Problems updating to latest firmware
12
20366 45 2015-2-12
markwiss.hotmai
I just installed the new firmware and the inspire 1 made noise and flashed yellow for an hour and 30 minutes.  After 45min I called support.  I waited 43 minutes to get there.  Finally the tech said it probably uploaded.  During the conversation, the noise stopped.  I checked the TXT file and it was successful. Updating my two RCs and two batteries went like a rocket.  It is not a complaint, but boy, that wait was frustrating.  The anxiety, though, was totally mitigated by the result. Communication between The Inspire and RC is better.  Seems much more stable and response time is better, too.
DELETE the txt file from the SC micro after EVERY update!  That got confusing fast
2015-3-13
sunstarfire
OK,
I know I am resurrecting a necro'd thread, but I found this when I was looking for my poblems, so I guess this is a good place to post some help…
I got a brand spanking new Inspire 1 (Revision D btw). When I fired it up for the first time, it said “firmware upgrade needed”.
I knew that from my Phantom, so I went right ahead.
And it seems like that’s what made me run into problems. Here is what happened.
- I am working on a Mac, so I put in the MicroSD in a Multireader (not some cheap-o crap, but a Belkin "quality" one). I got connection probs from time to time, no idea why. The card ejected from the Mac and was not there when trying to copy stuff
- I took the 16GB card that came with the Inspire, formatted it in the Mac to exFat and copied the Firmware onto that.
- I then inserted the card into the camera gimbal in the Inspire.
The Inspire would start the firmware upgrade, and then stop, changing from the D-D-D-D and DD-D-D sounds to a DDDDDDDDDD with a flashing yellow tail. Looking at the SD, the result file said “Failed” and “Try to reboot aircraft”.
I tried this like 10 times. Always the same.
Now here is what I did:
- I charged the battery to 100%. It was full in the first place, but for some reason it seems that is important.
- I took an 8GB microSD I had lying around
- I formatted that microSD with FAT32 using a dead simple USB thumb adapter in a Windows 8.1 laptop
- I downloaded the firmware via Firefox on that same laptop
- I extracted the FW on that same laptop
- I copied the FW to the microSD in the thumb on that same laptop
- I stuck the card into the Inspire
After that, everything went as expected and the FW upgraded successfully.
As a conclusion, these were the possible reasons for my failure:
Formatting the card on a Mac for some reason is not OK
Writing the file to the card on a Mac for some reason is not OK (I tried formatting the card in the copter, too)
Downloading the file on a Mac for some reason is not OK
Extracting the file on a Mac for some reason is not OK
You need a battery that is
- either 100% charged
- has more than 0 charge cycles
I thought it would matter to which version you upgrade from which, but the Inspire had 1.2 something, and I went right to 1.4.0.10 in my successful try, so that does not matter at all.
This solution worked for me (!!), and it is actually a compilation of several I read (use Windows, charge the battery)… So thanks to those who suggested that.
I really hope this is a help to some of you….
2015-10-9
saman.majdi
Iran
Hi dear
I have updated to the last version WM610_FW_V01.05.00.30 after upgrade aircraft and battery in during upgrade perform beep fail D----- and trying again with another version for downgrade after a few beep, beep fail
i use another SD card and forrmat SD card and redownload firmware and your all proposed i have doing but no avail.
and i turn on aircraft camera swing back and behind show
please help me.
log file & result file attached
[00009121]Delete history success.
[00009481]========== remo-con disconnect. boot(15) ============
[00009571]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x35ebcc5a].
[00009650]Packet upgrade start...
[00009742]Packet checking...
[00007447]========== remo-con disconnect. boot(15) ============
[00007647]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x35ebcc5a].
[00007828]Packet upgrade start...
[00008032]Packet checking...
[00008135]Packet upgrade failed at packet checking.
[00007338]========== remo-con disconnect. boot(15) ============
[00007571]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x35ebcc5a].
[00007799]Packet upgrade start...
[00007956]Packet checking...
[00008119]Packet upgrade failed at packet checking.
[00007790]========== remo-con disconnect. boot(15) ============
[00007959]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x35ebcc5a].
[00008075]Packet upgrade start...
[00008250]Packet checking...
[00008333]Packet vlink 01.03.0000 <-> 01.02.0000.
[00008411]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 1).
[00008487]Done.
[00008570]Version checking[1]...
[00008655][01 00][00] v2.47.4492 -> v1.19.3422
[00007639]========== remo-con disconnect. boot(15) ============
[00007801]Packet [C:\WM610_FW_V01.05.00.30.bin] detected, card sn [0x35ebcc5a].
[00007936]Packet upgrade start...
[00008082]Packet checking...
[00008242]Packet vlink 01.05.0030 <-> 01.04.0010.
[00008323]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00008412]Done.
[00008505]Version checking[1]...
[00008607][08 00][00] v2.14.9.35 -> v2.14.9.35
[00007521]========== remo-con disconnect. boot(15) ============
[00007758]Packet [C:\WM610_FW_V01.04.00.10.bin] detected, card sn [0x35ebcc5a].
[00007983]Packet upgrade start...
[00008121]Packet checking...
[00008298]Packet vlink 01.04.0010 <-> 01.03.0000.
[00008380]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00008460]Done.
[00008549]Version checking[1]...
[00007611]========== remo-con disconnect. boot(15) ============
[00007865]Packet [C:\WM610_FW_V01.02.01.06.bin] detected, card sn [0x35ebcc5a].
[00008011]Packet upgrade start...
[00008118]Packet checking...
[00008302]Packet vlink 01.02.0000 <-> 01.02.0000.
[00008386]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 6).
[00008463]Packet upgrade failed at packet checking.
[00007603]========== remo-con disconnect. boot(15) ============
[00007786]Packet [C:\WM610_FW_V01.03.00.00.bin] detected, card sn [0x35ebcc5a].
[00007903]Packet upgrade start...
[00008087]Packet checking...
[00008166]Packet vlink 01.03.0000 <-> 01.02.0000.
[00008251]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 1).
[00008339]Done.
[00008425]Version checking[1]...
[00006974]========== 2015.12.09 18:05:25. boot(15) ============
[00007204]Packet [C:\WM610_FW_V01.05.00.30.bin] detected, card sn [0x10ce088d].
[00007418]Packet upgrade start...
[00007564]Packet checking...
[00007677]Packet vlink 01.05.0030 <-> 01.04.0010.
[00007860]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00007929]Done.
[00008001]Version checking[1]...
[00008090][08 00][00] v2.14.9.35 -> v2.14.9.35
[00008165][01 00][00] v2.47.4492 -> v2.47.4492
[00008234][01 01][00] v2.47.4492 -> v2.47.4492
[00006866]========== remo-con disconnect. boot(15) ============
[00007108]Packet [C:\WM610_FW_V01.05.00.30.bin] detected, card sn [0x10ce088d].
[00007332]Packet upgrade start...
[00007446]Packet checking...
[00007632]Packet vlink 01.05.0030 <-> 01.04.0010.
[00007711]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
[00007783]Done.
[00007861]Version checking[1]...
[00007963][08 00][00] v2.14.9.35 -> v2.14.9.35
[00008039][01 00][00] v2.47.4492 -> v2.47.4492
[00007492]========== remo-con disconnect. boot(15) ============
[00007615]Packet [C:\WM610_FW_V01.05.00.30.bin] detected, card sn [0x10ce088d].
[00007702]Packet upgrade start...
[00007862]Packet checking...
[00007936]Packet vlink 01.05.0030 <-> 01.04.0010.
[00008129]Record vlink 01.04.0010 <-> 01.03.0000 (flow = 0).
Result file
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
========== 2014.01.01 00:00:07 remo-con disconnect======
Packet: WM610_FW_V01.02.01.06.bin
Result: Corrupted.
Result: Corrupted.
========== 2014.01.01 00:00:06 remo-con disconnect======
Packet: WM610_FW_V01.03.00.00.bin
Upgrading ...
Result: Corrupted.
Packet: WM610_FW_V01.05.00.30.bin
Upgrading ...
Result: Corrupted.
Packet: WM610_FW_V01.04.00.10.bin
Upgrading ...
Result: Corrupted.
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Upgrading ...
Result: Corrupted.
========== 2015.12.09 18:05:25 =====================
Upgrading ...
Result: Corrupted.
Upgrading ...
Result: Corrupted.
2015-12-11
DJI-Ken
Flight distance : 1515312 ft
Hello Saman,
First off, make sure you download from the DJI website as suggested in the .txt file.
But before you do, reformat the SD card from your computer thn download from here http://www.dji.com/product/inspire-1/info#downloads
Then extract the file and only Copt the .BIN file to the SD card and make sure nothing else is on the card.
Put the SD card into the aircraft and power it up and  it will update.
2015-12-11
saman.majdi
Iran
Hi DJI-Ken
2015-12-12
saman.majdi
Iran
I do this All proces you told you but not succses upgrade and after a few beep , beep fail update and camera swing back behind show
2015-12-12
12
