augusthansen
Flight distance : 89498 ft
I am new to all this. I've never owned a quad, drone, insert whatever name. I bought the Inspire, took it out of the box after reading the manual, watched tutorials and had it in the air that evening. I was never even aware of the CSC move of death. I consider this whole 'CSC Controversy' to be wayyy blown out of proportion honestly. Yes, its there. Yes, its there for the safety of others and other property. But have you noticed how unbelievably far out you have to tuck the sticks down and in to perform this? Unless you are doing some insane maneuver that isn't even truly effective, then your craft deserves to come down as maybe a sign you are flying a bit careless.
I've performed a handful of super successful flights, flying out over the trees, buzzing low to the ground on a dirt road without any issue. The controller is super responsive and I never feel the need to push the sticks not even HALF way to max output. Thus, never even coming close to the realm of an insident such as the CSC MOD.
One last thought. If they altered the firmware and put in your request to turn off CSC, then you fly it into a crowd and injure or kill someone, you will probably be the same person that then tries to sue DJI because you had no way to shut it off and now "its DJI's fault." Also, if in any case you do need to drop it out of the sky, its most likely to be due to a flyaway which is the ROOT CAUSE for having to perform this CSC. The real issue, DJI needs to address the flyaway bug.
Don't be scared to fly this thing, it's amazing! Sure, there are a few unfortunate exceptions like the one discussed in this post, but for the most part, these things are awesome and I'm having a blast. Fly safe, fly smart and don't try some crazy crap you probably shouldn't be doing in the first place with your new $4,000 drone. Cheers. |
