DJI assistant2 not working
12
39837 67 2017-1-9
fansb5a54234
Kuwait
SOLVED
quit the Assistant and keep the mavic connected to the pc and ON
go the device manager and you will find an unrecognized driver
choose it and choose the DJI Folder from the Program Files in your PC and let it look for the driver there.
and thats it
2017-12-26
Capt.Carney
Flight distance : 1191726 ft
thehippoz Posted at 2017-1-14 10:39
I have a older install of dji assistant 2 (1.0.7) if you need. I run it in a vm with vmware though. I ran it through total virus and one engine came up with Qihoo-360         HEUR/QVM06.1.0000.Malware.Gen
Same with the GO app, it keeps contacting the mothership on android, so I kill it and only run it when needed. I don't know why they want to spy on everyone, it's gotta be a chinese thing =] They probably know too much about everyone on this forum already!
legend... I was filming in Grenada and needed to reset the vision system. Couldn't get it to to work on windows 10 on my HP laptop or on my 8.1 pro system at home. Spent hours trying to make this work and found this thread. I.7 worked for me. Thanks man
2018-1-3
csaszarzoli
Flight distance : 160873 ft
Hungary
thehippoz Posted at 2017-6-5 13:02
https://www.dropbox.com/s/4l05ytvcwef7jyd/DJI%2BAssistant%2B2%2B1.0.7.exe?dl=0
Thanks so much!
2018-1-6
Spini
Flight distance : 81565 ft
hi everyone, i am experiencing the exact same issues as Maclak, despite following Bullseye's advice i am still getting the drive error when connecting to the USB, can anyone help with further diagnosing this issue ? Cheers
2018-1-6
312UAV
Flight distance : 768 ft
DJI Mindy Posted at 2017-1-11 01:39
Could you please provide some screenshot of the issue?
I'll help to report it.
Sorry for the frustration.
I am having the usb problem on all my birds since last update today. PH4 and Mavic / mavic controller will connect but birds will not, have tried on mac and pc. same thing, both connected no problem before the upgrade, it may be these no fly zones or the firmware I don’t know but I can get in any longer. different cords used, downgraded assist no luck same thing all around, I am certified on dji repairs and those will not connect either after all upgrades.  no screen grab needed it just sits on the blue circle the usb plug does not move. Something in the latest firmware cuts out the usb to pc,
The controllers and up still work via mobile divisive, just connecting bird directly does not work any longer.
again only mavic controller works nothing else that shows that my systems are working.
Looking into the manger on the PC it says unkown driver, but pointing to the DJI assistant drive folder does not correct the problem.
So this is telling me that your latest updates, dont know which one firmware or all these do not fly zone updates is messing up the usb settings to connect to a pc or mac.
please advice or send me a new something data to get me going please.
I was able to grab the manager you can see it is not finding the driver even after I point it to the folder.
it just about the blue highlight ohter device / unknown device
its pointing to the driver folder like it should so something is up there.
running win 10 64 but I will add again it does not load on MAC Air Pro either, I have both.
I just tried everthing one last time on the Macbook Pro same exact thing, contoller connects but the bird do not, USB to computer connection is dead from last batch or upgrades.
and yes I uninstalled reinstalled, I have done everything, I am not a novice at this, have been selling and reparing DJI products for some time now.
Thank you and please get back to me on this.
2018-2-13
312UAV
312UAV Posted at 2018-2-13 18:46
uploaded but like I siad its just the round circle screen doing nothing......
jsut the first scree
2018-2-13
aalbatross
same same problems, Win10 PC laptop and Win 10 desktop. clean install, 32 bit drivers, no USB or port conflicts...and I get the same page with a blue circle showing me how to connect an inspire 2...FFS, I have S900 not a toy thing like inspire.
2018-2-17
lannes
Flight distance : 4465 ft
Why don't you try the latest version of DJI Assistant 2 , I believe it's  1.2.2, which is a bit more recent than 1.0.7
2018-2-17
fans681ac1c1
Flight distance : 550548 ft
Same problem as 321UAV and Maclav. I've a new PC (Windows 10 64, AMD Ryzen). I've tried all the above solutions, even installing former version of DJI Assistant... DJI Assistant could't connect to my Mavic. I tried to run "DriverSetiup64.bat" on the command line and get messages saying for all the files that the path was not found (see picture)...
2018-3-18
Wachtberger
Flight distance : 261509 ft
fans681ac1c1 Posted at 2018-3-18 09:23
Same problem as 321UAV and Maclav. I've a new PC (Windows 10 64, AMD Ryzen). I've tried all the above solutions, even installing former version of DJI Assistant... DJI Assistant could't connect to my Mavic. I tried to run "DriverSetiup64.bat"[view_image][view_image][view_image] on the command line and get messages saying for all the files that the path was not found (see picture)...
I also have a new PC AMD Ryzen with Win10/64 and the DJI Assistant is working. Did you confirm during installation that you allow use of unsigned driver? I would suggest to try installing the latest version of DJI Assistant again.
2018-3-18
fans681ac1c1
Wachtberger Posted at 2018-3-18 09:53
Thank you for your help.
I've already installed and uninstalled DJI Assistant (last version and former one) many times (and cleaned my system with CCleaner)!... When installing, DJI Assistant doens't ask me to allow use of undersigned driver...  When I try to install drivers directly from Windows, no driver is recognized as such in the "drivers" folder... As you can see on 1st the picture above "eject DJI" is present (right corner at the bottom of the picture) but the SD card is still inaccessible with Windows Explorer.
2018-3-19
fans681ac1c1
I've tried again the above solution proposed by fansb5a54234.
Finallly, Windows installs Vision (interface 3) under "libusb-win32 devices" and I get a BSOD (DRIVER IRQL NOT LESS OR EQUAL) caused by ntoskrnl.exe...
After restarting my PC, DJI Assistant is still not working...
2018-3-19
Wachtberger
fans681ac1c1 Posted at 2018-3-19 00:59
I am very sorry about your problem but have no further idea right now...
2018-3-19
djiuser_jozzbTlc5PnZ
Fantastic!  It worked for me.  If you haven't already, you should alert the DJI developers of the problem AND, more importantly, the workaround you created.  It should help them to debug the issue and fix this pervasive bug for all users.  Thanks for your help!
2018-6-9
Mark Weiss
I have this problem too. Win 7 64-bit, app just says "how to connect to Inspire2" but I have a Phantom 4 Pro 2.0. Is this the wrong software?
2018-7-14
SmudgeMeister
Flight distance : 554 ft
New Zealand
fansb5a54234 Posted at 2017-12-26 07:35
SOLVED
Did not work for me
2018-9-1
fans681ac1c1
SOLVED
Looking for a solution for a very long time ! That works for me... Many thanks !
2018-9-20
Picanoc Jack
Flight distance : 10368153 ft
RichJ53 Posted at 2017-1-10 08:28
I had this happen before when the wrong version is being used with later FW. Please download the latest version of DJI Assistant 2 remove the older version by uninstalling it. Now install the new version and then reconnect to your Mavic.
DJI Assistant 2 v.1.0.9
That is exactly what I had to do Richj53, and it worked.
2018-9-20
Picanoc Jack
Bullseye Posted at 2017-1-14 15:01
Happy to help!  I am new to drones but not new to USB problems. I troubleshoot USB and other interfaces along with embedded software systems daily.
Great to know Bullseye,  being one who’s not too familiar with computers.
2018-9-20
RichJ53
Flight distance : 1837356 ft
Picanoc Jack Posted at 2018-9-20 20:15
Excellent news and I am glad you were able to get this working
DJI does a pretty good job of updating their programs. The problem is they have so many more drone platforms now, it is getting more difficult.
Rich
2018-9-20
Qi Yuan
Malaysia
did not work for me :// please help
2018-9-23
Tibopix
Flight distance : 4582054 ft
Hello thehippoz,
do you still have that DJI Assistant 2 v1.0.7 available?
I could use it right now!
2018-11-23
Chris1a
Flight distance : 801 ft
Sweden
DJI
Fix your Assistant app for Windows. It’s a mess of ugly hacks, unsigned drivers etc. It. Does. Not. Work. I’m trying to activate a pair of new DJI goggles in Windows 8.1, but I can’t (getting CDC errors etc). How can you sell products that rely on such extremely bad USB (and network) driver foundation? Your Assistant software and drivers are horrible, I know it can be hard to create good USB drivers etc, but if you lack the expertise needed to pull it off, without ugly and non working hacks, PUT A STICKER ON THE BOXES “Probably won’t even activate”.
2018-11-24
highbar
Nothing worked for me - tried older versions, back to 1.0.7...  Then I installed the flight simulator, which includes its own driver packages.  I actually had DJI Assitant 2 v. 1.2.4 running in background + powered on RC plugged in - all while the flight simulator install ran.   As soon as it finished, the RC became available in Assistant 2.
We should not have to troubleshoot $700+ products like this!
2019-1-4
djiuser_b6FZKwVdwa96
Flight distance : 19721 ft
New Zealand
Can anyone please link 1.07 ! Need it
2019-1-16
Shay13
Flight distance : 106355 ft
Link not found. I really need this. Probably going to send my drone and controller back anyway, I have multiple issues.
2020-1-15
djiuser_mZlXmXX4TleC
yhsong64 Posted at 2017-8-30 16:47
You solve my problem as well!!!  The version 1.1.2 didn't work for me and I followed your advice and used 1.0.7 and it worked. Thanks so much!
Can anyone share the link again or upload the file somewhere...
Shared link in not working anymore..
Thanks
2020-2-6
nado flying
Flight distance : 16 ft
Malaysia
i got the same problem, cannot connect RC mavic air to windows 10, do i have to seek Macbook to install  the DJI assistance 2 guys?
2020-4-2
12
