn't give the down stick input soon enough as the Mavic was rising from the car going underneath it.
Again, the last several seconds of the flight and the crash looks to be user error from what I can see from reviewing your flight. And the flight data analysis department said the same thing as me.
If your aircraft had issues prior to the flight or even during the flight, the last several seconds of the flight, the Mavic flew as designed to fly and without any errors that I can see.
Hopefully when they analyze the flight they will have a different conclusion.
2016-12-6
Alansin
Mexico
DJI-Ken Posted at 2016-12-7 03:39
srry, i meant how do we post a video where it shows your stick movement ?
2016-12-8
DJI-Ken
Alansin Posted at 2016-12-8 07:22
You can upload your video to YouTube, then post the link here.
2016-12-8
NomadRT
Flight distance : 1669012 ft
Heavysledz Posted at 2016-12-5 13:14
were you flying (hovering) directly above the street? If so, how high above the car was the drone when the car passed under it? I wonder if it sensed the abrupt change in altitude above the vehicle and in an attempt to avoid an obstacle, auto corrected upward into the tree?
This is exactly what I was wondering.    The quick movements would have been him.   The slow rise looked more like collision avoidance kicking in and raising the drone up because the car passed under it.
2016-12-8
Alansin
Mexico
DJI-Ken Posted at 2016-12-8 09:54
of course i can upload to you tube... i mean, how do i can post a video, where it also shows the overlay of my stick movement, or my route?
2016-12-9
DJI-Ken
Alansin Posted at 2016-12-9 13:34
From the home page in the DJI GO 4.0 tap the + sign on the top right.
Then tap Flight Record, then scroll down to whichever flight you want to see and tap that then tap the RC icon and it will overlay your sticks, then tap play and that's it.
2016-12-9
12
