Electro-Nick
Flight distance : 7083891 ft
Well, mine was 'perfect' and I'd not had any problems until Friday, flew it, thought it sounded noisier and when I landed to change batteries found that the front red motor/prop was doing the rattle/click. Tried swapping it and noise disappeared. That was at 4hrs 30min of flying.
Today, checked when putting props on, same noise, unlocked prop, relocked... no noise. Took prop off, turned it thru 180, locked, no noise. Changed props back to front, noise appears, unlock & relock prop (without moving prop) noise goes. Go fly, land, check, noise is back again. Noise is always front red motor/prop. Hasn't appeared on the back yet, even with props that are noisy on the front.
It kind of sounds as though a bit of the locking mechanism is catching the top of the magnets, and clicking as it goes.
